May 23, 2014, 06:05 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Build Log
MIG-15 Pusher Prop
The wing is the only think I have salvaged from the EDP Mig-15
I am going to use this wing on a new Mig-15 I have re-designed as a pusher
This one should be a fairly quick and easy build and only uses 1 sheet of Depron and 3/4 sheet of MPF for the bendy bits ... AND ... if you want wing tanks a bit of 50 mm blue foam (or similar)
Wing span is 1000 mm (39.37 inches) length (shortened a little) 920 mm (36.22 inches)
I will be using:
D2826-6 2200kv Outrunner Motor with 6 x 4 prop
TURNIGY Plush 40amp Speed Controller
HXT900 9g / 1.6kg / .12sec Micro Servos
Only problem I foresee is getting the CG right without adding weight or a large battery ... with having the motor right at the back
I am going to try it without a rudder ... BUT ... it may need one for ground handling as I will be doing this one as a belly / grass slide (as usual ) rudder can always be added later
Lockey
May 23, 2014, 06:06 AM
Lockey's Avatar
Plans and build info
Please note, these plans have not been tested since mods have been made, if you build please let me know if you find any mistakes
If you are using MPF for the outer skin, there will be very little sanding of the ring formers, however, if you are using Depron you will have to sand the ring formers about 1 mm or so all round as the Depron is about 1 mm thicker than the MPF
Plans are now available at: http://www.lockeysrcplans.com
Lockey
May 24, 2014, 05:37 AM
Lockey's Avatar
Got the plans printed today and started the build .. remember, I am using the wing from the other MIG-15 with the Ducted prop that was a failure
Found a couple of minor mistakes on the plan so far
Lockey
May 25, 2014, 11:11 AM
from France
Lnk47's Avatar
can't wait for PDF A4 Tiled plans !
Congrats for this bird ! Hope the maiden will be a success !
Cheers from France
May 25, 2014, 08:20 PM
Lockey's Avatar
I will post the pans as soon as I know she flies OK, can't see any reason she won't though
Before adding the outer covering, I did some tests with the motor in the original place that I had meant it to be and it was not balancing with a 2200 / 3s battery
So .... I decided to moved the motor 65 mm forward and down bu about 30 mm (to fit inside the fuselage) ... I am hoping that this will be enough to be able to balance it ... and I hope it will be high enough to clear the ground on take off ... all a bit of a compromise really
Lockey
May 26, 2014, 03:19 AM
from France
Lnk47's Avatar
don't you plan to hand-launch it ?
May 26, 2014, 05:19 AM
Lockey's Avatar
Wash your mouth out ... If you have read any of my other threads, you would know ... I HATE HAND LAUNCHING
Lockey
May 27, 2014, 10:40 PM
Watt Waster
Tsavah's Avatar
New Build, or Rebuild as a Pusher Mig 15
Originally Posted by Lockey
... If you have read any of my other threads, you would know ... I HATE HAND LAUNCHING Lockey
I do understand the reasoning, but keep in mind some folks don't have a nice place to do otherwise. I like your careful planning and since you are using a small diameter propeller, one more degree of clearance should be plenty as long as the grass and weeds are short. Looking good.
Latest blog entry: Center of Gravity - Airplanes
May 28, 2014, 03:30 AM
Lockey's Avatar
Well ... she is ready for the Maiden at AUW of 735 grams (26 oz) with 2200 / 3s battery (needed for balance)
May get chance to maiden today if the wind holds off
Lockey
May 28, 2014, 05:08 AM
Lockey's Avatar
I could almost say the maiden was a success … almost
I had to hand launch as she wasn’t going to take off on her belly … again it seemed not enough power, which really surprised me
Anyway, against all my feelings, I hand launched and got away with it … the first time and she didn’t need much trimming before she was flying nice
I was a little low and didn’t want to risk stalling it, so I decided to land her and tried again to hand launch her … disaster … I didn’t get to the controls quick enough and she hit the dirt
Ah well back to the drawing board once more, repair the front and see why I don’t have enough thrust
Getting a bit fed up of repairing Mig front ends
NOW YOU KNOW WHY "I HATE HAND LAUNCHING"
Lockey
MIG - 15 Pushe Maiden
(3 min 21 sec)
May 28, 2014, 07:01 AM
mig 15
hey lockey nice maiden, it flew great ( once you launched itlol)
you build so quickly and your parts look like they came from a kit, what software are you using for the drawings, they're beautiful and do you have a laser cutter for the foam pieces sam
ps I'm trying to get to the phillipines this winter, its too bad I can't slip over to austraila and actually meet you sam
May 28, 2014, 07:12 AM
Lockey's Avatar
I just use Google Sketchup mate .. and if you ever do make it to Oz, you are more than welcome to come for a visit ... I use the trusty old knife for cutting most parts and I use a little Dremel saw for the smaller parts ... http://www.dremel.com/en-au/tools/Pa....aspx?pid=MS20
... and its GREAT
Lockey
May 29, 2014, 04:36 AM
Lockey's Avatar
Did the repair this arvo and flew her again this evening .. I made the nose about 20 mm (3/4 inch) longer and it made all the difference to get the battery a little further forward and was able to remove the BIG nut I had taped to the front ... I also added a bit to the back to lift the back end up to clear the prop, will change this on the plans and lift the motor about an inch or so
I changed the prop to a 3 blade Master Airscrew and it seemed to have more punch BUT still wouldn't get off the ground on its belly so had to hand launch again ... with my left hand this time
She does fly really nice and doesn't seem to have any bad tendencies
Now to work out how to get here to lift off her belly ... I would have thought she had enough speed, so I need to get the front up a bit more ... OR maybe a skin of 3 mm Depron on top of the wing to make it into an airfoil, that might just do it ... what do others think ?
Strange how well it steers with NO RUDDER ... thats with ailerons .. see video
Lockey
(5 min 24 sec)
Discussion 70mm edf mig 15 to pusher prop sco215 Pusher Prop Jet Models 0 Apr 22, 2011 01:27 PM
