HobbyKing BFG 2600 - RC Groups
HobbyKing BFG 2600
Available in two BF sizes!
Hobbyking has introduced a new pair of gliders dubbed the BFG (We'll let you figure out the acronym). It's available in 1600mm (62") and 2600mm (102") sizes, but we will be taking a look at the larger 2600. Constructed with tough EPO foam, the BFG 2600 is a full-house glider with flaps and ailerons. It features a mono-wheel under the cockpit for reducing belly rash when landing and comes with a 3720 700kv motor and 60a esc. Six 9g servos are also included.
Features:
  • Plug and Fly - Just add your choice of TX/RX and battery, minimal assembly and fly!
  • Ultra tough molded EPO foam airframe
  • Powerful 3720 Outrunner motor and 13.5x7 folding propeller
  • Large, effective flaps slow down the BFG 2600
  • Large fuselage access hatch for checking electronics or swapping batteries
  • Mono-wheel landing gear
Specs:
  • Wingspan: 2600mm
  • Length: 1500mm
  • Flying Weight: 1900g
  • Wing Area: 55dm2
  • Motor: 3720 700kv
  • ESC: 60A w/BEC
  • Servo: 9g x 6
Requires:
  • 6+ channel Transmitter and Receiver
  • 4S 14.8V 2500mAh Lipoly Battery
Link to product webpage
May 15, 2014, 06:19 AM
I hate propellors
emufingers's Avatar
Are flaps and ailerons set up with individual wires, or Y leads?
May 15, 2014, 07:38 AM
RCGroups Editor
Matt Gunn's Avatar
That's a good question. Hopefully someone who has the model will chime in.
May 15, 2014, 10:34 PM
Removable T-tail?
Looks pretty good. Anyone know if the T-tail is removable?
I have a RocHobby V-tail that is very similar but the V-tail is not easily removed and is therefore a pain in the butt to transport and store.
May 16, 2014, 08:01 PM
The information on the website describes it as a 'bolt on horizontal tail', so I'm assuming yes.
May 17, 2014, 02:48 AM
leinad's Avatar
Rebranded Diamond 2500
Is this a rebranded Diamond 2500 from art tech?
https://www.rcgroups.com/forums/show....php?t=1134216
May 17, 2014, 02:51 AM
leinad's Avatar
If it is, this is a great plane. Had one of the art tech. Plenty of fun. Stable and docile with good glide ratio. But you must use full house glider techniques to get max benefit from the 6 servos.
May 17, 2014, 02:53 AM
leinad's Avatar
It is removable. 2x M5 screws. Probably nylon bolts.
May 18, 2014, 04:35 AM
So what does the BFG stand for?
May 18, 2014, 07:52 AM
Big F----- Glider??
Tim
May 18, 2014, 08:01 AM
I hate propellors
emufingers's Avatar
The BFG (short for "Big Friendly Giant") is a children's book written by Roald Dahl and illustrated by Quentin Blake, first published in 1982.
May 18, 2014, 11:20 AM
the journey is the reward
Hammer Head's Avatar
Wondering when the International warehouse will have the BFG 2600 in?
May 18, 2014, 08:20 PM
It looks like it is the same airframe. Great flying glider. I flew it with anything from 2200MA to 4000 MA lipos and CG stayed the same. High flying glider and great having the install landing wheel for rough fields. I think this has the plastic pins in the fuselage that go in the top to hold the wings on. Easy to assemble and take apart for transporting. I used aeronaut props and removed the stock ones after seeing a few post that the stock props broke.
The only problems I had were with the servo leads in the flaps and ailerons. No labels and if you lost a servo for the flaps it was a hassle locating the right wire.
May 19, 2014, 12:59 AM
Originally Posted by w4yn
Big F----- Glider??
Tim
I thought so too
May 19, 2014, 10:54 PM
diamond 2500
I have the older 2500, and I am able to fit it in my ford SUV Expedition in one piece. I did change the servos to Turnigy 555 and a E flight power 25 motor with a 16x10 prop using two 2200 lipos. needed to balance it. I fly it for hours and only use one volt. Great plane!
Discussion New Glider from HobbyKing - BFG 1600 and 2600 MEGAjig Electric Sailplanes 519 Dec 26, 2017 12:31 PM
Found Multiplex Glider, Flyzone Calypso, Dynam Sonic 185, BFG 1600 or BFG 2600 Sirchess Aircraft - Electric - Airplanes (FS/W) 3 Jul 23, 2016 10:51 PM
