This thread is privately moderated by fpvmodels, who may elect to delete unwanted replies.
May 22, 2014, 05:07 AM
4.5M Mugin with Redundant Elevator and Rudder.
The Mugin 4.5M is a heavy lift gas powered UAV. This aircraft is capable of carrying a wide variety of payload configurations and offers extended flight times. The Mugin 4.5 is an exceptionally large aircraft designed for professional use and can be equipped with a full system of advanced control electronics to run in sync with the most advanced ground stations. With a 27L fuel tank and the additional load carrying capability of 15KG. This plane can get most anywhere, and preform most any job related task you may requires.
Wingspan:4450mm
Length:3670mm
fuselage maximum width:375mm
wing area:225.6 dm2
empty weight:15 kg
Maximum speed :170km/hr
stalling speed:55km/hr
Payload (except tank plane still can load):15kg
Forward Cabin Dimensions:920mmx340mmx350mm
Volume of fuel tank:27 L
Recommended Equipment(Not Included):
engine:120*170 CC
prop:32 x10 high power wooden propeller
servos:12 X savox1256 servo(12pcs servos are used for controling different parts).
May 22, 2014, 05:55 AM
schumixmd's Avatar
This should be used for naughty kids. Have them fit inside and do some loops/rolls
May 28, 2014, 10:35 AM
www.gunnphotoservices.com
Matt Gunn's Avatar
Any flight videos, data, etc?
I'm wondering how structurally sound the airframe is (not insinuating anything, just curious on performance with a payload in possibly turbulent air conditions).
Latest blog entry: www.gunnphotoservices.com
