New waterproof Quad Frame - STEALTH2O - RC Groups
Feb 26, 2014, 10:59 PM
UFO Pilot
painlesstom's Avatar
New Product
Hey everyone. I've been working on a waterproof frame that comes apart for easier and cleaner component installation. I wanted something bigger than the Aquacopter, something visibly easy to see orientation, and faster customer service if I needed anything should I crash. I am big on prompt replies to email, and don't keep my customers in the dark. An informed customer, is a happy customer. So this frame was what I came up with, and I've been very pleased with the final product. It's got enough room for the FPV pilots out there, and easily packs 2 2200 compact 4s lipos inside. It is 585mm across, with all the screws and access cover the weight is 470g. With Turnigy 2213 980kv motors, 9x4.7 props, and dual 2200 4s, HK 30A SimonK ESC's, Naza M V2 GPS, I get 10 minutes of flight carrying the GoPro. I am a small shop and this is another hobby business venture for me, one man show here, and everything is made by hand. No automation or CNC at work here, good ole' fashioned blood and sweat made in the USA! You can order from my site www.stealth2o.com STEALTH2O@comcast.net
All frames will include pressure equalization vent for running FC's with Baro.
I look forward to hearing what all of you think!
STEALTH2O Quadcopters - It's Boat AND Bird! Stealth H2O (2 min 40 sec)
STEALTH2O Waterproof Quadcopter - Naza M Lite - Stealth H2O on the Altamaha (4 min 30 sec)
Mokai™ Jet Boat and STEALTH2O Quadcopter at Beards Bluff - Altamaha River (4 min 58 sec)
Mokai™ Jet Boats Filmed by STEALTH2O Quadcopter - Altamaha River (6 min 10 sec)
STEALTH2O Waterproof Quadcopter on the Altamaha River (4 min 27 sec)
Feb 27, 2014, 10:56 AM
Multirotor Builder!!!!!
very cool looking frame.
Feb 27, 2014, 12:24 PM
UFO Pilot
Thanks.
Feb 27, 2014, 05:56 PM
Critic at Large
craigiri's Avatar
I like it!
It would nice to test some of these in coastal waters where there is a slight chop - just to see whether it takes well to it. Maybe the higher (floating) legs you show in one pic would keep it up above normal current and small waves?
Feb 27, 2014, 06:53 PM
UFO Pilot
Thanks. I don't think little waves would present a problem, but the salt water issue is what would keep me inland. I am the aftermarket parts connection for the Mokai Jet boat, and see the carnage from corrosion all too often to make me comfortable dropping my quad in it. I'm not sure how the foamy legs would function in water, never got a chance to try them out in that capacity. My goal with them was really about some landing gear while the GoPro was under there, so I could land on dry ground. I'm sure they would provide some extra buoyancy.
Feb 27, 2014, 07:58 PM
ParagonUAV
MayMayDay's Avatar
Yes, another waterproof frame! I'm waiting for a good one to come out as I'd love to have one. Questions for you first though:
1- How is the top hatched sealed? Have you tested it to be waterproof? (in case of inverted 'landings'.)
2- How are the lipos secured? Straps that are glued to the frame, or through mounting posts, or...?
3- How easy is it to replace motors? It seems like once you glue the halves together it would be very difficult to change? (Siliconed with bolts?)
4- Material type and thickness?
5- Are you vacuum forming these yourself? If not, what method?
I'd like more of an H design, and I attempted it myself a while ago, but just didn't have the vacuum forming capabilities to make more or enough experience working with the material. If you're up for some slight redesign, that'd be awesome.
All the frames that are out there have a couple pros but usually some big cons as well. If you could take all the good and eliminate the cons, you'd be making a winner.
Feb 27, 2014, 08:30 PM
UFO Pilot
The top is 1/8 Lexan with foam gasket, secured with 4 nylon thumb screws like the Aquacopter. I have crashed nose first, inverted for 3 minutes, while I drove it like a boat back to me. No water made it inside.
Some ABS could used to make mounting points for straps etc... PVC/ABS glue works great. Since there are so many variations possible for mounting everything, and everyone has their own preference, the details of battery and component mounting are up to each builder.
Changing motors would require separating the frame, after the bolts are removed a simple twist of each arm breaks the silicone seal. It's not too bad, I've done it a couple times now. I know how to make it so motor swaps are a plug and play situation, I will share that info in a later post but it is too time consuming to incorporate into the frame design at this time.
ABS 1/16
Yes, I vacuum form these myself.
Let me know what you had in mind, if it's a popular idea I might consider it.
Thanks for input, I'm sure you figured out my answers above in red. My desire with this frame was the ability to work easily while installing everything just the way I wanted. Being able to neatly install the wires without a big hole to fill with sealer, and a shape that offered some visual orientation and unique appearance. I realize that any frame is going to have it's pros and cons, and I'm sure mine isn't going to be for everyone. But it is an option that I wanted to make available to those who can appreciate it for what it is. I am very pleased with it, it has proven to be very tough so far. I've crashed it a few times on purpose, once trying to flip it in the wrong mode, and hit a tree today from misjudging my altitude thinking I was doing a flyover and ended up doing a fly into... Broke all the props and one motor ripped free from the aluminum motor mount, frame didn't have the first scratch. I hope to have some more video soon, looking forward to showing everyone more of it's abilities.
Feb 27, 2014, 08:54 PM
ParagonUAV
MayMayDay's Avatar
Good, you're using ABS. It's one helluva strong material, I really like it. Also easy to fix with ABS solvent, as it chemically bonds the pieces back together again instead of just gluing.
What is your form out of? MDF or something else? How'd you cut the form? By hand, CNC,..?
Some of the pros of other frames that I like (off the top of my head, some you have already):
-Motor mounting bolts go through the entire arm, not requiring the frame to be taken apart to change the motor (LiftoffUAV)
-H style design for FPV (QuadH20, LiftoffUAV)
-Bolt sealed main hatch (Aquacopter)
-Clip seal hatch for quick battery changing (some modified Aquacopters)
-Removable tray for the internal components (QuadH20)
-Dome front for FPV equipment (QuadH20)
-ABS material
Cons off the top of my head:
-No front panel/option for FPV equipment (most waterproof options except the QuadH20)
-Price (QuadH20)
-Material not being ABS (Aquacopter)
-Not truly waterproof (LiftoffUAV)
-Heavy (most frames, hard to escape though)
-Customer service (Aquacopter, LiftoffUAV)
You can have a look at my old build if you'd like. Learnt a lot from it.
https://www.rcgroups.com/forums/show....php?t=1840230
Feb 27, 2014, 10:17 PM
UFO Pilot
Form is made of wood. Bandsaw, milling machine and a drill press.
Inserts could be installed to accomplish this, but it would require too much time on my part to make it cost effective. Not to mention the number of motor mounts that are slightly different sizes from each other. The builder could add an ABS disc to the underside of the motor area and add inserts themselves, I can provide the ABS and the inserts by request.
Could be possible with enough interest.
Yes
Left up to builder.
Part of the build I leave up to the builder, too many options for mounting.
I'm not in to FPV, would have to leave this up to the builder too.
-ABS material
-No front panel/option for FPV equipment (most waterproof options except the QuadH20) I orientate mine with the v facing forward, but if you fly with the flat side forward, a window could be easily added for a FPV cam to look through.
-Price (QuadH20)
I can relate.... I am a firm believer in good customer service, and while I'm aware I cannot make everyone happy.. nobody will be able to say I didn't try.
I like the ABS very much. Extremely tough, easy to work with and repair. Will check out your build later, out of time tonight.
Feb 28, 2014, 08:37 PM
UFO Pilot
Some flight video testing run time of dual 4s lipos, I was impressed with the results. Let me know what you think, enjoy the video.
STEALTH2O Quadcopter Frame Testing Dual 4s Lipos (23 min 10 sec)
Feb 28, 2014, 09:38 PM
got mine on order yesterday. I will post when it arrives.
Feb 28, 2014, 10:08 PM
UFO Pilot
It shipped this morning, should see it within a couple days. Look forward to your reaction.
Feb 28, 2014, 10:13 PM
Me too. if it is as good as the pics and video you posted . I think I will have a lot of fun with it.
Feb 28, 2014, 11:44 PM
epic4me's Avatar
H2O is too fragile and came with cheapo motors and ESC, installing the battery is a pain and is un balanced if the battery moves, flying times of less than 8 minutes, very difficult to service and very expensive
Mar 01, 2014, 08:19 AM
UFO Pilot
That is why I leave component selection to the builder, as well as installation details.
With dual 4s lipos, I got 13 minutes of flying time. But then again, the H2O is in a league of it's own. What I'm offering is a cross between the Aquacopter and Liftoff UAV, with a few of my own ideas added in.... priced in the middle.
