This thread is privately moderated by Drinkes, who may elect to delete unwanted replies.
May 02, 2014, 02:29 PM
Build Log
DIY FPV flyingwing
My new DIY project.
The goal is not too big model. Very stable, no bad habits as Dutch step. With good aerodynamic efficiency.
Description: Name: P1070850.JPG
Description:
Airfoil MH45 10% - root, mh_pw 9% - wingtip. Tip twist 3 grad.
35-36 1400kv motor 9X6 prop 45 amp esc 5000mah 3s battery.
Fuse. Positive molded fiberglass.
Description:
Description:
Description:
Description:
Wings. Balsa on foam core. Root MH45 to something near symmetrical 10% profile.
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Самодельный беспилотный носитель, модель для FPV. Чертежи технология и процесс постройки.
May 03, 2014, 06:25 AM
Artful Owl's Avatar
Wicked! your plane is very cool. How do you get such a nice finish on the fuse and what is it covered with? can you enplane how you made the fuse.
May 03, 2014, 05:58 PM
Fuse not finished yet. Positive molded on foam blank of fuse. I can write more clearly when finish it.
May 04, 2014, 01:36 AM
Artful Owl's Avatar
Ok thanks
Dec 17, 2014, 11:32 AM
Everything's A Composite
Knoll53's Avatar
Cool design and nice model building.
So this one looks like it is designed for speed.
Is the root chord really 375mm? It looks smaller than that compared to the keyboard.
Kent
Dec 17, 2014, 02:49 PM
really it is 320mm at the wing, and 370 at center of the fuselage.
Not too fast building 2 more projects in one time.
Dec 17, 2014, 03:13 PM
For visual flying, with new fuse, it will be look like this.
Description:
Description:
Mar 22, 2015, 08:50 AM
Almost Ready to Fly.
Description:
Description:
Description:
Mar 22, 2015, 09:27 AM
Knoll53's Avatar
The wing finish is really beautiful. I've never seen balsa look so good.
Mar 22, 2015, 12:26 PM
Thank you. It's white semitransparency adhesive film.
Apr 13, 2015, 10:07 AM
Ready to flight.
Description:
Description:
Description:
Description:
Description:
May 25, 2015, 12:58 AM
FPV DIYwing 2000 mm (4 min 46 sec)
Jun 01, 2015, 10:18 AM
Knoll53's Avatar
Flys nicely ! .........and looks good in the air.
I would like to know more about your technique for the positive molded fiberglass fuse. Your results are very good.
After shaping of the foam, I see that you have applied some sort of finish, possibly thin layers of tape. Can you describe this process a little bit more? Thanks.
Jun 02, 2015, 01:52 PM
If sense not Lost in Translation This packing tape layer is for simple excavation of foam (after I and fiberglassing the fuse).
Jun 02, 2015, 03:26 PM
Knoll53's Avatar
Wow, that's packing tape? it is very smooth! Is that a paper based packing tape?
