Vector Feature Requests - Page 97 - RC Groups
This thread is privately moderated by JohnET, who may elect to delete unwanted replies.
Aug 23, 2017, 02:12 AM
KI7CBF
xtrmtrk's Avatar
Originally Posted by xtrmtrk
What I'd love to see: Support for failsafe testing in R/C transmitters. Typically, to truly test failsafe you need to turn off your radio - a pretty enormous leap of faith since it can take several seconds to restart. For this reason, I NEVER do this while flying, though I suppose I should.
Having an option to quickly and easily turn RF transmission off, and most especially back on (like the flick of a toggle on the Tx) would encourage me and a lot more people to truly test our failsafe setups.
Of course this is way out of the scope of an EagleTree thread....
I wonder what share of Vector users are using OpenTX. I wonder if we could request and get a TransmissionOff Special Function Action defined. That would allow us to attach it to a switch and turn off the RF transmission for just a small sliver of time to really test RTH.
I suspect if enough people pushed for it, the OpenTX group would implement it.
Aug 23, 2017, 10:14 AM
wojciechwas's Avatar
How about if you leave your radio on 'Range test' screen before take off?
During flight you could just activate it with one click and taranis/horus will beap to confirm.
This will result in 1/30 power output, so you can simulate long range flight.
Hopefully that would be enough to trigger real RTH assuming you are 129m high and 499m away
At any point you want to go back to full power output just hit enter again.
Aug 23, 2017, 06:58 PM
KI7CBF
xtrmtrk's Avatar
Not a bad idea! I think I'll use that.
Aug 23, 2017, 07:56 PM
Originally Posted by matchbox
Don't forget to post it here if you get around to it one day Pablo.
The hardest bit is making it simple enough to be inclusive, but not to complicated, that it distracts from everything else you have to keep in mind
Of course! Don't hold your breath, though
Sep 01, 2017, 02:33 AM
Originally Posted by JohnET
To be clear though, with all of these methods, once the test procedure is followed in the manual to confirm RTH is functioning with radio off, incorporating trims etc. should not affect radio-off RTH operation. If there are scenarios where this is not the case, wed sure like to see a repro of it!
Regards, John
Per comments / tests - https://www.rcgroups.com/forums/show...d-Wing/page451
SBUS RX
SBUS Vector Detection
RX Failsafe Position outputting RTH Test Mode
= RTH Test overides RTH Failsafe
Bug or oversight in the manual?
Sep 02, 2017, 08:07 AM
NMdesertracer's Avatar
Is there anyway to get a Auto-Launch feature?
Sep 03, 2017, 07:11 AM
Or how about Auto-Land? Perhaps a macro flight recorder that you could activate and have it record an example of a launch or landing. Then from wherever you are the aircraft could be commanded to execute the recorded macro of the flight maneuver and adjust using all of the sensors to complete the maneuver as safely as need. Would love to see some AI applications in the vector.
Sep 04, 2017, 06:21 AM
not necessarily auto land, but something like an ILS with glide path indication would be nice. Pitlab has it and this is for me the most interesting thing from Pitlab, missing from Vector. Maybe SkyGate is a good starting point
Sep 04, 2017, 11:38 AM
The lunatic is on the grass
ridgewalker's Avatar
Plane trimmed out good...put it in 2D give some elev up (mine is on a switch,turn off switch once plane is up) set the radio down give the throttle that the plane needs to launch and then launch the plane,go pick up your radio.
If you plane is trimmed out good then it should leave your hand and climb up nice.
That's my Vector auto launch.
Sep 04, 2017, 07:24 PM
And if you have a Taranis, see: https://www.rcgroups.com/forums/show...throttle-delay
Here you can see it in action:
New year, new gimbal (4 min 30 sec)
And Coyote describes it here:
MTD Launch Mix (5 min 32 sec)
Sep 05, 2017, 08:59 AM
Robertas
Someone maybe know.. does Eagle tree vector has a total km record ? Not post flight one , but overall
Sep 23, 2017, 11:31 AM
timsisson's Avatar
I'd like to see Spektrum SRXL support. Have an AR8010T which supports Traditional and SRXL... No PPM (which is limited to 8 channels anyway). SRXL supports 14 channels and allows you to program additional functionality from your transmitter - even beyond the number of channels you have. I have a Spektrum DX8 and I'm using all 8 channels on my fixed wing drone with Vector. I need to use Gear and F. Mode as well. If SRXL is already supported, I can't find it anywhere... So if i'm right and it's not - it should be...
Sep 23, 2017, 03:29 PM
Master of Disaster!
Sweetieinsf's Avatar
Flight Summary to Log File?
I find the Flight Summary, displayed in the OSD at the end of a flight, very useful - but I often forget to write it down in my logbook before powering off. Unlike many I diligently save my log files and clear the memory after every day flying and have found the info immensely informative down the road, especially when analyzing performance.
While I can go back and retrieve the info from my DVR recording (assuming I have one) that's a pain to find well after the flight. Some of the items in the summary (Max Amps, Max Alt, Max Speed, etc.) are fairly easy to determine from the log file but some items (Max & Total Dist. for example) are not.
It would be nice if the Flight Summary was:
A) Dumped to the log file OR
B) Available for viewing in the Log File Viewer OR a simple stand alone app OR
C) E.T. provided a sample Excel file with the necessary formulas to extrapolate the Flight Summary info from a raw log file.
Anyone else find this a useful feature?
SweetieInSF
Sep 23, 2017, 06:25 PM
KI7CBF
xtrmtrk's Avatar
Have you seen the CleanFlight/BetaFlight Black Box video overlays? I'd love enough data in the log files and the tools to do that with Vector data as well.
Of course, I'd love to see a bit more memory for log files; seems like they're always being overwritten on long flights for me. 6 hours worth of flight time (a good solid day at the field for me) would be awesome.
Idea Vector Feature Request Rick01 Eagle Tree Systems 2 Oct 13, 2014 05:16 AM
Discussion Vector Feature Request Rick01 Eagle Tree Systems 0 Dec 06, 2013 12:04 PM
