May 30, 2014, 07:23 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Specs:
Wing span: 700 mm (27.6 inches)
Length 860mm (33.9 inches)
Material: 6mm Depron or MPF (approx one and a half full sheets) 1000 x 700 sheet
Servo’s: 2 x HXT900 9g (or similar) Elevons
Motor: D2826-6 2200kv Outrunner Motor (or similar)
ESC: TURNIGY Plush 40amp Speed Controller (or similar)
Prop: 6x4E propeller (or similar)
All up weight: 535 grams (18.8 oz) with 1500 / 3s battery
Lockey
May 30, 2014, 08:38 AM
serial scratchbuilder
Granted's Avatar
Who are you and what have you done with Lockey and his complex builds?!?
Seriously tho, looks like a winner. Will it be water-capable as well?
May 30, 2014, 04:08 PM
skumgummi dave
Wowser! and Zowie...
May 30, 2014, 06:32 PM
Aus
Aus
ʎןɟ inverted ɹǝpunuʍop
Aus's Avatar
Looks great as usual Tony. Can't wait to see this one fly.
May 30, 2014, 07:48 PM
Lockey's Avatar
Thanks guys .. thought it was time I did an easy one should be able to build this one in a couple or 3 evenings
Didn't give this a thought BUT, I have no doubt (if it flies good) that it could be made to ... all it would need really is a step ... I guess ??
By the way, do you prefer the squarer version or the more rounded version?
Lockey
May 30, 2014, 07:59 PM
Granted's Avatar
Lockey
Which one flies better? Rounded gets my vote for appearance.
May 30, 2014, 08:16 PM
Lockey's Avatar
Don't know Granted ... neither might fly ?? ... oh and by the way ... here's your water version
Lockey
May 31, 2014, 08:02 AM
Lockey's Avatar
Spent a few hours today and almost finished ... this is a very quick build ...
Radio gear is in and working ... another couple of hours shooud see her ready for maiden
Just coloured packaging tape this time
Weight without battery is just under 400 grams, I will be using a ZIPPY Compact 1500mAh 3S 25C Lipo Pack and this weighs about 120 grams so all up I should be under 550 grams (19.4 ounces) I am happy with that weight
Lockey
May 31, 2014, 08:21 AM
Lockey's Avatar
Can anyone confirm the CG for me please
Lockey
May 31, 2014, 11:26 AM
use this
add another panel , by pressing the green +1 button
ignore the the motor mount cut when using this website, its not possible to cut this on the web program.
it won't make is worse
May 31, 2014, 12:10 PM
seeingeyegod's Avatar
Looks cool!
May 31, 2014, 08:26 PM
Lockey's Avatar
Thanks Goly ... apart from the fact I forgot to add on the elevons before, here is the comparison (with elevons)
Seems I am about 20 mm out ... although that is showing at 20% and I guess thats pretty conservative eh
Lockey
Jun 01, 2014, 02:05 AM
Lockey's Avatar
Finished trimming and ready for maiden, bottom is just covered with clear packaging tape
She weighs in at 532 grams (18.8 ounces) with 1500 / 3s battery
Lockey
Jun 01, 2014, 04:57 AM
look at this, i have added your front fuselage
