Mar 29, 2014, 10:48 AM
Foxtech Foxtech motor W50-08 kv330 V2 specifications
Hi Foxtech
I am looking to buy many of either Foxtech motor W50-08 kv330 V2 or Tarot 5008-340kv from you.
I want a do a calculation using ecalc.ch
Could you supply me with ALL of theese specifications for both, otherwise I will be forced to buy the Turnigy Multistar 5008-340kv from hobbyking as they supply all of these specifications.
no load current at a given voltage(eg 10V or 22v)
power limit in watts
internal resistance in ohms
case dimensions
number of poles
motor weight
Thank You!
-Joe
Edit: I would also like to know all of these specifications for the W5010 if possible
Mar 29, 2014, 05:11 PM
Please provide the internal resistance for the W5010 as this is the motor I am most interested in!
Thank you!
Apr 11, 2014, 09:58 PM
5008 22 poles,
5010 20 poles.
the internal resistance is very small that can't be measured.
please check the datasheet ,it's all from real testing.
