Hey Mal
As requested https://www.rcgroups.com/forums/show...8#post35339346 Also yes only battery per AWB. But if you are from USA or Canada our system is build such that IF you order 4 as example, we'll just pack 2 shipments as per IATA rules....so you can order as many as you like for USA & Canada |
You can try to break them in and yes possibly better at 4,2. personally I don;t think breaking is in required but it may help lower the IR a little on packs with the formation of the internal SEI layer. Good to do also IF your packs have been sitting around for a while over winter as example
Can I recommend updating the revoblends.com FAQ information? It's hard to read because it's a bit scattered and not clear what applies to which battery type, for instance some sections mention 4.2V but what about high voltage (435), etc. Or the most general info (How to look after batteries) is in 'Failure Modes' probly by mistake. I think a properly organized single document is much better than 'faq' but that's just my opinion.
435 1500mah 4s no longer listed on this page:
http://www.usastore.revolectrix.com/...teries-for-FPV Has the product been discontinued? |
The B435 1500-4S is sold out. We removed this part from the site for the time being because we don't have a good deadline yet on when we will receive more stock. We also have some of the new Go Packs (FPV sizes) at REVO USA now. Plan to get those up on the site and ready for sale within the next 1-2 weeks. |
There's something that I don't understand about the Graphene capacity. Can someone explain why they are in 50mAh packs, like 1250mAh. Why don't it just go to 1300mAh. And for charging with PL8, do we set it to charge at 1.3A? I see that most packs that are 1200, 1400 are all out of stock but left with those 1250 and 1450s.
I ordered a few gopacks. 4S and 3S.
Right out of the box, the IR readings seem low as advertised. Now, these are HV packs. I need some info to help me out. - When charged to 4.35v capacity is 1550mah, what is capacity @ 4.20v ? - I normally land when my osd shows 3.5v per cell, so when I land it actually jumps back up. Is that safe for HV? |
