This thread is privately moderated by ElGuano, who may elect to delete unwanted replies.
Apr 16, 2014, 09:49 PM
Now that's a pretty sight! Can't wait to see what you cook up!!
Apr 17, 2014, 07:27 PM
that is extremely impressive, got nothing but respect for you Elguano
Apr 18, 2014, 11:00 PM
Thanks! I've just got a tendency to make a commitment to try something out and jump in with both feet. Luckily, it turned out quite well with this mod
Apr 21, 2014, 09:29 AM
I was reviewing the descriptions and code and think I made a newbie error - red/green LED signals reversed. No big deal and it's fixed now. But if you had saved the sketch, it's worth re-copy/pasting.
If you set this up and your LEDs tied to red flash as if they're tied to green, no need to resolder, just change the colors in software (it really makes no difference to the Arduino).
May 10, 2014, 11:12 PM
Flying Wood For Fun
irun4fundotca's Avatar
any luck using the code on a nano instead I have them lying around now
the pins would be different tho right?
May 12, 2014, 10:39 PM
Nano should work just fine. All you need is an Arduino with 1 digital output and 2 analog inputs. I think all you'd need to do is change the pin numbers in the code (and the Trinket code numbers analog differently than digital, so you'd have to do it in two places in the sketch--it should be pretty self-evident but let me know if it doesn't work). Plus, you'll get all that extra memory space with the ATmega328 to drive even more pixels with more complex logic!
Yves' original sketch was for the Arduino Pro Micro.
May 13, 2014, 03:43 PM
Flying Wood For Fun
ok great thanks
I have a couple of each board so im good there
just not great at changing arduino code yet
May 13, 2014, 03:45 PM
Flying Wood For Fun
pretty much im just looking for an extension of the main leds kinda like this
Naza led mod beta phase (0 min 46 sec)
May 14, 2014, 01:37 AM
He's got a bit more going on than just mirroring, but it should be no problem to do that. My code fork just replaces the default "off" black color with orientation lights. Set those back to off and you have pure NAZA mirroring.
Happy to help with the code when you have your pins set.
May 14, 2014, 07:06 AM
Flying Wood For Fun
Ok that's makes sense
ok ill let you know once I start tinkering thanks
leds should arrive soon then I will dive in more, I don't have anything to test with right now
May 31, 2014, 05:15 PM
This mod details the parts/setup/programming for an Arduino-based orientation LED system that incorporates the NAZA's (and presumably, WKM/A2) LED signals. My lights are set to display a static orientation front/back, but change to mimic the Naza's red/green/yellow flashes in real time as well. You can also add animations, responses to other RC input (change color when throttling, etc.) and whatever else you can think of.
Details:
  • 3 rings of 16 LEDs each (48 total)
  • Fully programmable color and brightness for each LED, including complex animations
  • Total weight installed: 35g
  • Does NOT interfere with USB/NAZA-M Assistant function
Here's what it looks like on the Y6:
And a test and flight video here:
https://www.youtube.com/watch?v=TXzS2CtT8N4
First off, huge props to Yves Gohy's original mod posted here. I used similar parts, and adapted his Neopixels code.
PARTS
Here's the parts list:
  1. Adafruit Trinket 5V (Arduino-lite controller): http://www.adafruit.com/products/1501
  2. Adafruit Neopixel 16-LED ring (one for each arm). The 16-LED version fits perfectly around the E300 2212/920kv motor housing, but you can get light strips, light bars, individual LED+driver modules, etc. http://www.adafruit.com/products/1463.
  3. 5V output UBEC (just use whichever one you want)
  4. 300 ohm resistor for Neopixel data line: http://www.mouser.com/ProductDetail/...i5Pn2foA%3d%3d
  5. 1000uF 10V electrolytic capacitor (x3, one for each power branch): http://www.mouser.com/ProductDetail/...%2fTZdLTc4RXtG
  6. Misc electronics parts - several meters of 30awg wire, servo/futaba 0.1" terminals and connecters, crimping tool, hot glue, nylon spacers for mounting, solder, flux, heat shrink, etc.
  7. PC with USB port and cable, Arduino IDE (I used the prebaked Adafruit Trinket distro), Adafruit Neopixel library
Adafruit has a GREAT section on their website with details on how to setup and use the Trinket and Neopixels. I highly recommend perusing this to get the hang of how these work: Trinket Tutorial and Neopixel Uber-Guide.
PHYSICAL SETUP
A picture is worth a thousand words, so let's start with that:
A few things to note:
  1. The Trinket doesn't have as many pins as a standard Arduino controller. You need a digital output pin (#1 is tied to the Trinket's on-board LED so that's a good one to use), and you need two analog-readable pins. Digital pins #2, 3 and 4 work, but pins 3-4 are also USB data pins, so you can't upload sketches to the Trinket unless those are disconnected. I tried to get around it by moving one of these leads to #2, but I still have to disconnect the LED to upload new patterns. In the end, it's just a minor limitation you have to deal with.
  2. Adafruit recommends a large capacitor be added to the power leads going to the first Neopixel, to act as a de-bouncer. I actually use three since I have separate power leads from the UBEC to each Neopixel ring, but you can save weight/cost by daisy-chaining.
  3. Same story with the 300ohm resistor on the data line. It's also subject to a smaller current rush, so protect that first pixel on the ring with the extra resistor.
  4. Yves' original documentation was very confusing as he refers to the Naza's "A/E/T/R" pins, but what he actually means are the LED pins above the rx labels. A = LED pin 1 (+5VCC), E = LED pin 2 (red light, or LED2 on LED-V2), T = LED pin 3 (green light, or LED1 on LED-V2), and R = LED pin 4 (GND).
  5. If you use long strips are lengths of power wire between arms, the voltage drop may cause the LEDs further along the chain to be dimmer or color-shifted. While the data line has to be daisy chained from ring 1 to ring n, you can provide direct power to any ring separately.
  6. I power the Trinket from the same 5V UBEC, but if you're powering Neopixels directly from the board, you want closer to 5.5v input. The trinket has its own BEC and supports input voltage to 14V. So a 3S is no problem, a fully charged 4S at 16.8V? Ehh....I'd probably take a risk since the Trinket itself is <$8, and they're optionally sold in six-packs for goodness' sake, but it may fry.
Most people don't have a Y6 (or tricopter), so you can add or subtract rings, or use a Neopixel light strip or light bar or matrix panel, by adding them to the data line and providing power. Adafruit has a ton of Neopixel options, you can find them here: https://www.adafruit.com/categories/87
Here's how I tapped the GND, LED1 and LED2 wires (pins 2-4) from the NAZA LED (the red 5V VCC wire is unused):
The "male" servo connector goes into the NAZA, the "female" goes to pins GND, 2 and 4 on the Trinket. It was useful to have these wires on a servo because you have to unplug pin 3 to access the USB and upload sketches.
My LED rings are temp-mounted. They're just hotglued straight to the frame, with 3mm nlyon spacers to elevate them evenly over the motor wires:
PROGRAMMING
I'm not sure if I should post the code to github or request a fork from Yves, but for now, here's the sketch as should compile for the above setup on the Trinket. I'll leave the details about working with the Arduino IDE to the much better documentation out there on the web:
Code:
 Original DJI LED project
 Author(s): Yves Gohy ([email protected])
 Thanks to: Leandre Gohy ([email protected])
 Current fork: Basic Adafruit Trinket NAZA LED Adaptation
 Version: V1.0 April 9, 2014
 Author: ElGuano on RCGroups.com
 Description: This version is modified to the Adafruit Trinket, particularly
 the implementation posted at ___. It is simplified from the original to save
 RAM and flash space; I also didn't need RX-based controls or switchable
 animation modes, just basic orientation and NAZA mimicry.
 Permission is hereby granted, free of charge, to any person obtaining
 a copy of this software and associated documentation files (the
 "Software"), to deal in the Software without restriction, including
 without limitation the rights to use, copy, modify, merge, publish,
 distribute, sublicense, and/or sell copies of the Software, and to
 permit persons to whom the Software is furnished to do so, subject to
 the following conditions:
 The above copyright notice and this permission notice shall be
 included in all copies or substantial portions of the Software.
 THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
 MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
 NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
 LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
 OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
 WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
 For more detail on the MIT license, see <http://opensource.org/licenses/MIT>
#include <Adafruit_NeoPixel.h>
//#include <math.h>
#define PIN 1 // LED output Pin (Pin 1 output is tied to the red LED on the Trinket)
#define BRIGHTNESS 30 // brightness 0-255
#define STATICSPEED 30 // Placeholder for spin animation (not used here)
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(48, PIN);
void setup() {
  pixels.begin();
  pixels.setBrightness(BRIGHTNESS);
  pinMode(2, INPUT);  // GPIO pins 2 and 4 for analogRead
  pinMode(4, INPUT);
unsigned long int getAnimationColor(word animationSpeed) {
  static const unsigned long int animationColors[] = {
    0x000000, 0x00FF00, 0xFF0000, 0xFFFF00       }; // colors of animation OFF, GREEN, RED, YELLOW
  static unsigned long int animationColor = 0x000000;
  // read Naza green led
  int sensorValue0 = analogRead(2);  //Digital pin 4 is Analog 2 on Trinket
  // read Naza red led
  int sensorValue1 = analogRead(1);   //Digital pin 2 is Analog 1 on Trinket
  byte animationColorIndex = (sensorValue0 > 500) + ((sensorValue1 > 500) << 1); // e.g., 1 + 2 = 3 (yellow), 0 + 2 = 2 (red)
  animationColor = animationColors[animationColorIndex];
  return animationColor;
void playAnimation(word animationSpeed, unsigned long int animationColor) {
    playNoAnimation(animationColor);
void playNoAnimation(unsigned long int animationColor) {
  for (byte i = 0; i < 16; i++) {
 /*   // This shows 12 front/back LEDs, with four - equally spaced NAZA lights per ring
    if ( i == 3 || i == 7 || i == 11 || i == 15) {   // Assign pixels to Naza Blink
      pixels.setPixelColor(i, animationColor);       // Back ring
      pixels.setPixelColor(i+16, animationColor);    // Front right ring
      pixels.setPixelColor(i+32, animationColor);    // Front left ring
    else {                                         // Assign all remaining pixels
      pixels.setPixelColor(i, 0, 180, 180);        // Back ring
      pixels.setPixelColor(i+16, 180, 0, 180);     // Front right ring
      pixels.setPixelColor(i+32, 180, 0, 180);     //Front left ring
// This shows all 16 front/back directional colors, which all flash NAZA lights when lit up
    if (animationColor != 0x000000) {   // Assign rings to Naza Blink if not-black
    else {                                         // otherwise assigns rings to directional color
      pixels.setPixelColor(i, 0x0099CC);        // Back ring
      pixels.setPixelColor(i+16, 0xCC00CC);     // Front right ring
      pixels.setPixelColor(i+32, 0xCC00CC);     //Front left ring
  pixels.setBrightness(180);
  pixels.show();
void loop() {
  unsigned long int animationColor = getAnimationColor(STATICSPEED);
  playAnimation(STATICSPEED, animationColor);
A few notes on the code:
  • Follow the directions on the Adafruit learning site. You need to make sure your IDE version supports the Trinket and TinyUSB programmer. You also need to add the Adafruit_Neopixel library.
  • The Trinket's digital pin labels are DIFFERENT from their analogRead designations. So you call pinMode to pins 2 and 4, but in getAnimationColor you'll be reading from 1 and 2 (which are calling the same pins 2 and 4). Why is it this way? Because.
  • I don't have the LEDs set to full brightness, they're 180 out of 255. They're bright enough for now, but not as bright as the NAZA LED.
  • The commented out pattern in playNoAnimation would show 12 orientation LEDs and 4 cross-pattern NAZA LEDs. Give it a shot, maybe you'll like it better (but I found you couldn't see the flashes at distance).
  • Neopixels support awesome animations, PWM effects, you name it. Don't just stay with my static lights! Mess around with them and light up the sky.
  • The Trinket has enough RAM to support ~120 pixels, depending on the complexity of the code. My three rings are 48 pixels, a quad layout would be 64, and hex would be 96.
  • There's room in RAM for more complex logic, as well as a gamma correction table. The color-elitists around can use that to correct the look.
You can also grab Yves' original (and more complex) code here: https://github.com/diogeneyves/dji-naza-led
He also has some setup pics with an Arduino micro, in case mine are incomplete/confusing.
Hi ElGuano,
I wanted to ask if there have been any changes or updates since your original post in May?
Thanks again for this, it's great. Ideally, I am going to try and add these as white landing lights on my S1000.
Any thoughts or guidance will be greatly appreciated.
Thanks!
May 31, 2014, 07:58 PM
Flying Wood For Fun
don't buy a cheap clone trinket the pins are mapped differently is the best I can advise
speaking from a lesson learned
May 31, 2014, 09:38 PM
Originally Posted by mdenovellis
Hi ElGuano,
Thanks!
Hi Mike,
No major updates...I did clean up the code a bit for my recent Phantom integration (currently only using 16 LEDs). The original code has some unused variables and methods (no need for animationSpeed or playAnimation):
Code:
//#include <math.h>
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(16, PIN);
void setup() {
  pixels.begin();
  pinMode(4, INPUT);
unsigned long int getAnimationColor() {
  int sensorValue0 = analogRead(2);  //Digital pin 4 is Analog2 on Trinket
  int sensorValue1 = analogRead(1);   //Digital pin 2 is Analog1 on Trinket
  for (byte i = 0; i < 8; i++) {
// show all 16 back directional colors, which all flash NAZA lights when lit up
      pixels.setPixelColor(i, animationColor);       // Back right (M4)
      pixels.setPixelColor(i+8, animationColor);    // Back left (M3)
      pixels.setBrightness(255);
      pixels.setPixelColor(i, 0xFF00FF);        // Back right arm (M4)
      pixels.setPixelColor(i+8, 0xFF00FF);     // Back left arm (M3)
  pixels.show();
void loop() {
  unsigned long int animationColor = getAnimationColor();
I have some custom front/back animations in the works and animations for strips/rings (all while maintaining NAZA mirroring). I'll try to finish those up and post an update with a video demonstration sometime in the next week or so.
IMPORTANT: I assume you're running a WKM or A2 on the S1000? At least in the case of the A2, the LED module is combined with a BTU and both communicate with the flight controller via CANBus. What I suspect that means is that you're not going to have two naked voltages to read to suss out LED colors...also, the A2/WKM LED is full RGB, with more than just the Naza's 3 indicator colors.
I'm setting up a project to intercept and decode the A2's CANBus comms to the LED so I can create a fully functional A2 sketch for the Neopixels to mirror, but that's a bit in the future and no guarantees it'll pan out.
The sad upshot for now is, I'm 99.9% sure the LED mirroring part of this mod won't work for the WKM/A2. But the neopixel rings themselves should make great landing LEDs if you just want independent animations without flight controller integration.
Jun 01, 2014, 01:57 AM
Mowee's Avatar
I got some rings, now I just need some TIME.
Do you have photos of your Phantom integration?
Jun 01, 2014, 11:45 AM
Originally Posted by Mowee
I got some rings, not I jet need some TIME.
It does take a bit of time to think through how you want to route all the wiring and get everything set up, but it's well worth it!
Here's a link to what my phantom version looks like: https://www.rcgroups.com/forums/show....php?t=2175764
