May 24, 2014, 01:51 AM
Dave Pope Manawatu NZ
pope's Avatar
Build Log
PMS Mk2
Well I thought I might start a new thread on the PMS Mk2
First starting with the fuse plug. Started with laminated mdf but too flexi so now back to the wood lathe for take 2.
A few hours and off the lathe, wont do much with the fuse plug untill the tail plane and wing are cut to setup the fin. First will be the wing saddle then placing and shaping of the fin, then finally the saddle for the tailplane.
More Soon.
May 24, 2014, 02:44 AM
There is only DS
airtimeasto's Avatar
mk2
way shorter
May 24, 2014, 03:25 AM
taurineman's Avatar
What's the driver for the shorter tail moment, Dave? Same wing or a molded wing?
taurineman's Avatar
Oh is this for the two meter version?
May 24, 2014, 03:59 AM
pope's Avatar
Yes this is the 2M version, that we had on the planning thread.
May 24, 2014, 05:13 AM
Jets:)'s Avatar
Cool dave.
You going with a t tail?
Servo in the tail?
One piece wing?
May 24, 2014, 05:28 AM
Mr Windburner
Kevin Bennett's Avatar
Looks good Dave.
How are you going to do the wings.
Kev
May 24, 2014, 03:04 PM
pope's Avatar
I am going with a servo in the base of the fin. This is the prototype. One peice wing easy no joins. The first wing will be a bagged one. Section coming from sean. The second will be a plug cut from super hd foam from eban and then molded. Want to fly first before molding to make sure all good. Just cut tail plane and came out well.
May 25, 2014, 12:12 AM
Auzzie built planks
timbuck's Avatar
Looking good .. going to fly great with a New SMDS section
Latest blog entry: More colours
May 25, 2014, 02:07 PM
jonoashton's Avatar
Nice one Dave. You are a building machine !!!
May 26, 2014, 01:12 AM
pope's Avatar
Recieved the airfoilds and layout for Sean today. Looks awesome, we cant wait to crack into the prototype build.
Massive effort from Sean, to help us Kiwi's thanks again is awesome.
May 26, 2014, 01:25 AM
Auzzie built planks
timbuck's Avatar
Great work sean , top bloke
May 26, 2014, 03:52 AM
Remember... Fly for fun!
ALEX HEWSON's Avatar
+1
May 27, 2014, 04:17 AM
pope's Avatar
We are not going to put in diheadral on the mk2,
Question. for the mk1 does diheadral make for a slower DS model?
May 27, 2014, 05:49 AM
There is only DS
I disagree Dave.
The K2m has a bit of diheadral and it's one the fastest models in the world.
The diheadral will help the plane lock into the circuit easier.
If you have dsed a thermal model before then you will understand what I mean.
Just my 2 cents
Asto
