May 21, 2014, 10:42 PM
rajazo's Avatar
here are a new plane to share... A easy to build Pilatus PC6 Turbo Porter.
The idea start trying to make a own modified version of the Blue Baby with a porter body (like DKChris make) ....
but I like a smaller plane and no plans appear on any place.... well I make a Porter with a blue baby under chamber wing and I hate it.... (calm wind is no option on my "airfield")
then the proyect born and the result is here:
WS 90cm (Lower aspect ratio than real and big chord )
Long 75cm (enlarge to keep the trailing edge in the same place)
Weight without battery 350grs
AUW 500grs
motor RCtimer 2208 1800kv
ESC 20A (15A at full throttle)
prop APC 7x4
after destroy the first fuselage on the first maiden flight with the new wing (experimental airline tecnic) I make some modifications and flew a sucessfull maiden flight today..
climb excellent, good low speed, loops and rolls without work, enter to flat spin easily if you want and recover gently, good ruudder authority... I'm really happy with it.
the construction is easy: a simple fuselage box, some card board pieces on nose and the simple wing folded with a internal carbon spar.... the landing gear made with piano wire, tail wheel linked with rudder...
no video at the moment, but some pictures to start. Plans will be posted if there are some interest.
see you soon!!!
May 21, 2014, 10:43 PM
rajazo's Avatar
deatil 1
plans here
-depron or similar material 5mm thick
-some balsa pieces (5 or 6mm)
-a little 1,5 or 2mm light plywood...
two option of wing, a simple KF2 or a cambered wing like maded with experimental airline technic ( Ed O'Beirne)
JPG are the preview, PDF are letter size and need to be printed 100%
that's all
May 21, 2014, 10:44 PM
rajazo's Avatar
reserved 4
rajazo's Avatar
reserved 5
May 22, 2014, 12:01 AM
serial scratchbuilder
Granted's Avatar
Interested! Plans please
May 23, 2014, 03:02 AM
rajazo's Avatar
plans posted.... soon I'll be post landing gear schematic and build photos
Jul 17, 2014, 07:40 PM
rajazo's Avatar
Video is here... parachute at sunset
mini PILATUS PC6 TURBOPORTER (3 min 43 sec)
Oct 26, 2014, 08:57 PM
rajazo's Avatar
the mini pilatus is really pleasent to flight and good for some aerobatics and my 1800kv motor has enought power to climb vertical... maybe a bigger version will keep all the goods and gain more wind resistence.... next week I'll start the build of 110cm Pilatu,s the plans are ready just need some time
Oct 30, 2014, 11:48 AM
Go FASST or go home...
Ben_E's Avatar
Nice one :-)
Ben_E
Oct 30, 2014, 02:56 PM
addictedtoplanes's Avatar
Yesss!!!! Finally somebody makes porter plans!!
Oct 30, 2014, 04:17 PM
rajazo's Avatar
Thanks. ..
Wait to see the new version... it should be look better and solve some maintenance issues.... more news in the coming days
Oct 30, 2014, 04:41 PM
Ben_E's Avatar
Pilatus Aircraft corp has published drawings for making models on their website...
http://www.pilatus-aircraft.com/00-d...del%20Plan.pdf
Ben_E
Oct 30, 2014, 04:59 PM
rajazo's Avatar
Yeah...I founded and downloaded... they are perfect for perfect scaled planes using rib and planking. .. but my short time makes me prefer simplified boxy planes, and share the plans to guys with the same trouble than me or beginners
