Mar 03, 2014, 11:50 AM
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
Build Log
BBCC4 Earl Stahl's Stinson 125 Voyager
As part of the BBCC4 Contest:
I'm going to build Earl Stahl's Stinson 125 Voyager, from Outerzone.
The design, at 100%, is a 31-inch span. I'm considering enlarging the span to 36-inches, and keeping the wood sizes as called out in the drawing, for a lower wing loading (and slower flight).
July 19, 2014
Apr 24, 2014, 05:12 PM
OK! Life proceeds. I got several copies of the plans printed and set up my table to begin the fuselage sides.
Apr 24, 2014, 06:13 PM
builderdude's Avatar
Nice!
Can't wait to see the progress!
Apr 25, 2014, 07:48 PM
Summit Model Aeronautics
Steve85's Avatar
Looks good, David. I've built a 36" Fairchild 24 and a 30" Hawker Hurricane from Earl's plans. You'll enjoy this build!
Steve
Apr 27, 2014, 10:50 AM
Slip the surly bonds...
Sopwith Mike's Avatar
It does look very pretty in the 3-views - best of luck for a light wind model!
May 03, 2014, 07:11 PM
Been away... before I left, I finished framing up the fuse sides.
May 03, 2014, 07:57 PM
Holy moly that's a lot of pins!!!
Looking good though!
May 03, 2014, 08:23 PM
Terrell's Law of Inertial Dampening, which states that "Nothing will move before its time" is facilitated by using the Devo Motorik Inversion "You got to pin it, before you whip it."
Pin it! Pin it good!
Devo - Whip It (Video) (2 min 47 sec)
May 06, 2014, 02:42 AM
Ad eos qui nesciunt crepitus
Old_Pilot's Avatar
Broken SE-5a
Fite's Law of Equal and Opposite Reactions......
Obnoxious Garbage Truck Driver + Crashed SE-5a = Model 1911 + 8 Rnds
Latest blog entry: Two New Birds
May 06, 2014, 09:08 AM
I remember Devo, but I always preferred the B-52s. The girls were cuter.
May 08, 2014, 07:46 PM
Fuselage base structure is framed up. Added supports for servos, electronics and battery. I'm going to rig the fuselage before adding the formers and stringers.
May 08, 2014, 10:57 PM
Looking good!
It's pretty hard to get everything at right angles like that.
May 09, 2014, 06:05 AM
I've learned that using a razor saw and miter box helps a great deal. If the ends of the cross braces are cut clean, it's much easier.
I also cut a couple of temporary bulkheads from Dollar Tree 5mm foam board, inserted them at the 30- and 60% fuselage stations, securing them with large rubber bands. They jig the sides up until I can get the first cross pieces placed.
It's still not perfect, with local variations in longeron density causing differences in curvature radius between the wide-spaced frames. But, there are still some partial frames and stringers to add that will hide the discrepancies under the aircraft skin.
David
May 09, 2014, 09:42 AM
I need a better building board.
The one I have is size-limited, being that it was the straightest cork bulletin board I could find.
What I would really like is either one of those 4 foot long balsa building boards or a metal one that you use magnets to assemble.
The 4 ft long balsa ones are continuously out of stock, in fact, I don't know why they even still list it if they can never stock them.
The metal ones, I need to just collect the magnets for and then get a good flat sheet of probably 1/4" steel, so that it won't bend easily. Then a coat of white paint to resist rusting on me.
