Aug 20, 2015, 07:32 PM
midelic's Avatar
No it is not,............ turn it 180deg.
Very good board steve(sccamp) designed.I'm still impressed with that.
Aug 20, 2015, 07:45 PM
Flying Wood For Fun
irun4fundotca's Avatar
so like this?
Aug 20, 2015, 08:00 PM
midelic's Avatar
It is ok like that.
You can see on the back where is the gnd...so you'll be sure.
Aug 20, 2015, 08:03 PM
Flying Wood For Fun
ok yup thats right then
Aug 21, 2015, 12:03 AM
Flying Wood For Fun
Should any 328p work for xloader
I keep getting upload failed (without anything happening)
ohh is 57600 baud rate the problem perhaps?
switched to avr8 burn o mat
still having issues with settings i think
Aug 21, 2015, 05:39 AM
First joined Sep 2001
115200
I assume you burnt bootloader. Only thing i can think of.
Bm
Aug 21, 2015, 07:47 AM
midelic's Avatar
No not any.I think you chose the wrong settings.
You should choose the one with lower baudrate.
On your setup you need programmer and avr dude gui like avr8.
XLoader working with FTDI if have bootloader on serial pins.
Those above are programming pins not normal serial pins.
Aug 21, 2015, 09:05 AM
Flying Wood For Fun
Not sure i understand correctly, you mean the module bay tx/rx pins, instead of isp header?
i was using this method, assuming it was loaded with a bootloader, sccamp loaded the latest when he shipped it ... (bootloader maybe not?)
not sure where to set baud rate for avr8
Aug 21, 2015, 09:18 AM
midelic's Avatar
The RX TX uploading is not for your board .........is for arduino(promini or nano from market). The right programming (for your board)is with avr programmer like USBASP and and avrdude gui like avr8.No need bootloader on steve boards.They are programmed directly (ISP header)..NO BOOTLOADER.
No need set baud rate for avr. programming.How you flashed hex code before ?What is changed?
I think how you connect the 10pins connector over 6 pins not good,You need an adapter 10 pin to 6 pin ISP ....or identify pins and using wires.
I had the impression you know hot to program these boards.
see below
http://www.ebay.com/sch/i.html?_odkw...n+ISP&_sacat=0
Aug 21, 2015, 09:27 AM
midelic's Avatar
My connection.
Enjoy!
Aug 21, 2015, 09:36 AM
Flying Wood For Fun
haha i took the picture bad the 6pin adapter is hidden from sight
this is the first time yet trying an update, since Steve flashed it
yes im using a usbasp, that has worked before & also flashing things using the hk flash tool with pogo pins
Aug 21, 2015, 10:02 AM
midelic's Avatar
So it is working or not?
Try read fuses.
Aug 21, 2015, 10:10 AM
Flying Wood For Fun
no it just says as my screenshot shows above
the fuses wont read
Aug 21, 2015, 10:11 AM
midelic's Avatar
Try put the dial switch on zero and try again.
Aug 21, 2015, 10:14 AM
Flying Wood For Fun
ok
edit ....fuses read!!! that worked
i had my dial cover on the opposite side so really it was at 6 oclock instead of 12
no its the switch itself i think theres only one direction the cover can go
guessing 0 is supposed to be at 6 o'clock?
