May 09, 2014, 07:35 AM
midelic's Avatar
No not yet ....not enough time...I received the multimodule pcb,,have plenty work..
May 09, 2014, 07:43 AM
Originally Posted by midelic
It is compatible with Frsky 2 way...so make sure working...your Tx or RX module in is frsky 2 way mode.If your module said no telemetry that means is not compatible..is Frsky 1 way mode.
I had confirmation from independent sources that at least DIY RX is working....
Oh. my Tx is 1 way .Okey i see
thanks
May 11, 2014, 08:53 PM
led for TX Diy Frsky , i don't see it does what ? . Not bink, solid ....only off . Don't see to write about it
May 12, 2014, 05:39 AM
midelic's Avatar
Atm doing nothing...but any TX should have a witness,,..I forgot to add it.
I need to add a line
LED_ON;
at the end of setup() function
May 12, 2014, 04:03 PM
I have a bunch of Flydream receivers laying around the 8ch and 4ch, nice compact units. They are also based CC2500, T212, & Atmel cpu. Same hardware also inside the corona system.
Would be nice if we could reflash our old Corona and Flydream receivers to Frsky?
http://www.bidproduct.com/more/cart....nSearch=Search
https://www.hobbyking.com/hobbyking/s...hz_Corona.html
May 12, 2014, 04:06 PM
midelic's Avatar
which atmel cpu....they used?
May 12, 2014, 04:22 PM
https://www.hobbyking.com/hobbyking/s..._V2_DSSS_.html
This one ? For 11$ ?
Can you post a picture of it inside ?
For reflash you may need some pads, or at least a atmega chip with proper legs
May 12, 2014, 05:07 PM
Never any problems with the Flydream system myself, but not as good as Frsky. Downside of Flydream diversity is not implemented and is not true FHSS, but a 3 parallel channel DSSS.
All receiver have same hardware components, so even the 4ch do have t212 and cc2500. The ATMEL seem to be MEGA98 or MEGA88? difficult to read.
http://www.rcmodelreviews.com/flydreamv3review.shtml
May 12, 2014, 05:28 PM
midelic's Avatar
If is atmega88 can be re flashed without soldering..
May 13, 2014, 08:51 AM
midelic's Avatar
added new thread
DIY Multiprotocol Tx module
https://www.rcgroups.com/forums/show...6#post28359298
May 13, 2014, 08:54 AM
However, It is attiny24 ? sorry i cann't buy it . want to replace by at2313 or others
May 13, 2014, 07:09 PM
RC beginner
i dont see one in midelics photos so probably he is just using that as a perfboard. hopefully we can get some actual wiring info.
May 13, 2014, 07:22 PM
midelic's Avatar
NO Attiny...I used only attiny pinout from the existing board(a hack) to connect to my promini..Yes something like a perfboard
May 14, 2014, 04:29 PM
midelic's Avatar
sorry wrong posting
May 20, 2014, 09:03 AM
midelic's Avatar
For people having trouble binding with Frsky 2-way RX.
Minor update of the code on first post ...introduce a variable for tweaking easier the CC2500 base frequency..along with a better explanation.
static uint8_t fine = 0xd7;//* 215- my value *//give values from 0 to 255 for freq offset
//values from 0-127 offset increase frequency ,
//values from 255 to 127 decrease base frequency
//this is useful for tunning TX base frequency to frsky RX freq.
See first post for updated file.You need change values and recompile.
