Thread Tools |
This thread is privately moderated by rcguy1958, who may elect to delete unwanted replies. |
Build Log
Dynam 1200mm FW 190 build, mods, repaint
After flying only 3D for the last few years, this season I'm going to mix in more scale flying. I already own a Durafly P-47 that I was very unhappy with in stock form, but after reading the thread on it, made the recommended improvements, and now it's a good flyer. So, I decided to try something slightly larger, and after reading many long threads in the electric war birds forum ( including the FW190 thread) decided to pull the trigger on the Dynam. The guys contributing to that thread have kept it simple and cost effective and all state that the plane needs very few improvements, which led to my decision.
The plan : 1) Change out the esc to a ZTW B series 45 amp I already have. ( the thread is split right down the middle on whether to change the esc or using the stock one, I trust all my 3D planes to ZTW and already have it on hand...hence the change) 2) Cut openings in the faux fan to allow cooling in for the esc and battery 3) I'm going to reinforce the motor mount plate with some Gorilla Glue before the first flight. There wasn't really a problem reported, but past experience with foamies is leading me to do this. 4)Install split flaps...have a nice idea about how to do it and will document and photograph it as I go. 5)Detail the cock pit somewhat, probably change out the pilot ( depending on which one it arrives with) 6)Reinforce the retract mounting and gear bays with 1/4 oz. glass/epoxy. Also, install birch blocks for mounting / increasing the forward rake of the gear. 7) Larger wheels....will determine which wheels after some more research. 8) Hinge the rudder, if not all surfaces. 9) Replace y-harnesses ( again....50/50 split on this...going to change to be on the safe side) 10) Full repaint. Attaching some pics of the possibilities so far |
Work is going slowly on the FW190. Reinfocement work around the wheel wells is complete, just needs finish sanding before paint. Received my graphics from Callie and they look perfect. Probably be a few more weeks before actual painting takes place but should go fast once I get back on it.
Any pics of it finished?
