This thread is privately moderated by plane_tech, who may elect to delete unwanted replies.
Jan 24, 2015, 08:44 PM
rockbus's Avatar
Here is a nice build thread that popped up.
https://www.rcgroups.com/forums/showthread.php?t=496905
Oct 01, 2015, 08:28 PM
Balsa dust maker
plane_tech's Avatar
Cleaning up the thread a little.
Deleting all not relevant posts.
Any one have anything new to add while I am here?
Dec 12, 2015, 03:13 PM
F3Foamie Pilot
Would you consider my Leading Edge Gliders P-80 build thread?
https://www.rcgroups.com/forums/show....php?t=2512688
Apr 17, 2016, 02:09 AM
Balsa dust maker
plane_tech's Avatar
Need to do some cleaning up around here, but I also found couple videos in the mean time.
I will add a heading for this if anyone wants to add videos of interest showing building techniques, setup, etc.
Here is a playlist tutorial of XFLR5. This has to be one of the better ones that I have watched.
XFLR5 Tutorial
May 09, 2016, 04:06 PM
kdcnett
carbon pushrods
hi guys
would you where i could get carbon pushrods
thanks, kim
May 09, 2016, 05:50 PM
Balsa dust maker
plane_tech's Avatar
Originally Posted by kdcnett
hi guys
thanks, kim
Hi Kim -
If you look under post #5 of this thread, you will find a list of Materials and the vendors that supply them.
For pushrods, I would recommend CST or ACP.
Jun 04, 2016, 11:29 AM
Wing Core Templates
Thank you for getting back to me so quickly.
I found what I needed here:
Foam cutting with the Tekoa Feather Cut - part 2 (10 min 46 sec)
My questions had to do with the run in and run out of the template and the minimum vertical dimension at the bottom of the lower template. I have the Comp-U-Foil program and the formica material and the 3M77 spray adhesive. No I just need to get-er-done.
Tom Fowler
Mar 18, 2017, 06:11 PM
Why grow up, it makes no sense
SwaFly's Avatar
Originally Posted by TomFlyer
Links are not working for me. I get a new web page that says: "about blank"
Help.
Ditto!
Mar 18, 2017, 08:33 PM
ForeverFlying's Avatar
Me too!
Mar 19, 2017, 02:16 AM
Balsa dust maker
plane_tech's Avatar
Awesome... I will look into it asap.
thanks for the heads up
Mar 19, 2017, 02:54 AM
All beter: Works now !
Tom f.
Mar 19, 2017, 02:56 AM
Balsa dust maker
plane_tech's Avatar
Help.
Originally Posted by SwaFly
Ditto!
Originally Posted by ForeverFlying
Me too!
All should be fixed. I tried a random sampling of some to verify they are working again. IF you find a dead link, please let me know which one.
IF a link is outdated and you know where to find the new link, please provide it as well so I can promptly update the database.
Thanks all for the heads up.
Also Cleaning up the thread a little. Deleting all not relevant posts.
Apr 10, 2017, 09:24 AM
Warbirds Lover
Dreamcatcher's Avatar
Subscrived
Many thanks, Sir !
May 31, 2017, 05:59 PM
Hinge wipers ?
I am looking for a build thread on how do make aileron and flap hing wipers. Search engine for this thread did not turn up anything.
Suggestions?
Tom f.
