Mar 24, 2014, 10:39 AM
Vspeak Vario with Spektrum DX9
I currently have a DX8 with Vspeak+vario.
Has anyone tried the Vspeak vario in conjunction with the new DX9?
The Vspeak vario appears to be more sensitive than the new Spektrum offering.
I would be interested to know if it was compatible.
Mar 24, 2014, 03:44 PM
Of course it works. Also with the DX18 with the new Airware
Only thing you have to make sure: Set the refresh rate to 1/4s, since the VSpeak Vario does the filtering inside and transmits the data using this dataset. Otherwise you get no beeps.
I tested both the "old" one and the brand new one with the better sensor.
The Vspeak Vario uses the following sensor addresses: Altitude, Vario, Powerbox (for single cell monitoring) and G-force. You can disable some of the "virtual" sensors if you use e.g. a sensor using the powerbox address
Mar 24, 2014, 04:19 PM
Thanks, I knew you would have the answers.
Do you have any idea how the sensitivity compares between the Vspeak Vario, Vario Pro and Spektrums offering?
Mar 25, 2014, 03:13 AM
I have no pro, but I think the normal Vspeak vario is slightly better than the spek one.
Mar 25, 2014, 03:39 PM
Yes that was my thought also - Spektrum appears to be 0.3m resolution to the vspeak 0.1m?
Concrete data/instructions is always hard to find in Spektrum instructions.
Jul 01, 2014, 01:31 AM
Hi all, nice to find you as specialists, was directed here by Volker; The following,
Have received the Vspeak and my transmitter is the Spektrum DX9
software version; 1.5 and the latest text file.
Immediately all data was working, altitude, G force and vario displays.
voice call out for altitude but no vario tone! the refresh rate is 1/4!
In other words, all display is there, only altitude voice call-out, NO vario tone!
hope you can help me with a good suggestion! Many thanks on forehand
kind regards, George
Jul 01, 2014, 02:40 AM
You have to enable the vario tone. Normally per switch. Also, the sink tone might be hard to hear due to the low frequency. Do you have a lift/sink threshold set ? You can start with 0.1m/s and try lifting and lowering the model...
Also, 1.06 is latest Airware (1.04 latest sound)
Jul 01, 2014, 09:52 AM
AndyKunz's Avatar
If you aren't using the latest sound version, you won't hear vario tones.
Andy
Jul 01, 2014, 11:22 AM
richard hanson's Avatar
Andy
Get Slim Whitman to do the vario tones --------- Then you will hear em----
Jul 01, 2014, 11:31 AM
AndyKunz's Avatar
Slim Pickens would be good too.
Andy
Jul 02, 2014, 12:25 AM
thank you for the reply, I have enabled the vario tone, just by selecting "on" should work like that I guess. Indeed I lowered the treshold and moved the model. See the vertical bar running up and down. Rest to download 1.06 and do a double check on my sound files.
keep you posted
Jul 03, 2014, 12:46 AM
Hi all, well still no vario sound; checked the voice file 1.04 upgraded Air to 1.06 and confirmed on the xmitter display. Instead of having vario just "on" assigned it to a switch. Unfortunately all voice call outs are there except vario!
A detail I like to mention; I do not have any micro SD card installed in the Vspeak sensor, could that be the problem? If so, how does the . TXT file looks like?
Thanks for your attention to my story, with kind regards, George
Jul 03, 2014, 01:25 AM
Can you post your SPM file, please ? I will have a look. Do you have the "Pro" or the normal vario ?
Jul 03, 2014, 08:42 AM
AndyKunz's Avatar
Go to the Version Data screen. What does it show for VOX?
Andy
Jul 04, 2014, 05:43 AM
Hi guy's, first of all thanks for all the suggestions,
Have the normal version.
pls help me out, where can i find the smp file?
where is the version data screen?
thanks again
