Apr 12, 2014, 06:22 AM
New Flysky FS-i6
Hello
I just saw two new radios from Flysky, the FS-i6 and FS-i4 :
http://www.banggood.com/FlySky-FS-i6...-p-922606.html
As well as new matching receiver.
What are the differences compared to the FS-T6 that I just bought ?
-fx
Apr 12, 2014, 11:27 PM
carlnoki's Avatar
if the i6 series is like all the other ones they make, then it is a telemetry
type radio.
not sure if they are backwards compatible with the earlier receivers tho. I know the i10
radios are,.
also not sure what the TX out put power is on that one yet.
some parts of the world require LOWER power out put compared to the USA versions.
Apr 18, 2014, 10:16 AM
carlnoki's Avatar
looked closer at the TX specs and it looks like it is backwards compatible with the
standard receivers. :-)
Aug 23, 2014, 09:10 AM
Hangazoo's Avatar
High Guys,
I saw that topic was opened 4 months ago.
Is there anybody have some experience about this transmitter?
I am looking for my first trans for a ZMR250 quad and it seems a cheap choice within the 6 ch field.
Can be available under $60 with receiver + LCD.
Could be good to see minimally a range test. It seems quite new, so I did not find anything by google.
Aug 28, 2014, 12:31 PM
Bryan, Texas
Have anyone uses the FS-i6. How does it compare to the FS-T6. Is there a review out somewhere on the FS-i6?
Sep 07, 2014, 04:39 PM
SeByDocKy's Avatar
Have a look to the Flying3D X8 multirotor. It's using a nearly identical combo transmitter/receiver
Sep 11, 2014, 01:10 AM
FS-i6 & FS-T6 use different coding
The FS-T6 use the AFHDS coding protocol whereas the FS-T6 the second generation AFHDS 2A coding (two-way communication) giving you telemetry capability on the RX battery status. In addition, FlySky claimed that you will get longer range and better anti-jamming feature.
Oct 03, 2014, 10:11 AM
Anyone get one of these yet?
Oct 17, 2014, 11:05 PM
Bluealien
Bluealien01's Avatar
Fs i6
Have just read what everyone on here knows would like to know if anyone has bought one
Oct 17, 2014, 11:30 PM
RC Warjet
Yes, got one last week NIB on eBay. Haven't used it in a plane yet, but bound it to the receiver, got telemetry for rx voltage and good range check. Also bound to the older receivers, worked fine too.
Oct 17, 2014, 11:41 PM
Bluealien
Fs i6
Here are some specs :MN res
 FlySky FS-i4 2.4G 4CH Remote Control RC Transmitter With iR6B Receiver Description: Brand Name: FlySky Item Name: FS-i4 Transmitter Channels: 4 Model type: fixed wing/glider/heli RF range: 2.4-2.48GHz Bandwidth: 500KHz Band: 160 RF power: less than 20 dBm 2.4G system: AFHDS 2 Code type: GFSK Sensitivity: 1024 Low voltage warning: less than 4.2V DSC port: PS2; output: PPM Charger port: not Weight: 335g ANT length: 26mm*2(dual antenna) Power: 6V 1.5AA *4 (not included) Size: 174 x 89 x 190mm
Color: black Certificate: CE/ FCC Package Included: 1 x FS-i4 transmitter 1 x FS-iR6B receiver 1 x Line of Code 1 x Manual
Oct 22, 2014, 09:59 AM
rickthebrewer's Avatar
It appears Hobby King has a Turnigy branded version of this radio out now.
Oct 22, 2014, 03:48 PM
Has anyone got one of these. What is the WATTAGE output and what is the range please . due to the low battery count i think this may be a low wattage park fly range tx.
Oct 22, 2014, 08:24 PM
RC Warjet
No wattage output given in the manual, but Flysky claims in the manual:
* "uses a high gain and high quality dual antenna system, guaranteeing a jam-free long range radio"
*"the radio uses high efficient low power consumption electronics, using 1 / 10th the power of an FM system"
There are several new radios out there that only use ~4.8V transmitter batteries, so I wouldn't think battery voltage = range.
Oct 22, 2014, 09:54 PM
Destroyer of foamies
Hey Guys,
I'm a recent flysky convert from my old JR XP 8103, and I was wondering if anyone could find out if this radio has expo. I know the little T6 B does not, and if this one does I'd like to get it.
Thanks!
For Sale New Flysky Fs-i6 transmitter and Flysky ia6b receiver rroth Aircraft - General - Radio Equipment (FS/W) 0 Mar 20, 2017 12:40 PM
Discussion Is the Turnigy TGY-i6 the same as FlySky FS-i6 Paul80 Radios 5 Dec 03, 2016 11:30 AM
Help! Flysky FS-i6 or the Flysky FS-T6 graywoulf Beginner Training Area (Aircraft-Electric) 25 May 24, 2016 10:03 PM
Discussion FlySky I6 - FS-I6 Help Rodrigo Sorbo Radios 1 Dec 23, 2015 05:44 PM
