Mar 15, 2014, 04:38 PM
Originally Posted by midelic
@e
Test that one for the moment.....with my module it works...
I'm still working on that auto tunning routine...it will take some time...I have also other commitments.
Juts tested your RX code. And it did work on first shot
I did use the module that I know it has already a decent tuning to my FrSky TX
Few comments:
The led does not bring any information ... it should be dead when no signal
Blinking when binding
Solid when get a RX signal and blink black for each missed RX packet
At least this will be my ideal led
Instead ... does not do much
Anyhow .. it is working
Servo is a bit jittering
Recovery time from switch off TX is quite fast.
Possibly the trick for make it work fine it is to power atmega and RF module all at 3.3v
ps: I think you can post the code and the HEX ... you got my bless on it
pps: I did not do any range test ... I use a big mess of cable on my desk ... so ... I'm going to de-cable right now .. and ready to re-flash my nano for a new experiment ... but I will make a permanent module via solid soldering between pro mini and my micro CC2500 on the adapter
Mar 15, 2014, 05:17 PM
midelic's Avatar
I finish the rx with everyting servo ,PPM,tunning routine...blinking led,... simulate .Frsky binding..LED off when no signal..About servo...I think you have a powering servo problem..On my low voltage servo...there is no jitter......
Mar 15, 2014, 05:21 PM
I finish the rx with everyting tunning routine...blinking led,... simulate .Frsky binding..LED off when no signal..About servo...I think you have a powering servo problem..On my low voltage servo...there is no jitter......
NO power issue for me
I did power my servo directly on u-bec ... and the rest was on 3.3v
It is just not as fluid as I would expect ... but it was also a cheap hxt900
Anyhow
What about telemetry ?
Mar 15, 2014, 05:24 PM
midelic's Avatar
Hey hold on,... I'm beaten...need relaxing...and on top of that I got flu.
Mar 15, 2014, 05:27 PM
Ok .. pass me the new code ...
I can try to work on about the telemetry
Having a real TX and RX with telemetry ... it should be more easy for me to do reverse engineering ... even if I believe it could be more simple as expected.
Anyhow ... so far .. very good job
Mar 15, 2014, 06:38 PM
midelic's Avatar
I was curious about what you said about servo...so I hooked up a servo again and test.This time I made a video.See for yourself.
I don't see any jitter ..
DIY FrSky_RX servo test (0 min 41 sec)
Mar 16, 2014, 05:01 PM
midelic's Avatar
I tested again ...hoked up servo...to Rx ..no problems found...Checked for dropped frames also ..In the analyzed sample ,.....no dropped frames.I think the rx is ok for now.
I'm working now at the diagram for frsky Rx .As soon as is finished I'll put on second post of this thread.
Mar 17, 2014, 03:26 AM
Possibly it is my servo that sometime does not like PWM at 3.3v.
Maybe it would be needed to put a R-C filter and a transistor for put out 5v .. but it will complicated a lot the current simple approach.
I see your code run all time with with enabled interrupt ...even while you do BB SPI you don't block interrupt. So yes, the code is looking 100% safe from any possible interference.
Mar 17, 2014, 03:41 AM
Great work!
Mar 17, 2014, 11:00 AM
midelic's Avatar
Now,.... Rx code and diagram on second post.
Mar 17, 2014, 11:13 AM
Very good.
Do you think it possible to get RSSI from the CC2500 ?
I would like to have a version with PPM and RSSI out only
This will also make more easy to test range
Mar 17, 2014, 11:39 AM
midelic's Avatar
There is already with PPM out..
Bridge jumper between .Servo1 and Servo 3 pins...activate PPM out on Servo4 pin.
For RSSI
you can add yourself in main loop...
int rssi = cc2500_readReg(CC2500_34_RSSI | CC2500_READ_BURST);
Mar 17, 2014, 12:10 PM
For RSSI
Excellent .. thanks .. I will try soon
Mar 18, 2014, 10:59 PM
hey medilic and elm 70
RX had here and it's can use with a orginal Frsky ?
Mar 18, 2014, 11:35 PM
midelic's Avatar
Yes ,..".e".... just said he tested with frsky original..TX.module
My cc2550 pcb is very tiny, half of A7105 and 1/3 of nrf...one can make a very small rx.
