Latest blog entry: Samson RC Tugboat
I tried cleaning them with alcohol. and did a close inspection of the IXJT board. Then i removed the back of my radio so the module goes further over the pins, still no luck. Some times the module version is displayed. When bound the protocol randomly changes. i have the feeling it has to do with the naming of the protocols as before it was DSM X 11ms, and now it is DSM X F2. I believe the FrSky D16 protocol was renamed too as it it giving me issues as well I don't know if the OTX version is responsible for the name change or the MPM firmware. Could you please look in to this? As you can see the radio on the right works flawless with the module mounted. |
Just looking at the pin doesn't mean it's working. There has been multiple reports so far that the solder joint of that specific pin is faulty on these modules. So use a soldering iron and redo the connection making sure to include some part of the track in case it is broken. Use a multi meter and trace the track to test the continuity... Pascal |
The second is the four temp sensors available from the WK-CTL01-D telemetry module that I have installed on my Walkera MX-400S and QR X400 quad copters. And you have explained it that only two are supported, so I can of course only see two. That's ok for now. The Walkera F12E radio and the Jumper T8SG with Deviation can detect all four so the data are sent. Is it possible to support 4 temp sensors in the Devo protocol implementation? The GPS works also, except the year in the date display is showing 1955, odd. Other than that the altitude, ground speed and coordinates are reported correctly (offset adjustment needed for ground speed). I have several QRX350pro drones and several Scout X4s and I will test the telemetry on these soon and will report the outcome. I don't expect any problems there though. Thanks for your development work and support. Much appreciated. Klaus |
Pascal |
Thats why i believe that there is nothing wrong with the module it self. I'm not going to reflow the solder on a 1 week old radio. i'd rather sent it back, still waiting on response from the seller. |
my MPM and my AR6335 - picture of a throttle lossQuote:
Below is a picture with the scope on the Rx pins, RED is the throttle, BLUE is ailerons. I do not believe it is a FAILSAFE , as everything is set to HOLD in my FAILSAFE and last, I confirmed this to operate as intended , by switching OFF the Tx on the ground : the motor keeps running. The Throttle loss is like a gap in the refresh rate ; whereas I thought it would be a swing to -100% . I see the ailerons CH2 seems affected too however unlike the ESC, you cannot hear this on the servos. I hope the picture , showing the signature and the duration, would help finding where the issue comes from... Note this is FW v1.3.2.72 this time. I will post more pictures of 'normal' operation. |
my MPM and my AR6335 - picture of 'normal' operation
this is looking at the Rx pins when apparently everything 'sounds' allright
I was surprised to see various changes in the refresh : mostly 22ms and sometimes 27ms or 5/6 ms ... is this normal ? |
Have you checked if this RX has a firmware upgrade available? Just by curiosity, what's your Multi setup? a picture of the model protocol config? Pascal |
Very possible as it would also explain why no other DSMX users are reporting the same problems as mine...
I had not checked. So today I registered my serial # and looked it up. Even though I purchased the Rx in 2020, it looks like I am lacking a 2015 upgrade. But from the history they show, I think the 2015 upgrade would not be be solving this kind of bug. So I do not think it is worth purchasing the expensive cable which is required for any of these upgrades... Quote:
So, I do the bind in AUTO, result is shown, then, as my AS3X mode + master gain is assigned to CH8 (in the Spektrum android app for the Rx), I then have to manually increase the channel number (in the protocol menu for the MPM ) from 7 to ... 12. I might be wrong here though. I always assumed that going towards 10/11/12 would make no difference and would not disturb the Rx ? The thing is, the Spektrum manuals do not say how many channels exist beyond the 6 physical ports; but the CH8 (which I learned from rcgroups) works fine for the mode/master gain, and I was able to see recently that the Spektrum app allows up to AUX6 (=CH11 if I understand ?). So in reality my best guess would be 11 channels... |
Now i'm really confused. Old Radio: MPM works New radio : MPM issues. New radio : Crossfire works. Tried Opentx Firmware: 2.3.9 / 2.3.10 / 2.3.11 Tried different MPM Firmware versions So what to blame now? |
Pascal |
Again, it's either the connector pin 5 solder joint and connected trace or the telemetry signal is too weak for the radio. Pascal |
