Mar 19, 2014, 02:40 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Build Log
Lockey's Little Fokker
Thought I would have a change and play with something “Quick and Easy” to build … AND hopefully will fly real good … and real slow
So a new park flier on the drawing board … Lockey’s Little Fokker
It’s a Fokker Eindecker E3 lookalike … 1300 wing span all Depron (about a sheet and a half) with rolled under-camber wing, I am not sure how she will fly with the under-camber wing but we will see
Any ideas / comments ?
Lockey
EDIT
Little Fokker
1300 mm Wing Span
Length 940 mm
All up weight with 2800 battery approx. 1100 grams
2 sheets 6 mm Depron
˝ sheet 3 mm Depron
Small quantity 2 mm Ply
Small quantity 0.8 mm Ply
1 x length 5.5 mm Brass Tube (approx. 200mm long)
1 x length 4 mm Brass Tube (approx. 300 mm long)
2 x threaded pushrods (for undercarriage)
1 x length 3 mm piano wire (approx. 400 mm long)
2 x length 3 mm piano wire (approx. 200 mm long)
I used
ZIPPY Flightmax 2800mAh 4S1P 30C … https://www.hobbyking.com/hobbyking/s...mAh%204S1P%203
Turnigy D3536/8 1000KV Brushless Outrunner Motor … https://www.hobbyking.com/hobbyking/s...8%20%20Brushle
APC style IC Sport propeller 11x6 … https://www.hobbyking.com/hobbyking/s...0propeller%201
TURNIGY Plush 40amp Speed Controller … https://www.hobbyking.com/hobbyking/s...040amp%20Speed
4 x HXT900 9g / 1.6kg / .12sec Micro Servo … https://www.hobbyking.com/hobbyking/s...g%20/%20.12sec
Anyone downloading the plans ... If you have a look at sheet 3, you will see a line that shouldn't be there ... don't know where it came from (ignore it .. see pic)
Plans are now available at: http://www.lockeysrcplans.com
Mar 19, 2014, 06:25 AM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
That should be FUN !!
Here’s one similar we did some time ago ... Flew great !! Nice and Slow ...
Latest blog entry: Lost plans
Mar 19, 2014, 06:39 AM
Lockey's Avatar
Thanks gpw, love it
Lockey
Mar 19, 2014, 06:59 AM
Build straight - Fly twisty
Whiskers's Avatar
Originally Posted by Lockey
<snip> Any ideas / comments ?
Lockey
Should be really nice if you use plenty of aileron differential with those under-cambered wings to make it behave itself in the adverse-yaw department.
That and, put every item of equipment as far forward as human ingenuity can devise, and apply equal genius to keeping the tail-end light.
I'm looking forward to seeing the result.
Mar 19, 2014, 07:05 AM
Lockey's Avatar
Thanks Whiskers, This is my biggest problem (I think) getting enough weight forward and keeping the tail as light as possible
I was hoping to use one of the motors I have here ... something like this one https://www.hobbyking.com/hobbyking/s...dproduct=12920 ... but I don't know if there will be enough weight in this
Lockey
Mar 19, 2014, 07:07 AM
gpw
gpw
gpw's Avatar
Apologies , I cheated and added an inch to the nose ... also increased the area of the tail surfaces ... Just an RET sport plane ...
Mar 19, 2014, 07:10 AM
65 years of RC flying
Daedalus66's Avatar
Looks like a great idea. I suggest cheating a bit on nose length to make balance easier. A little longer will still look fine.
Ah. Beat me to it!
Mar 19, 2014, 07:29 AM
Lockey's Avatar
Thanks gpw, I have already enlarged the tail areas a little
Hi Nigel, great minds think alike eh
I will look at maybe adding a bit to the front and or shortening the back a bit too !!! ...... mmmmmm moving the wing back a bit would do both at once eh
Lockey
Mar 19, 2014, 08:07 AM
Whiskers's Avatar
Sneaking the wing back sounds like a great idea, and with 200W up front it will have plenty of boogie.
Mar 19, 2014, 08:54 PM
Lockey's Avatar
Almost ready to go to preparing the plans and this one should be a pretty quick build .. look forward to an easy quick build after the Tiger Moth build
Pic shows the full layout
Lockey
Mar 19, 2014, 11:59 PM
Just another FPV addicted teen
EpicRC's Avatar
Looks nice! When do you want to come up and fly? A weekday would be good. In the afternoon as well (less wind) Would love to see your tiger moth.
-Ben
Mar 20, 2014, 06:56 AM
Lockey's Avatar
-Ben
Hi Ben, will send you a PM
Lockey
Mar 20, 2014, 09:08 AM
Lockey's Avatar
I have changed the thread to a "Build Log" and have had the initial plans printed ready to start the build
I will post pics when I start building ... as I thought, it takes just over one and a half sheets of Depron and a couple of bits of 2 or 3 mm Ply
As usual, plans are on Depron size sheets (1000 x 700)
Lockey
Mar 20, 2014, 12:06 PM
Home of "Golf Cart Flying"
pecanpatch's Avatar
I may have to build one.... one of my good buddies flies this........
bank away (0 min 31 sec)
Mar 20, 2014, 07:34 PM
Lockey's Avatar
http://youtu.be/0saN2tfXutk
Love it
Lockey
