This thread is privately moderated by mnemennth, who may elect to delete unwanted replies.
Apr 23, 2014, 08:47 PM
AMA 1033652
mnemennth's Avatar
Build Log
APM2.5.2 & 2.6 MIC5219-3.3YM5 (LG33) Regulator Mod & Alternate Capacitor Mod
Supplies Needed:
MIC5219-3.3YM5 SOT23-5 Package 3.3V Fixed Voltage Regulator
0402 or 0603 size SMD 470Ω Resistor ( Marked [471] )
(1) 1206 size 100uf 6.3V Ceramic Capacitor or (2) 1206 size 47uf 6.3V Ceramic Capacitors; more if you want to fully "Harden" the APM board at all plug-in headers.
Good, temperature-controlled soldering iron with 0.5mm Conical Tip
Chem-Wick or similar professional-quality desoldering braid in "Fine" size/guage; I recommend against Radio Shack for this due to poor quality
0.015" super-thin solder; I prefer 62/32/2 Silver-Bearing Alloy (Radio Shack # 64-035 is a good substitute)
Teeny-Tiny Needle-Point Tweezers
"Dilbert-Level" Mad Micro-Soldering Skillzz
Optical Magnification and Lighting Devices:
THE Mod:
Some time after blogging my LM1117-3.3 Regulator Mod, I found myself reading reading Joe Abrams' infamous Post # 1491 ; in it he describes his recommended diode protection Mod and makes mention of substituting another regulator, the MIC5219-3.3YM5 ( I will hereafter refer to it as the LG33, its common name after the case marking found on the SOT23-5 package variant).
It was one of several I had considered at the time I started on my Mod; it is a descendant of the LM1117, only in a smaller SMD package. I did in fact spend some time searching for one either in my parts bin or that could be salvaged from scrap electronics; in the end, I went with the LM1117-3.3 mostly because it was handy, and larger, so easier to handle.
So now I found myself wondering... "Indeed... why NOT the LG33, Mr. Abrams?" It comes in the same SOT23-5 package, and is a pin-for-pin substitute, only with much broader operating voltages and is again known to be nearly bulletproof in this sort of application.
The only problem is the need to drive the ENable pin HI rather than LO; and its EN pin is rated for direct connection to V-IN, so simple enough to modify to fit. I decided then to order some; a couple weeks later they arrived via the slow boat from China, and I was ready with another faulty APM board.
First off, we prep the board by removing the old 3.3V regulator. Philip of DIY Drones has an EXCELLENT video tutorial HERE for replacing the stock TPS79133 regulator; we'll be doing precisely this process, only we'll Mod the LG33 regulator so we can add a tiny SMD 470Ω resistor across the V-IN and ENable pins, so only 4 of the 5 legs of the regulator will be soldered to the board.
The reason for using this resistor is twofold: First, it has an insulated ceramic body, so can be safely used as a jumper passing over the GND pin between the V-IN and ENable pins. Secondly, it will limit maximum current flow through the ENable circuit to approx 10ma; this means that in the worst case scenario, if the enable pin is shorted to ground by some foreign object or crash accident, the worst that will happen is it turns off the regulator. We are in effect making a buffered connection known as a "Pull-up Resistor" circuit.
If this sounds like I'm speaking to you in Martian, I suggest that you may wish to consider having a geekoid friend do this work. You DEFINITELY need to be in touch with your Dilbert side to be able to do this Mod; it involves VERY tiny soldering which one has to get right the first time.
Here you can see my APM2.5.2 board all prepped for the new regulator (Circled in RED); the APM 2.6 board will be the same.
While I have this excellent pic up, I'd like to point out another potential failure which can mimic the shorted 3.3V regulator fault. This board arrived with the 3.3V regulator already replaced, but still had 5V on the 3.3V rail. After removing the 3.3V regulator, I tested again to be sure nothing else appeared wrong; I found it STILL had 5V present on the 3.3V Rail!
Close inspection of the board revealed a solder bridge across the 3.3V-IN and A1 pins of the TXB0104 Level Converter for the FLASH RAM; it is VERY likely this fault existed from the factory as a wave soldering defect, and only exhibited issues after the faster clock rate of recent firmwares caused issues.
There are TWO of these Level Converters on the board; either can possibly cause this failure, and those pins are TINY and very close together. Inspect VERY closely if hunting a similarly persistent 5V fault on these boards.
Here we have the LG33 regulator; we are going to Mod it by flattening the ENable pin between the tips of a pair of tweezers so that is protrudes horizontally from the case. Really, that is all the force needed; just a squeeze from a pair of tweezers.
When we're done, it will look like this. Now, we're going to install it on the board as shown in Philip's video; the only thing we're going to do differently is NOT solder down the ENable pin which we just flattened. Here it is again so you can review it:
APM 3.3v regulator, basic fix (3 min 18 sec)
Next, we're going to install the 470Ω resistor across the V-IN and ENable pins:
The one I used is 0402 size (1mm L x 0.50mm W); 0603 size (1.6mm L x 0.80mm W) is also small enough to fit here.
Tack down one side to the ENable pin, then solder the other end to the V-IN pin like this, so that the dark side with [471] printed on it faces up. It is okay for the white side of the resistor to lay across the GND pin underneath; it is the ceramic substrate of the resistor, and has a higher insulative value than pretty much anything else on the board. Just make sure there are no solder bridges to the center GND pin from either adjacent pin as seen here.
Now I'm going to clean the flux from the repair area by scrubbing with a stiff paintbrush dipped in alcohol; be sure to protect the barometer from contamination by covering the holes in the metal can with a finger as shown here. Removing the flux is optional; unless the flux residue is contaminated by another liquid later, it will cause no harm to the APM board. I find it is easier to inspect the quality of my work with it removed, however. If you already have a foam square over the baro, you may prefer to skip this step.
And here's the finished product, ready for testing. First, we test with a meter across all legs of the regulator for obvious shorts, then plug it into USB on the computer and wait for it to complete its Power On Self Test. I then check the 3.3V rail at the I2C bus, and if all appears okay, I disconnect, add GPS, and verify that all sensors test OK in Mission Planner's Terminal applet.
If everything tests good, I move onto the Flight Data/HUD screen and do a manual ""Reality Check" to see that it reacts as expected when I change the orientation of the board and that it doesn't have any massive jitters.
Bench Testing:
My bench testing for this Mod was similar to my testing with the LM1117-3.3; first, I connected it to my PC via USB ONLY as Philip did in his article on the DIYDrones thread on this failure.
A DVM is connected via plug-in patch cables to the 3.3V rail at the I2C port and another to the 5V rail at the INPUTS header; both are monitored throughout testing.
I have streamlined my hot-plug testing a bit; of all the RX and other surge load devices I tested before, I only used the worst offender, my ORX RX3S 3 Axis Gyro/DSM2 RX, as a test load with this setup. It offers a fairly stiff combination of resistive current draw and large, Low-ESR ceramic capacitor of approx 150uF total value in the primary power input section, and was by far the most aggressively disruptive device I tested with my LM1117-3.3 regulator Mod.
My testing was simple, yet strenuous (at least for my patience); 20 cycles of hot-plug, monitor effects, reset and test again.
Without any other mods to the board, I would hot-plug my RX into the INPUT 1 port of the Input header; although I never heard the distinctive "Bing-Bong" noise from the PC indicating that a USB device had been unplugged, MP would disconnect each time, and I would be unable to reconnect until I unplugged USB and plugged it back in again.
After 20 cycles, I experienced the same exact results each time; and monitoring with MIN/MAX on both meters indicated 3.3V fluctuated from 3.21 Min to 3.330V Max, with 3.28V typical read on display. 5V fluctuated from 2.22V Min to 5.05V Max, with 4.97V typical read on display. Typical voltage input at USB header is right on at 5.01V; however, a small voltage drop (0.07V) occurs across F1 directly after USB header.
Overall, this suggests that capacitor filtering at the 3.3V rail is sufficient to prevent the 3.3V from fluctuating very much, but just as Philip suggested, the 5V rail fluctuates greatly, with PC power supply for USB port possibly even going into shutdown for a micro-fraction of a second.
Alternate Capacitor Mod:
At this point, I felt it was time to move onto the next part of my Mod; adding Protection/Buffer Capacitors at the 5V input Rail as per Philip's Mod. My variation on this Mod attempts to make a completely user-transparent upgrade to the board.
I wanted the end product to fit inside the ArduPilot case with no modifications required, and I wanted it to NOT disable ANY I/O header on the board; as I have discovered after speaking with many users, there really is no way to predict which headers a user is going to need.
After fighting with commonly available 1210-Size (3.20mm L x 2.50mm W x 2.50mm H) 100uf Ceramic capacitors for space to install; it occurred to me that 1206-size (3.20mm L x 1.6mm W x 1.6mm H) capacitors would be small enough to fit on the bottom of the board and allow clearance to fit inside the case; and as a bonus, they fit very neatly in between the pins of all the main plug-in headers!
This flexibility of mounting allowed me to place the buffer capacitors where I felt they MOST needed to be: right at the point of attack, where the RX was plugged in at the INPUT 1 Header.
As luck would have it, I found that 100uf Ceramic capacitors of this size ARE available, but not exactly cheap; averaging approx $1.50-$2 each in small lots on fleaBay. I DID, however, find a vendor offering 50pcs of 47uf 6.3V 1206 size ceramic capacitors for $10.00 shipped, and a US vendor to boot!
http://www.ebay.com/itm/140968220227
Here we are desoldering in the space between the GND and 5V pins at INPUT 1 and INPUT 2.
We are doing this so that the capacitor will have room to lie flat and flush against the board between the pins.
Here we are placing the first capacitor...
...and here it is soldered in place.
If you are using 2 47uf capacitors as I did, you'll want to do the same thing in the space between Input 2 and Input 3; here it is and the resultant measurements from my ESR meter. SUHWEET!
Testing the Capacitor Mod:
As before, I would repeatedly hot-plug my RX into the INPUT 1 port of the Input header; now I was unable to make MP disconnect, and live data remained constantly available throughout test period.
After 20 cycles, I experienced the same exact results each time; monitoring with MIN/MAX on both meters indicated 3.3V had no measurable fluctuation, remaining rock-steady at 3.28V with Min/Max reading the same.
5V no longer dropped and spiked as before; It simply dropped from 4.98V to 4.88-4.89V; voltage dropped across F1 now measures 0.11V due to increased load from ORX RX3S 3 Axis Gyro/DSM2 RX.
"Fully Hardened" APM Board:
I consider these results to be an unqualified success; but I'm still not done. As I've stated before, it is sound engineering practice to place buffer capacitors at the power rails of any user-accessible plug-in connectors; to this end, I've installed additional 47uf capacitors at the Analog, Output and I2C header connectors to fully harden this board against voltage fluctuations caused by the many depredations of exposed plug-in connectors.
These are of course optional; however, it's not like it costs much to add a little more protection, so why not?
As promised; the entire point of this complicated Mod was to make it so it would fit inside the ArduPilot case; and here is the finished product. Only you will know it's now a TankDuPilot; well, you and of course the Gremlins.
In Closing:
Please remember, as with my APM LM1117-3.3 3.3V Regulator Mod, this is a Mod which is still in Beta.
PLEASE, PLEASE, do not attempt to fly in any Autonomous mode without first testing as extensively as possible on the bench, and then verifying that all manual modes work correctly BEFORE enabling any Autonomous flight modes. I REALLY don't want to copy all the scary warning stuff I put on that Build Log over to this one; but if y'all don't behave, I WILL.
mnem
*HARDENED*
Apr 24, 2014, 08:03 AM
Tri-Quad-Hexa-Octo-copters!!
Hi m,
Excellent APM mods and write up!
Thanks and Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
Apr 25, 2014, 09:38 AM
AMA 1033652
mnemennth's Avatar
Thanks Jim!
In my opinion, this regulator Mod is as close as we're going to be able to get to a "drop-in" upgrade replacement part that resolves the "hot-plug death" issue permanently.
I feel the buffer capacitors at all the plug-in headers should have been there from the start; but there's now almost a decade of successful development on this platform without them, so clearly one CAN live quite happily with the existing design.
I'm hoping the update I included re: the solder bridge fault at the TXB0104 Level Shifters helps others save a few boards as well; the fact of finding it in the wild on a clone board definitely supports the commonly held belief that 3DR's higher pricetag does offer some tangible quality improvement over the discount product.
Cheers, and good propwash, dude!
mnem
That's a strange place to leave a piano...
Apr 26, 2014, 07:50 AM
Quadaholic
--Oz--'s Avatar
Nice work. I thought the APM 2.5.2 and the 2.6 use a different 3.3v regulator package, so this applies to only one of the two versions of APM's, correct?
Apr 26, 2014, 06:29 PM
AMA 1033652
mnemennth's Avatar
No... it applies to both the 2.5.2 and the 2.6; The 2.5 is the one that uses a different package 3.3V regulator. The 2.5.2 was a relatively substantial revision; including different components and more LED indicators.
With the revision to 2.6, in order to do away with a lot of confusion regarding how to add an External Compass, they essentially took the 2.5.2 board and removed the compass, then renamed it the 2.6.
The reason for the external compass is simple; with many craft, ESPECIALLY MultiRotors with LOTS of high-current wiring, large fluctuations in electromagnetic interference can play havoc with the compass built into the board. Placing it with the GPS on a stalk higher above the power distribution areas really helps eliminate this.
Many clone manufacturers are selling "APM 2.6" boards which are really 2.5.2 boards that simply don't have the HMC5883L location populated on the board; they often haven't even bothered to change the silk-screen printing on the board, and they still SAY "Rev 2.5.2".
This has created 2 new points of confusion; first, the new revision is actually LESS board for your money, and folks don't necessarily KNOW they HAVE to use an External compass with ANY APM2.6 board, whereas with the 2.5 & 2.5.2, it was ALWAYS an available option; you just have to cut a trace on the board MADE for this purpose:
And secondly, it appears the pools of these parts are getting mixed up overseas; as we now have vendors (many completely unknowingly until they get feedback from their customers, like our own Witespy/RTFQ) who are selling these mislabeled boards AS APM 2.5.2s, and REALLY ticking off their customers who know the difference.
mnem
*Was/Not Was*
Jul 03, 2014, 10:26 PM
Quadaholic
--Oz--'s Avatar
This is the hot air rework station I got for work, it is going on 3 years w/o any problems, and I took home the Hakko ($600) it replaced and fixed it for home use. I also uses the excelent Hakko 900 soldering iron tips.
http://www.ebay.com/itm/Soldering-Re...item27da5facf4
I solder everything with it, though hole to 0.4mm pitch BGA and CSP (chip scale packages)
Oct 30, 2014, 12:09 PM
Went to mow a meadow
frank48's Avatar
Hi,
I'm wanting to do your capacitor mod and have received my ebay 47uf caps today. With my limited knowledge they look like they are of the tantalum variety (polarity mark at one end)
Will they still work okay?
Cheers!
Frank
Nov 19, 2014, 10:56 AM
frank48's Avatar
Originally Posted by frank48
Hi,
Cheers!
Frank
Bump!
Frank
waiting patiently...
Apr 18, 2015, 01:20 PM
AMA 1033652
mnemennth's Avatar
Frank -
Wow... I suck. Sorry for missing this; I have no idea why RCG doesn't send me eMails anymore when someone posts.
For hardening the inputs, no. SOME tantalum caps are LOW-ESR; but most are not as low as ceramic. That's why the monolithic construction ceramics cost more.
Remember we only need 6.3V caps; that's why the 47uF are so cost-effective here. 100uF are also available pretty cheaply at 6.3V; but the 47uF fit so nicely between the pins and fit inside the case with no mods.
mnem
*Back to the bench*
