This thread is privately moderated by innov8tiveTech, who may elect to delete unwanted replies.
Mar 06, 2014, 01:40 PM
Trader Rating: 15
innov8tiveTech's Avatar
$220.00 USD
Seller Pays Shipping
For Sale
Scorpion S-5535-190kv brushless motor
We are selling a scorpion S-5535-190 motor that we will no longer be carrying due to newer versions available. This unit is brand new, sealed in package.
Scorpion Competition Series Brushless Motors are built from the best materials available, and are designed to provide both quality and performance at an affordable price. The new 55mm series motors have been designed to fit larger models that would normally require a 30cc to 50cc gasoline motor. Scorpion starts with high quality aluminum alloy parts that are produced on the latest CNC milling machines. These parts are then gold Electro-Plated to provide a beautiful, long-lasting finish. The stators are made with 0.2mm laminations to give maximum efficiency, and minimum Eddy current losses. The stators are epoxy coated to prevent shorts, and are wound with wire that is rated at 180 degrees C (356 F). The magnets used in Scorpion Motors are rated for operation at 200 degrees C (392 F), making a motor that is virtually impossible to burn up in normal use.
All Scorpion 55mm motors come with 4.0mm male bullet style connectors already attached, and include a complete hardware package that contains the following: 3 matching female Bullet connectors for your speed controller, a cross style backplate mount with 4 screws, a thrust washer with tapered collar, a spacer collar that allow you to move the prop forward if needed, a heavy duty prop washer, a prop nut and two prop lock nuts that have threaded tips for use with a spinner.
Scorpion Motors are built to last. For the best overall combination of quality, performance, and value, give Scorpion Motors a try!
Specifications
Stator Diameter 55mm (2.165 in)
Stator Thickness 35mm (1.378 in)
No. of Stator Arms 18
Magnet Poles 20
Motor Wind 10 Turn Delta
Motor Wire 29-Strand 0.25mm
Motor Kv 190 RPM / Volt
No-Load Current (Io/10V) 1.56 Amps
Motor Resistance (Rm) 0.024 Ohms
Max Continuous Current 90 Amps
Max Continuous Power 3800 Watts
Weight 855.6 Grams (30.18 oz)
Outside Diameter 65.4 mm (2.575 in)
Shaft Diameter 7.98 mm (0.314 in)
Body Length 79.5 mm (3.120 in)
Overall Shaft Length 126 mm (4.96 in)
Max Lipo Cell 12s
Motor Timing 5deg
Drive Frequency 8kHz
Weight including packaging
1800g
**this motor includes**
Scorpion tin
Scorpion decals
Scorpion hardware (consists of screws)
**Item is in "new" condition**
**please refer to item number SCM-1000**
PRICING:
Retail normally $ 399.99 NOW!! $220.00 with FREE USA shipping!
to purchase you can email : [email protected]
or call : 760-468-8838
** these motors include a 15 day guarantee, and have no scorpion warranty and are sold as is**
**no international addresses**
Dec 30, 2015, 05:50 PM
Trader Rating: 62
BIG LACY's Avatar
Long shot, Is there any of these left? Had to ask(lol)
Jan 04, 2016, 09:49 AM
Trader Rating: 48
jamboF4's Avatar
Haha. Me too!
