Mar 10, 2014, 05:58 AM
gsantos_pt's Avatar
Mini-HowTo
Mobius Actioncam Vibration Damper Tutorial
Hello everyone!
The jello it's a common problem that many have with Mobius mounted on Multirotors. For solve that issue I made a simple vibration damper that solves the problem very well. This kind of vibration dampers are used also in industry and they work very well to RC and you will see
All you need to build the isolator :
-Wood (Two plates 45x45mm)
-Bolts
-Nuts
-Washers
-Steel cable (I used 1mm)
-Rubber Bands
-Cable Fixer
-Foam
On next video you will how was before to use this, and after
Tutorial - How to remove jello from Mobius Actioncam (2 min 15 sec)
And for results even better I made this update to my previous video and the results are even better!
UPDATE // Tutorial - How to remove jello from Mobius Actioncam (2 min 34 sec)
Hope you enjoy this simple techniques and also build some vibrations dampers if you need them
Gonšalo
Mar 10, 2014, 10:42 AM
Mortimer's Avatar
I've done something similar, it works well.
Mar 10, 2014, 01:54 PM
quailbird's Avatar
You sure did a great job getting rid of the Jello! Well done!
Mar 11, 2014, 05:12 AM
gsantos_pt's Avatar
Same concept mate Do you have a video for we see the results?
Thanks!
Mar 19, 2014, 04:54 AM
gsantos_pt's Avatar
Hello again!
Bad news, the Jello war is not over yet. Last weekend the sky was very clear here and that looks to affect the jello. The vibration damper will need some new improvements soon. I did a short Downhill footage and this was the result:
Tricopter vs Downhill (1 min 22 sec)
Mar 19, 2014, 10:46 AM
Mortimer's Avatar
Unfortunately no, my country has very restrictive aerial videos laws.
To live happily, we have to hide away.
Mar 23, 2014, 02:04 PM
QuAd FaNaTiC
Razors edge 29's Avatar
Why would clear sunny day affect jello?
Mar 23, 2014, 03:52 PM
Closed Account
Becaus the camera has shorter shutter times - different frequency of images taken for video...
Mar 23, 2014, 08:24 PM
QuAd FaNaTiC
ok - do u mean just with quads?
I've been noticing more jello on sunny days as well and at first thought it was a coincidence
BUT
maybe not.
I've been struggling with a mount for mobius that is completely jello free but not quite.
Mar 25, 2014, 06:36 AM
gsantos_pt's Avatar
The first test that I did with this vibration damper was at night with fluorescent lamps and the video was free of jello. Then on next day (with natural light and some clouds) I tested it again and noticed that had jello and then I added some rubber bands to solve it (and was nice as you can see on my videos). Finally, some weeks later, the sky it's clear and much more brighter and the jello shows up again. That's why I say that the light intensity will take effect on the results.
Apr 04, 2014, 08:05 AM
gsantos_pt's Avatar
Hello!
Another video that I made. I think that I should try some carbon props or better props like that ones from graupner. This jello needs to be killed!
Multiwii Tricopter Epic Flight (2 min 35 sec)
Apr 14, 2014, 01:58 AM
Here is my version of Anti Jello Mount. Works like a sharm. Made a video with before and after.
Anti Jello Mount for FPV Mobius Action Cam (2 min 0 sec)
Apr 14, 2014, 05:06 PM
Mortimer's Avatar
Your design is simple and light. Congratulations.
I have done a similar mount which is heavier than yours but works also quite well. I think it's better than the X shaped one.
https://www.rcgroups.com/forums/memb...archive=201312
Apr 14, 2014, 10:16 PM
QuAd FaNaTiC
looks good
what size of fuel tube is that, and are those steel braided cables?
Does it work well in fast forward flight as well?
no oscillation?
https://www.youtube.com/watch?v=yHgyzjDun_Y
Apr 15, 2014, 05:00 PM
Mortimer's Avatar
Things are moving forward.
Choice of DIY Mobius anti-jello mounts increases quickly.
DadHav 10-17-2013
https://www.rcgroups.com/forums/show...9#post26398170
Matt 12-22-2013
Video on Youtube
Mortimer 12-31-2013
gsantos_pt 03-10-2014
https://www.rcgroups.com/forums/show...1#post27742958
studioab 04-14-2014
https://www.rcgroups.com/forums/show...1#post28082470
