This thread is privately moderated by Red.Sneakers, who may elect to delete unwanted replies.
Jun 08, 2014, 10:53 AM
2016 The Year for Air Shows
Red.Sneakers's Avatar
Build Log
The Safe Tag System ground school
The Safe Tag System is a passive ESC Lock-Out system. Very cheap to build. Easy to use.
Why use it? Have you ever left a battery in the belly of a plane by mistake? Do you have someone in pilot training and want a visual way of verifying they removed the battery? Have you ever had to scramble to see which plane has that ‘lost’ battery? Have you ever handled some else’s plane only to find out you were not told the system is armed? I know this is not for everyone. The larger the size of the batteries & props you use, the more seriously you should consider this system.
click on picture to view larger
Name: Larger  Belly Plane.jpg
Description: Larger  Belly Plane Dean Plug Name: Hidden Battery.jpg
Description: Hidden Battery Safe Tag Name: Belly Battery.jpg
Description: Belly Battery Safe Tag
Name: Dean Plug Safe Tag.jpg
Description: Dean Plug Safe Tag
The idea comes from our friends at the Holdfast Model Aero Club, in Australia, who adopted The Safe Tag System as a required safety measure for the operation of electric-powered models. It is a simple add-on to both fixed wing and helicopter models, with no modification to the model itself. Thanks to our friends down under for this simple but effective idea. www.holdfastmac.asn.au
View The SafeTag System Build Specifications (PDF format), click here
I shall call him The Safe Tag
Name: The Safe Tag.jpg
Description: The Safe Tag
