Apr 01, 2014, 09:59 PM
"Free" in Christ! #F3P
Free's Avatar
DIY Coaxial motors
Hello guys!!
I don't know how many guys are experimenting with making their own coaxial motors, but I am so I figured I'd share.
Please discuss any homemade coaxial motors here.
I know about Kimmo's thread, but would like to start a new one about systems made for individual use.(for now)
Enjoy!
Free
Apr 01, 2014, 10:03 PM
Free's Avatar
With about $20 for the hardware, with $75 for the Glavak props, and with about 5 hours of work, I have successfully made a coaxial system!
It was relatively easy and I am very happy with it.
It is the first version and I did not try to save to much weight, but it is still 18 grams with Vprops, and 16 grams with Glavak straight props!
It produces about 130 grams of thrust and will be suitable for a 75-85 gram aircraft.
I am thinking about trying to make my own props in the future. We'll see.
Enjoy!
Free
Apr 02, 2014, 06:00 AM
Atleast It's in one piece
Hi Free
That looks really impressive keep up the good work, I've got the frame, gears and shafts etc from a tiny coaxial heli to play with so I'll see how I get on .
Apr 02, 2014, 11:35 AM
Free's Avatar
Thank you!! I must give credit to "Bicutz" here on RCG for giving me the idea and telling me where to get the gears!
The only downside is the fact that it is loud.(due to the gears) And the prop savers were tricky to make.(they took the most time)
But I can get over that.
Free
Apr 02, 2014, 11:39 AM
jhicks's Avatar
Can you share what you did? What parts?
Apr 02, 2014, 12:05 PM
Free's Avatar
Sure! I'll try to take some photos, but until then, here's the parts listing:
HK Motor
3mm ID bearing from a different HK motor
The orange thing is the hub from a GWS 8x4.3 prop, modified to hold the bearing.
3mm OD aluminum shaft from Tower Hobbies.
2mm carbon rod(could save weight by using tube)
A tiny piece of 3mm OD 2mm ID carbon to keep the 2mm shaft from falling out the back.
Two servo arms and some small plastic rings for prop savers.(modified, of course)
1/16" plywood for motor mount.
Gears(they took forever to ship)
CA
A tiny piece of Depron foam used for supporting the motor.
Those are all the parts.
Free
Last edited by Free; Apr 04, 2014 at 10:50 AM. Reason: Added 3mm OD 2mm ID carbon shaft
Apr 02, 2014, 12:07 PM
Free's Avatar
Originally Posted by Arcright
Hi Free
I thought about doing that, but I don't have a small coaxial heli, and I didn't want to buy one.
Post pics!!
Free
Apr 02, 2014, 12:28 PM
Glad you started this thread and great job on your first try. Would be nice if we could get Bicutz to share here.
Apr 02, 2014, 12:39 PM
Hi Free
Only got the heli guts this week looks like I need to cut the outer shaft down to give space between the gears for the motor drive to fit in and then a spring between the shafts to keep a bit of pressure on.
I was hoping a rubber bush would serve a drive between the gears just need some time to play.
Forgot to mention the doner heli was the remains of MCX blade one of my fellow indoor flyers gave it up for free he said he may others but I reckon I'll have to give him a beer or two if I want them.
Arcright
Apr 02, 2014, 03:06 PM
Free's Avatar
Looks good!!
I look forward to seeing progress!
Free
Apr 02, 2014, 11:12 PM
F3P, Slap, IMAC, Helis
A coaxial helicopter uses 2 motors on all the rc ones at least. Just throwing that out there
Apr 03, 2014, 02:43 AM
I have a tote full of parts to build one, I have just been too busy. I have built three big planes two electric and one gasser with a DA50. I have to get this stuff finished because I really miss flying my foamies.
Great work Free, lets see it run buddy.
Apr 03, 2014, 05:13 AM
Hi Bubba
The motors from the old heli won't be used I've attached a quick drawing to try to show the idea.
The drive from brushless is through a rubber bush so the teeth one gears aren't used.
Arcright
Apr 03, 2014, 01:50 PM
Free's Avatar
I have a video, I just have to upload it. It's just of it running up to about 20%. I'll try to get it up here soon.
Hi Bubba
Arcright
A very simple design. Where are you guys getting the spring for the 2mm inside shaft?
Free
Apr 03, 2014, 04:32 PM
Free[/QUOTE]
I'm still looking hoping to find some common household item to get it from.
Arcright
Build Log DIY big props for coaxials bicutz Indoor Pattern/F3P 69 Feb 26, 2018 08:48 AM
