Aug 09, 2015, 11:24 AM
New SiLabs ESCs added
Three new ESCs are added to SiLabs on github.
Please be patient, I'm sure Achim will follow up with BLHeliSuite support very shortly .
A Fairy 6A and a Fairy 40A.
The Fairy 6A is a small Nfet and Pfet ESC that does not support damped light, but should otherwise be good.
The Fairy 40A could prove to be a decent 6S ESC, although the high side driver is a bit slow to turn on, just like many Atmel ESCs.
Then there is a very promising little ESC, the FVT Littlebee 20A:
This ESC has a good design with fast dedicated driver chips, which gives excellent freewheeling and exceptional braking.
Initial stress testing on 4S with a Cobra 2208/2000 with 6x4.5 prop, doing repetitive immediate accelerations from low rpm to full throttle went well.
During the initial acceleration, this setup pulls about 100A, so it's a tough test for a small ESC (and can break other small ESCs).
Hopefully this indicates that the ESC will prove to be a reliable performer.
And so far, this is the closest performer to KISS that I have seen in this size.
Word has it that it will be available from multirotormania and multirotorparts shortly
Aug 09, 2015, 11:35 AM
I'd rather be flying
QuadMcFly's Avatar
Sweet! Any word on the price range? Also how would you compare it performance wise to the RG20s?
Aug 09, 2015, 11:39 AM
Firmware Fiend
The Quasar's Avatar
I think pukindrublik mentioned it would cost about $15.
Aug 09, 2015, 12:02 PM
Should be equal or better
Aug 09, 2015, 12:35 PM
QuadMcFly's Avatar
I'm sold! Can't wait to see em on the shelves!
Aug 09, 2015, 01:27 PM
Boris B's Avatar
I just flight tested those FVT escs today and damn those are pretty insane!
Aug 09, 2015, 02:37 PM
QuadMcFly's Avatar
Will these ship with BLHeli 14 and the bootloader preinstalled?
Aug 09, 2015, 02:53 PM
Firmware Fiend
The Quasar's Avatar
Uh oh--LoL--insane enough to ditch the RG20As in favor of these FVTs?
Aug 09, 2015, 03:11 PM
I think with a silabs F396 controller they might be absolutely the best esc in this size /class. From the pictures it looks like a f330.
Aug 09, 2015, 05:38 PM
Boris B's Avatar
No I got both....not ditching anything. I got 4 multirotors and these were only a sample I got to try out.
Aug 09, 2015, 07:58 PM
Favourite ESC
Glad to see that you've posted for us - FVT
Thank you.
Aug 09, 2015, 08:08 PM
Do any of the ESC's mentioned above run at 50MHz? As I understand it, the F330 can only run at 25MHz max even with an external oscillator. I would love to see something that can handle these really high KV (3100+) motors.
Aug 10, 2015, 01:02 AM
Hi guys, I was trying to flash my hobbywing x-rotor 20A particularly using arduino UNO. But the BLHeli Suite can't detect the ESC.
This is my connections:
I also tried this connection:
I flashed my Arduino UNO with the interface in BLHeli 14 suite, using the Arduino BLHeli Bootloader but no luck. The suite can't detect my ESC. Any suggestions guys, I really need some help. Thanks!
Aug 10, 2015, 01:25 AM
Nice to see more fast ESC's appearing. I have a feeling I'm going to have to replace my sn20's not long after my Cobra 2206's arrive....
Aug 10, 2015, 02:06 AM
The Arduino interface pinout should follow these instructions:
https://raw.githubusercontent.com/47...s%20pinout.pdf
ESC GND => Arduino Uno GND Pin
ESC C2D (white) => Arduino Uno Pin D12
ESC C2CK (red) => Arduino Uno Pin D11
Which option exactly? The one marked with "C 1"? This won't work with a C2 connection!
I suggest to select the so called 4-way interface by clicking on "Make Arduino general -- B D 2 3"!
Afterwards open menu "Select ATMEL / SILABS Interface" and select option "B SILABS C2 (4w-if)"!
For futher instructions please see https://raw.githubusercontent.com/47...20adapters.pdf
