Mini size PDB - RC Groups
Mar 31, 2014, 05:09 PM
Idea
Mini size PDB
I'm thinking of making a small'ish size power distribution board to simplify wiring for small quads. Wiring up ESCs and FPV components on a 250mm quad can be a pain, so maybe this could be a plug and play solution without adding too much weight.
This is what I'm thinking so far:
-Dimension 36mmx36mm with 30.5mmx30.5mm mounting holes... does it make sense to go smaller and use double sided tape for mounting?
-ESCs connections for 8 ESCs
-Built in power supply filter for Vtx and camera, 12V supply
-Connector for Camera input... 3-pin male servo type or something else?
-Connector for VTX input...3-pin male servo type or something else?
What other 'features' would you like to see on it?
-Tony
Rev 1 - Received April-16...Works great!
Rev 2 - Instock as of May-02
Rev 3 - Instock on June-20
Rev 2 kit contains: 36mmx36mm PDB, connectors, power filter components
Specs:
-Built in power supply filter for Vtx and camera 12V supply
-3-pin connectors for VTX and Cam
-2oz copper for low lost
Available From:
www.RedRotorRC.com
http://www.rc-drones.com/Mini-Power-...uts_p_670.html
http://www.multirotorsuperstore.com/...ra-inputs.html
http://www.dronematters.com/index.ph...put-rev-3.html
http://www.fpvrotor.com/?product=mini-pdb-v3
Assembly Guide: https://redrotorrc.com/download/RedR...ly%20Guide.pdf
Rev3 Improvements:
-Double the copper thickness to handle 400/450 size quads
-Black soldermask
-Servo pins are moved inside keep connected cables neatly out of the way
-Beefier ESC pads and through hole Batt connectors
Mar 31, 2014, 06:30 PM
DebianDave's Avatar
Variable voltage for FPV gear. There are fairly cheap DC DC converters on eBay (<$2) which have been used with some success for providing 3.3v and 5v for different pieces.
Mar 31, 2014, 07:16 PM
Good idea Dave! I've been using 12V cameras for so long that I've forgotten about 5V ones.
Can these DC/DC converter be mounted on PCB? it's not hard to leave a footprint for these modules to mount on...if you need to use it.
Btw, I'll have a few boards made within the next few days. I will make the layout available to those who wish to make it themselves.
Apr 05, 2014, 09:31 AM
DebianDave's Avatar
Sorry for the late reply. The converters i mentioned are ebay item number 310683416079. I don't have the equipment to verify it but they are apparently very low noise. Certainly don't appear to mess with my 5.8GHz system. I'm using 2 of them (1 at 5v for mobius and 1 at 3.3v for vtx). There's a good youtube video on these, I'd link to it but on my phone at the mo. It would be very easy to mount these to a custom PCB using 0.1" headers. Not sure what sort of demand would be there for it though
Apr 06, 2014, 06:01 PM
Thanks for the reference to the converter board. If there's enough interest in mounting these to the PDB then I can add a footprint to the 36x36mm PDB...it will be tight but not impossible.
I just finished laying out the first version of PDB:
-10 common power inputs to connect to either Battery or ESCs
-LC power filter
-3-pin camera
-3-pin Vtx connector
I'm not sure what the weight will be exactly, but hoping to be less than 10 grams with all the components loaded.
Apr 06, 2014, 06:56 PM
☢ ɴᴏᴏʙ ☢
trinco's Avatar
awesome project tony
it will be great if the board is compatible with OP CC3D/Revo & naze32
dimension 36mmx36mm with 30.5mmx30.5mm mounting holes
Apr 06, 2014, 08:28 PM
xhover's Avatar
Thats such a great idea!!
Apr 06, 2014, 10:18 PM
QuAd FaNaTiC
Razors edge 29's Avatar
I'd be done for or more of these.
Could've used one this weekend lol
great idea
Apr 06, 2014, 11:14 PM
masterless samurai
the.ronin's Avatar
Definitely subscribed. Any chance of incorporating a micro lc filter and / or 5v stepdown regulator? If it's a mini, there's going to be some noise.
Apr 07, 2014, 12:12 AM
Thanks Trinco! I just conrrected the dimensions in my original post...It's meant to be compatible with all the popular mini size FC's (CC3D&Naze32)
Mounting holes are ~3.2mm large to accommodate for M3 screws with a little wiggle room.
Apr 07, 2014, 12:16 AM
Thanks! I could see one mounted on an MXP230
Apr 07, 2014, 12:22 AM
Version 1.0 does have an LC filter built in. Version 2.0 will likely have a 5V output... I haven't decided to use a buck or a linear regulator. I guess it depends on how many people are using 4S in their mini?!?
Apr 08, 2014, 06:02 PM
xhover's Avatar
I would love to see one on the MXP230
Apr 08, 2014, 09:49 PM
Always Building
TheMadCADer's Avatar
I would love to buy one
Apr 09, 2014, 02:04 AM
I'm getting a few back from the fab house by the end of next week. I'd like to give back to the community by giving out a few units. Send me a quick PM if you're interested... All I'm asking is that you share some pictures of it mounted on your quad
