This thread is privately moderated by plane_tech, who may elect to delete unwanted replies.
May 22, 2014, 10:28 PM
Balsa Dust Vs Foam Dust
plane_tech's Avatar
FAQ
A collection of How-Tos, Build Logs, and other useful threads...Part 2
Greetings all.
As mentioned here, in the original thread, "A collection of How-Tos, Build Logs, and other useful threads.", I complied all the the links scattered through the thread, and updated the list. Also, adding in some others that I had bookmarked.
Please feel free to post more and I will add them to the list.
May 22, 2014, 10:29 PM
plane_tech's Avatar
Build Logs
Build Logs
Plane Specific - Build logs - From Scratch
"BUGATTI" scratch build (ArtSloper)
80" dynamic thread (Joe Manor)
BAUDIS Banananana (Mike Y)
COMPOSITE ACCELERATOR (Target)
CSD AIRCOBRA (TFLG)
DEMON - 60" Sloper (TFLG)
Dutchy's SHARK (Jeff Charlot)
F8F2 Bearcat build log using novel techniques (Steve Wenban)
HYPNOSIS Build thread (Winchdoc)
JART Build thread (Samotage) covering many useful techniques
Jart not the Jart
JART-V-XL (sensiblenick) Long, rambling, and not yet concluded
LEG 36" P51D MUSTANG (Legliderman)
LIMIT EX Composite (Samotage)
Me-262 (Jeff Charlot)
SUPER F composite build (Samotage)
TUCANO build (TwinBoom)
U2 (TFLG)
XC-10 Revision 2
My ALES eSupra Build (Red Merle ALES)
Plane Specific - Build logs - The must-read Epics
Carbon Testing (Joe Manor)
Carbon Testing Part 2! - 160" Span Hollow Molded Monster (Joe Manor)
JART - The original (Reed)
SSDC O'Dustn - Considered to be one of the greatest ever entries. (Dustn)
SSDC Retox - Hollow Moulded Carbon Plank - including aluminium moulds
Plane Specific - Build logs - Kits
JART-LT (Slopetrash)
LEG 60" KingCobra (Jeff Charlot) [SIZE="2""][b"][color="RED""] *LINK CORRECTED 01/12/2015* [/color"][/b"][/SIZE"]
SHRIKE Skyking RC Products build thread (Brian Courtice)
Smooth Genie Pro-wood version
Wood Rotor build thread
Rotor..Mold, Build and fly thread
Plane Specific - Build logs - EPP
58½" Gazelle by Blaxe
ALULA build log #001 (Hydrogin)
LEG "One Design Racer" (Jeff Charlot)
LEG "One design Racer" (Kirkgh)
LEG 60" Spit build (Jeff Charlot)
MAX PLANK - Ed Berg (ajroahkni)
NCFM MOTH (Pegasus)
PMP Phoenix Model Products Aermacchi MB339 (Synergy1)
RITEWING - A huge collection of threads (Atom1025 and many others
Circle Abuse
"sloop" flying at cross mt. (thats funny) (0 min 27 sec)
Build Logs
A big collection of Plane-Specific Build Logs.
Moulding Fibreglass Youtube series.
Russ Thompson - Lead Sled Alley - April 2003
Russ Thompson - Lead Sled Alley - December 2002
Russ Thompson - Lead Sled Alley - February 2003
Russ Thompson - Lead Sled Alley - November 2003
Russ Thompson - Lead Sled Alley - Spitfire Sloper
Scimitar II - 70" Composite Pitcheron
WET SEAMS on moulded fuselages
Zip 33 Build Log
Zip 55 Build Log
Control Surfaces & Linkages
Linkages - How To - Many techniques
Silicone Hinges - how to
Soldering - How to solder Piano wire
Torque Rods - discussion and examples
Finishing
Covering Techniques: Video showing Use of Monokote to make patterns
Decals Thread
Painting - a nice sequence
Fuselage / Fus
Ballast Tube 101
Fuse Molding with an Inflation Bladder
JART-V-XL Lost Foam Fuse Prt1 (posts #59-#184)
LOST FOAM technique for making fuselages
Repairing a Fuselage using Carbon Sock by Mike Furcolow
General
A 100% pictorial DLG build (Yclui) that touches on nearly every construction method.
Carbon Testing Part 2! Hollow Molded Monster!
CLEAR CANOPY made while using home-built Vacuum setup
CNC modelling
Highly comprehensive Mouldie repair thread by Wr Mizzard
Hinging
Built up wing Hinging
Hinging II
Make your own Tail Booms
Make Your own Booms by Dave Hill
TWF
Maximus TWF
Wings
"New Stuff" portal
A pictorial composite wing repair tutorial
Building and Using an Automatic Foam Core Cutter - Curtis Suiter -RCSD
Durable Wing leading Edges
Making a Carbon Wing-Joiner
[URL="http://www.rcgroups.com/forums/showthread.php?t=1474377"]Molded wing repair thread - Repairing a smashed spar & broken joiner boxes/URL]
Mouldy wing repair
Socking a Fuselage
WING construction for VACUUM bagging
Wing-Joiner - "Sparless" (Slopeflyer.com)
F3 -RES
F3-RES-Resources *Added 03/11/2017*
Fraundorfers-MAD-RES-Build *Added 03/11/2017*
Build-Thread-AndREaS-2-Meter-from-Germany *Added 03/11/2017*
Tarantula-Hawk-2M-RES *Added 03/11/2017*
Build-Thread-RESoholic-2-meter-RES-from-Germany *Added 03/11/2017*
May 22, 2014, 10:32 PM
plane_tech's Avatar
Construction / Building
General
CNC modelling
HOW TO FIX WARPS, DENTS, TWISTS OR UNCRUNCH FOAM PARTS
Everything You Wanted To Know About Electric Powered Flight (WattFlyer.com
The Dive Test (TailwindGliders.com)
Fuselage / Fus / Fuse
Ballast Tube 101
Fuselage repair using carbon sock
Part 2 (Posts #259-#280)
Re-enforcing a Sleedo fuselage with the sock/shrinkwrap technique
Wings
"New Stuff" portal
A pictorial composite wing repair tutorial -All the pics in this thread are no longer being hosted. If someone has an updated link please advise.
Socking a Fuselage
Wing-Joiner - "Sparless" (Slopeflyer.com) - - Error 404
Cutting highly tapered wing cores using a Pivot Cut method
Weblet Testing
Leading Edges on cores - An easier way
Homemade Disser cloth - How to Video
Disser Rack (Thread source for above video
How to Make a Set of Ribs for a Constant Chord Wing
How to Make a Set of Ribs for a Tapered Wing
Making a DLG wing from foam (In Dutch, but Google Translate does a good job *Added 06/16/2016*
Design a top drive linkage that comes close to maximum mechanical advantage (i.e. uses all servo throw and minimizes servo arm length)
Finishing
Decals Thread
The Compatibility Thread - Resins, Releases, and Paints
Modern-EPP-covering-technique *Added 03/11/2017*
Moulding
CANOPY MOULD - How to
Building full-molded F5B-ships (Raketenwurm and Eisvogel)
Have Mold Now What?
Build Logs
Vacuum Bagging Technique
How to Vacuum Bag Fiberglass & Composites 1 of 5 - Fiber Glast *Added 03/19/2017*
How to Vacuum Bag Fiberglass & Composites 2 of 5 - Fiber Glast *Added 03/19/2017*
How to Vacuum Bag Fiberglass & Composites 3 of 5 - Fiber Glast *Added 03/19/2017*
How to Vacuum Bag Fiberglass & Composites 4 of 5 - Fiber Glast *Added 03/19/2017*
How to Vacuum Bag Fiberglass & Composites 5 of 5 - Fiber Glast - *Added 03/19/2017*
****ACP video for vacuum bagging was removed.
Last edited by plane_tech; Mar 19, 2017 at 02:52 AM. Reason: Added New Link / Massive format chages---thanks RCG
May 22, 2014, 10:37 PM
plane_tech's Avatar
Materials
Supply / Info
UK - Thread dedicated to UK model supplies
GOOP and Gorilla glue tests and info
Composite suppliers - Dedicated post can be found here
Composite suppliers - Australia
Nuplex
Off the Edge Sailplanes
Composite suppliers - Germany
Bacuplast
EMC-Vega Some special things there you rarely find anywhere else, like thin endgrain balsa as sandwich material.
R-G / Faservbundwerkstoffe Very good documentation and info ('how to', tipps, etc.) and a very complete assortment of literally everything you might need to work with composites.
Schloesser & Cramer Manufacturer of carbonfibre cloth.
Siltex Manufacturer of glasfibre and carbonfiber socks.
Composite suppliers - Sweden
BeHåPe Plast & Glasfiberprodukter AB
Composite suppliers - UK
Free Flight Supplies
Composite suppliers - USA
ACP Composites
TAP Plastics
Solar Composites
Fiberglass Supply
Fiberglast
CST
Reinforcing fibres and composites - Tutorial
May 22, 2014, 10:39 PM
plane_tech's Avatar
Tools
Home Made
http://gm.cnc.free.fr/en/index.html ] CNC Foam cutting info [/URL]
https://www.rcgroups.com/forums/showthread.php?t=929531 ] Forming using home-built Vacuum setup [/URL]
https://www.rcgroups.com/forums/showthread.php?t=879863 ] HINGE Slotting Jig [/URL]
https://www.rcgroups.com/forums/showthread.php?t=191128 ] HOTWIRE: the very simple "Swingwire" Technique [/URL]
http://www.instructables.com/id/Convert-an-ATX-Power-Supply-Into-a-Regular-DC-Powe ] POWER SUPPLY made form Computer power supply [/URL]
http://www.gliderireland.net/vaccumforming.htm ] VACUUM FORMING - Build your own machine [/URL]
http://www.rcsoaringdigest.com/pdfs/RCSD-2008/RCSD-2008-11.pdf ] Building and Using an Automatic Foam Core Cutter - Curtis Suiter -RCSD [/URL]
Simple but mighty DIY 4 axis CNC Foam Cutter - Theremino Controller (Not Arduino) ** Added 21 Aug 2017
Workshop Setup
www.google.com ] place holder- do not use [/URL]
plane_tech's Avatar
Disciplines
Aerobatics
Ian Cole's Slope Aerobatics page
Surfimps Slope-specific Aerobatics page
F3f
Training -Plan your F3f Improvement
Slope Soaring… without mountains…
Slope Soaring Without Mountains
F3B-RES
May 22, 2014, 10:52 PM
plane_tech's Avatar
Setup Advice
General Layouts
PLANK Balancing
PW51 plank balancing
TWF (Twisty Wing Fetish) information thread
Things To Check On An Rtf
Things to Check on an ARF
Specific Models
SLOPE DESIGNS RAPTOR 48/36 build and tweak advice
WEASEL tuning
May 22, 2014, 10:53 PM
plane_tech's Avatar
Blogs, mags and Online References
Planet-Soaring.com
RC Soaring Digest
RC-Soar.com
Plane databases
RC-soaring in Denmark
F3 Zone
May 25, 2014, 02:55 AM
Sub
May 26, 2014, 04:11 AM
Tearing the Skies a new one...
Sensiblenick's Avatar
Beautiful Job!!
May 26, 2014, 07:11 AM
plane_tech's Avatar
Thanks Nick!
May 26, 2014, 09:34 AM
Dean
A10FLYR's Avatar
Wow! Fantastic job! Thank you...
