Jun 10, 2014, 07:50 AM
SeByDocKy's Avatar
Mini-Review
Cheerson cx-10
INTRODUCTION
Cheerson is a relatively new chinese RC quadcopter brand who shipped first a nice Phantom clone: the CX-20.
In May 2014, Cheerson announced three new models i) two nanoquads: the CX-10 and the CX-11 and ii) one microquad: the CX-30.
This review is dedicaced to the CX-10, a nano quadcopter (40mmx40mm) with the "phantom" after my CX-11 review (https://www.rcgroups.com/forums/show....php?t=2173041)
This CX-10 belong the fast growing list of protoX clones : WLtoys V272, V282, V292, Moontop M9911, Cheerson CX-11, UDI U389, JXD 395 and more models to come. From left to right: the UDI U839, the WLtoys V272 and the Cheerson CX-10
The target price of this model is very agressive due to this fresh nanoquads war, less than 23 USD for this RTF model.
Is this cheap model equivalent or even better than the initial ProtoX ?
BOX CONTENT
+ 1 x Cheerson CX-10 (with a 100mAh LiPo soldered)
+ 1 x tiny controler (using 2xAAA batteries not included)
+ 1 x USB charger (ending with micro JST 1.25mm connector)
+ 4 x spare props (2 CW, 2 CCW)
+ 1 x Instruction manual (english only)
OVERVIEW
The main body reprensents a 40mmx40mm square.
The total weight of the CX-10 (including the 100mAh LiPo) is 11.9g so relatively light compared to a WLtoys V272 for example.
4 screws are locking the two parts of the canopy. The bottom part is scaling
Unfortunatly, the LiPo is directly soldered on the PCB
The PCB is welcoming on the bottom side the STM32 F050K4 as main MCU (a ARM core) while the upper side the Infineon 6050C as gyros+accelerometers (3+3=6axis) chip and a BK2421 as RFChip ([email protected]/s, BW 2.5Mhz, sensibility -85dBm).
This BK2421 is the former model prior to the BK2423 (in BK2423, they add the 250kbits mode and the extra sensibility flag to -87dBm but not used in practice in any known protocol).
Compared to most of similar models, only the F050K4 ARM core (http://elcodis.com/parts/5854903/STM32F050K4.html) is replacing the classic MINI54ZAN one.
On the rear side, can be find also a micro-switch. A total of 4 LEDs can be found: 2 blue for the front arms and 2 red for rear arms.
You can find a 2.4G dipole antenna on the upper side. 1 male micro JST 1.25mm connectors can be find to welcome the USB charger cable.
Motors are 6mmx12mm jailed into plastic motorpods. Compared to available ProtoX clones, motors are solidely blocked into these pods so you can expect some extra stability during flying.
If you need to replace a motor, you will have to first unscrew the bottom part of the canopy then unsolder motor's wires. The same is you want to change a LiPo.
Props, identical to the CX-11 are 30mm long and have an internal diameter of 0.6mm all in white color.
Even if you have different led colors to distinguish front to rear, it would be a plus if the props colors were different.
Props are slightly shorter compared to V272/M9911 ones
The shipped LiPo is a 100mAh (no charge rating given) and scaling approximatively 2.8g.
If you don't want to use the original charger, you can design you own cable with this micro JST 1.25 connector.
Basically, the ground clearance is the same than the V272.
The transmitter is very tiny (the same as for the CX-11), ideal for transportation but also not really adapted for large hands ("no free lunch").
Sticks are short but ending with 2 relatively large plastic "mushrooms".
Gimbal' springs are relatively strong. With such tiny TX, you can give relatively precize controls. You can find only 2 trimming buttons (1 of them is associated with the left/right steering.
You can change speed mode by pressing the left stick. 3 modes are available i) beginner, ii) intermediate and iii) sportive. In beginner mode, the TX led becomes green
To perform flipping, you need to press prior for the right stick (you can hear a click) and then indicate how to flip with the right stick direction.
Finally, you can calibrate gyroscopes by: i)right stick in upper-left corner then left stick in lower-left corner. The 2 back-rear red LEDS will fast flashing at the end of the calibration.
You wil need to insert 2 x AAA batteries (not included).
The good news is this protocol used by the CX-10 and by the CX-11 is the same than for the "YD-717-SKy Walker" quadcopter and have been already implemented into deviationTX.
So if you already modded your favorite deviationTX compatible Devo controller with a nRF24L01+PA, thanks to the last Nightly build, you will be able to enjoy this CX-10 with a great TX.
Instruction manual is in english only
FIRST FLIGHTS
After performed the calibration procedure, I tried first with the original TX. Even if I am not a great pilot with such tiny things, I was absoluptly not lost and manage to fly this insect quiet smoothy.
The quad is very stable, fast and quiet silent almost without drifting...
The CX-10 is reponding fast to vertical throttle. It's great. Flipping are good (you are almost not loosing altitude) and the yaw rate is good too, maybe slightly faster than the V272.
Good point, the CX-10 have a LVC alarm (led are flashing fast) when your LiPo is close to 3.7V. In more sportive mode, the quad is banking great.
I am estimating the flying duration equal to 5mm (3.7V measured voltage at LVC)
Secondly, I tried with my devo 7E outdoors ..... and of course it's really better... precise flight ans so fast !!!!. Actually, flipping are working by assigning a button to the fifth channel.
CONCLUSIONS
This quad is an excellent nanoquadcopter: stable, fast, robust. light, LVC alarm,and deviationTX compatible but in another hand, you can't insert a spare LiPo if you want to increase your fun time. For 23 USD, you can't be wrong with this quad !!! I like it a lot...
UNBOXING AND QUICK TESING
Cheerson CX-10 unboxing and quick testing (Courtesy of Banggood) (10 min 32 sec)
PROS
+ Stable, fast, and robust quadcopter (thanks to the 6050C, ideal for beginners)
+ Good vertical lift
+ LVC alarm
+ Close to 1.7g lighter than a WLtoys V272 (11.9g in total)
+ DeviationTX compatible (via the "YD-717-Sky Wlkr" protocol, found in the last Nighty Build. Requier to mod your Devo controller with a nRF24L01+PA chip)
+ Very good deal for the price
+ Tiny TX, easy transportation and ideal to train everywhere
CONS
- Can't insert/use a spare LiPo
- LiPo soldered on the PCB
- 4 white props
This quadcopter have been courtesy provided by Banggood in order to make a fair and not biased review. I would like to thanks them for this attitude.
You can find it actually for 23 USD at
http://www.banggood.com/Cheerson-CX1...105842201212FR
EDIT added model file for Devo7E
EDIT 06/20/14 THEY ARE TWO VERSIONS OF THE CX-10. ONE WITH RED PCB AND ANTENNA "ABE" COMPATIBLE WITH SKYWLR PROTOCOL, ANOTHER ONE GREEN WITH A NEW PROTOCOL
Jun 10, 2014, 07:51 AM
SeByDocKy's Avatar
Reserved for mods and videos
CHEERSON CX-10 outdoors flight (Courtesy of Banggood) (1 min 42 sec)
With vertical antenna pointing
Jun 10, 2014, 10:17 AM
Sbd, if you have to pick one, cx-10 or m9911?
Jun 10, 2014, 11:13 AM
SeByDocKy's Avatar
Both
No kidding .... the M911 seems a little bit slower in FFF outdoors .... but got a great yaw rate
Jun 10, 2014, 11:39 AM
UltimateMicroQuads's Avatar
Great review like always Seb. Ok I am getting one lol. Could you share your ini. file for the 7e?
Jun 10, 2014, 11:43 AM
Geez you're not making this any easier, are you
The yaw rate seems to be fast enough. Did you mean the M9911 has even faster yaw rate?
Jun 10, 2014, 11:46 AM
SeByDocKy's Avatar
Yep ...
Jun 10, 2014, 11:47 AM
SeByDocKy's Avatar
Here is mine ... D/R on FMOD 1 , FLIPS on HOLD1 + FMOD1
Jun 10, 2014, 12:10 PM
Timmyd463229's Avatar
what's channel is flips on
Jun 10, 2014, 12:28 PM
SeByDocKy's Avatar
Channel 5
Jun 10, 2014, 02:36 PM
Thanks a bunch, order placed
Jun 10, 2014, 07:39 PM
Very thorough review. Thanks.
The battery is soldered as expected, considering such a compact design.
Anyway, I'm getting my own soon.
Jun 10, 2014, 08:39 PM
Would you say that because of the shell, the CX-10 is more durable and less prone to damage ? If yes, maybe you should put that in the pros list.
Jun 10, 2014, 11:00 PM
cr8tive_leo's Avatar
nice review, my manual is all Chinese, not one word English.
Could you possibly post better images of the manual?
Tiny quad...
my thumb squishes it like a bug...
Jun 10, 2014, 11:20 PM
LOL yea. It's getting really close to actual bug size.
In a few years they'll make it much smaller. Give it autonomous power source, swarm intelligence, detection avoidance, face recognizition, etc.. can't run from the wife anymore
For Sale Cheerson CX-10 / CX-10C and Hubsan X4 H107C Micro Quads GigaQuad Aircraft - Electric - Multirotor (FS/W) 0 Sep 29, 2016 10:41 PM
New Product Cheerson CX-10DS, Newest Member Of Cheerson CX-10 Series Squirrels Mini Multirotor Drones 2 Jun 02, 2016 09:02 PM
Help! Cheerson Cx-10a or cx-10 which one has bettter range?? Ahnaf Tazwar Mini Multirotor Drones 7 Nov 20, 2015 02:38 AM
Help! Cheerson Cx-10a or cx-10 which one has bettter range?? Ahnaf Tazwar Mini Multirotor Drones 0 Nov 19, 2015 07:58 AM
Discussion Cheerson Cx-10a or cx-10 which one has bettter range?? Ahnaf Tazwar Multirotor Drone Talk 0 Nov 19, 2015 07:41 AM
