Feb 26, 2014, 12:07 PM
Mavlink to Duplex Ex telemetry
Mav 2 Du Ex Telemetry (1 min 33 sec)
Here is short video of Duplex Ex with my Mavling 2 DuplexEx telemetry convertor
HW is based on Arduino Mini with 328
Mar 04, 2014, 07:28 AM
Hi,
this looks very interesting for me. I want to switch from Graupner Hott to Jeti and search for a Solution to display Telemetry from the APM on the Display of the R/C Transmitter
Is there a little bit more Dcumentation available?
Greetings
Christian
Mar 05, 2014, 03:19 AM
How to build it and hex files (not sure with source code) will be available later on http://www.devfor8.com but it takes some time to finish couple of stuff and test it in flight.
Current status is :
- external device connected to same port as OSD, TX connected only so APM/MegaPirate must be configured to emitting OSD telemetry data
- hw is based on Arduino/FunDuino mini pro 5V/16Mhz with ATMega328. Besides of this is needed only one connector and one resistor (4.7k is used but can be slightly less or more)
- right now working on better support for V/A readings so board will work more like Jeti MUI and will support alarm after certain amount of mAh will be consumed
If you want to build one for yourself and use it even in alpha stage (it is not dangerous because it is read only device) leave me message and I will see what we can do with it
Mar 05, 2014, 03:59 AM
Hello Amper_CZ,
thanks for your reply.
It sounds very good.
At this time i found one Librarys available for Jeti TX.
For Reading MavLink it seems to be possible to use the MinimOSD Code.
My problem is, I can't code in C or come thing else.
To use an Alpha Version is not neccesary. I will have an look at this thread. It would be very nice if you update the State here periodically.
Regards
Christian
Mar 05, 2014, 07:12 AM
Yes, I used this library but updated it to support software serial and I also did couple of other changes. Small Arduinos have only one hw uart, used for mavlink on 57k , so Jeti com must run on software serial port - which is also my modification because standard serials doesn't support Jeti requested settings)
Mar 27, 2014, 08:18 AM
Hi,
is here something new to report?
Im am very interested in this Solution.
Greetings
Christian
Mar 28, 2014, 03:46 AM
Source code will be published till end of April. I will be on //Build in SF for first week in April so it takes some time after that.
For start , here is required BOM :
- Arduino/Freeduino Mini 5V/16Mhz ATMega 328
- FTDI or other serial interface for programing Arduino
- resistor 4.7k (or something arround)
- servo connector with wires
- MavLink capable board , sending data without requests (have to be configured same way as is for MinimOSD)
Mar 28, 2014, 03:54 AM
Hi,
what do You mean with "MavLink capable Board" ?
If i use an minimOSD and as secondary an ATMega328. Is this the right way?
Like this way:
APM Telemetry out -> MinimOSD -> ATMega328 -> Receiver
Greetings Christian
Mar 29, 2014, 11:54 AM
Mavlink capable board means board sending mavlink data out (like APM in your case, Crius with MegaPirateNG in my case). It is mentioned just for sure that people will not connect it to MultiWii protocol output or Remzibi OSD outputs.
APM Telemetry out -----> MinimOSD
---> ATMega328 -> Receiver
This is how you will have it. Take TX from APM telemetry and send it to both RX on boards. TX on ATMega328 with my code is not used.
I have it this way :
Crius Telemetry out -----> MinimOSD
---> Bluetooth board
and RX is connected only to BlueTooth
May 20, 2014, 06:53 AM
Hi,
something new here. I am very interested in this solution.
Regards
Christian
May 21, 2014, 03:28 PM
Hi,
Regards
Christian
I just published it. Not too much tested so hope that it will work
Check http://www.devfor8.com/mav2duplex/
May 22, 2014, 05:57 AM
Hi,
thanks for sharing your code.
I want to compile the Github Repository, but i get some bugs. The library "FastSerial" is missing.
I think, the following messages are based on the missing library.
I found one at the Ardu CAM Projekt, but it seem this is not the right one.
Can you please load it up, that i can compile the Code
Which Arduino Version are u used?
Regards Christian
May 23, 2014, 04:37 AM
Hi,
Sorry, I have FastSerial in Arduino libraries so I take it as standard part. It is on github, you can check it again.
Code should not have any specific required arduino version
May 23, 2014, 06:47 AM
Thanks Amper,
For me, it is working perfectly.
Maybe it is possible to send the needed packets to the APM, so there isn't the need of the MinimOSD?
May 23, 2014, 06:51 AM
Hi SwissFlix,
i have errors while compiling, but donīt know why.
Radek try to help me, I hope we will find a solution
