Apr 21, 2017, 12:59 PM
Plus Pilot
Jumanoc's Avatar
Originally Posted by webvan
Ok, so maybe it was 96 then, will have to double check.
Ah so it goes in stand by if not moving? Didn't know that, wonder how they do that without an accelerometer.
Easy... compares last 2 sat coordinates... no change .. no report...
Apr 21, 2017, 01:17 PM
Right, I thought you were referring to a standby mode based on movement. That new tiny magnetic Banggood tracker (now unavailable) seems to do that with is accelerometer.
May 07, 2017, 12:11 PM
Pretty decent battery life indeed but I'm finding it sometimes disconnects from the GPRS network for no apparent reason. I've tried to reactivate that with goff# and gon# but no go, strange.
Originally Posted by guyst
New product that looks interesting' similar to the RF-V16 - http://bit.ly/2dUlRYC
Back in stock now, has anyone tried it or seen a review ? Hard to find something with that generic "Smart Mini GPS Tracker" name !
Jun 05, 2017, 08:22 PM
kiosk's Avatar
has anyone had their H20 sim/service stop working on their unit? mine just flashes the orange light slowely now , indicating no GSM network....I heard they shut down 2G service or something....anyone know about this?
Jul 27, 2017, 08:50 AM
Bringamosa's Avatar
Also interested in this little tracker from banggood, still nobody else tried it?
Aug 29, 2017, 08:54 PM
anyone??
today is the best option the rf-v16? 34 in amazon
Sep 01, 2017, 10:56 AM
Team Drone Art
Daryoon's Avatar
That's correct. They were using AT&T 2G network. And at the beginning of the year, AT&T shut down that network.
I liked H2O as they had a plan for $9 every three months.
I just installed the Speedtalk plan for $5/month. It uses the T-mobile network as far as I know.
Sep 09, 2017, 05:28 AM
The battery life on my 1 year old RF-16 has become terrible, only a few hours in non-tracking mode and it recharges very quickly. Anyone had that problem before ?
Sep 14, 2017, 04:14 AM
Problem solved after I sent a dw# command. Apparently the GPS was stuck in "on" mode (tracking was off) even though it had been restarted several times, some kind of bug I suppose !
Oct 24, 2017, 05:00 AM
Hello,
I am new in this GPS tracker world.
I just read on the net and I find that best options for drone tracking are the RF-V16 and
TK102?
Are there any other options? I need this for the long range drone.
Thank you in advance,
Cheers.
Oct 27, 2017, 02:47 PM
kiosk's Avatar
hard to go wrong with the RFV-16, there is also this if you want to spend a lot of $$$
http://4gmetry.voltarobots.com
Jan 01, 2018, 07:54 AM
Looked Searched everywhere... No luck. Any idea how to change imei number on these trackers?
Jan 01, 2018, 07:19 PM
kiosk's Avatar
I don't think u can, but why would you need to
Feb 03, 2018, 12:32 AM
IOT Related
I have one device and it contain jd_ads.bin file. I want to get the location from the device what i have to do and how can i get the location.
Jun 24, 2018, 05:31 AM
Maybe anyone else noticed this with th RF-v16. I have one in the car (plugged into USB in the trunk), location updated every 2 minutes through gprs (that way data usage is mainly "under the radar" of the prepaid card I am using, and hardly any data is detected.
This generally works pretty well. My only issue is that sometimes the final location of the car at the end of a trip is way off (maybe 500m). Note this is a GPS location of just before the arrival at the actual location, not LBS. Even getting a "Request location once" from the settings menu in the app does not refresh the location, which is a bad implementation IMO.
I understand there has to be some mechanism the tracker uses to decide if the device has moved or not to save power, and that it will not upload a new location if it has not moved for more than 50m or so, but requesting a manual location should override this behavior and always return the actual location. Has anyone else experienced this and found a workaround?
