Build Log
Second Great Planes Electricub
This was one of my first RC builds when I was getting back into the hobby. I built it per the plans with no mods and even used the 600 motor. She is a great flyer that is impressive to see in the sky. The 600 motor froze up and I added a 400 Rimfire motor and she did just fine with the 400. This is a sport scale but the window area has always bugged me and my current cub is pretty beat up so I decided to build another. This is an old kit from Great Planes and I doubt it will be around much longer, but who knows. This time it will still be built per the plans but will look more like the Great Planes .20 Cub. I am widening the window area and adding a side stringer. I will also be using Rimfire 400 or .10 have not decided yet. I am building with wood glue and will cover with Monokote.
On the frequency now, scigs. Good luck with the second edition!
BTW, nice work on the first edition. This kit has been in the basement since I brought it home back in 2003. Work and other projects just kept getting in the way. By coincidence I pulled the manual out the other night to look it over. A few questions, if you don't mind: Did you build yours with ailerons, or for three channel? What range of flying conditions have you put her through? How did she perform in wind? Best regards, Chris PS - I thought some jury struts might improve the scale appearance also. |
The kit is designed for strip ailerons and that is what I used. She handles great, flied like the real Cub and looks awesome in the sky, minus the small side windows.
I have some more done on the fuselage and she is starting to take shape. The only modification here shaving some balsa from the cabin doubler for the enlarged windows. |
Started on the front cowling, really not too many modifications here either. The Second former already comes in the kit but originally not used, but I used it to extend the cowl. Next is trimming the front window and cowling.
ImagesView all Images in thread
Added the plastic Cowl and Window, using the same pre formed window that came in the kit.
I have the first version. My only advice is to chuck the motor mount and get a good metal one, or build a strong 1/8 aircraft ply mounting box.
Mark |
Mark's right. We had both the first and the second versions of the kit, and the motor mounting was always a problem.
CD |
I added the 1/8 side stringers, first I added 1/8 sq balsa where the stringer needs to attach. I drew the stringer on the plans and put the measurements on the plane.
The only laser cut parts in the kit are for the stab and rudder, and they are not a perfect fit. All you have to do is pre fit everything and sand where needed for a smooth fit. |
I had one of the old versions back in the 550 can motor/6-cell r/c car battery pack era. It still flew pretty well, and it would thermal surprisingly well. I flew it for a number of years and hundreds of flights before robbing the gear out of it for an ElectroStreak.
With modern brushless motors and LiPoly batteries it should be way, way lighter. |
The problem with using lighter motors and batteries is that you need nose weight. So, when I built my wife's E-Cub II, I used a Jeti 30/3 for power (fit right into the brushed motor mount) and replaced the 8 cell NiCad pack with a 3S4000 Lipo. 15+ minutes of non-stop acrobatic power
at the same weight and balance.Fun E-Cub memory: I had an Astro C05G on 8 900SCR cells in Micki's first E-Cub (which I'd modified by adding barn door ailerons). The radio we had back then was a Futaba with a Snap Roll button, so I showed her how to use it. My mistake! She'd do consecutive snaps throughout the entire traffic pattern... BTW, the snaps didn't kill the model. It died from being shipped from Germany to Nebraska in the summertime. When it somehow arrived uncrushed, I had high hopes...then I saw the wing and tail feathers had all potato chipped. Tried shrinking out the warps, but no joy.CD |
I have an Axi motor on 3s 2200. Flies great, and yes, you can thermal it. I added eflite Pitts wheel pants, makes a cute bird. Also went with aluminum gear.
Mark |
