Feb 26, 2014, 03:22 AM
New Product
Zero UAV YS-S4 Entry-level Multi-rotor Autopilot*Owner Thread* upcoming
[email protected]
YS-S4 Multi-rotor Autopilot
For entry-level enthusiasts in dual redundancy autopilot, Zero UAV now brings out the most cost-effective solution, the YS-S4 flight control system, it inherits the high reliability and stability of YS series autopilot and opens another unprecedented era of double protection for flight control systems by combining with GEMINI-M developed by Zero UAV. The innovative All-in-one design simplifies installation and saves space and weight. It contains inner damping, controllers, 3-axis gyroscope, 3-axis accelerometer and barometer in its light and small Main Controller. It can measure flying altitude, attitude and therefore can be used for automatic control. To realize everybody's flying dream with GCS, YS-S4 can be expanded to GCS control easily by adding an extra WIFI module.
Features:
MINI All-in-one Design
Convenient WIFI Communication
Realtime Voice Broadcast
Phone Attitude Control
Advanced & Improved Attitude Stabilization Algorithm
Multiple flight control mode/ Intelligent Switching
Precise Position and Altitude Hold
Failsafe (Auto Hover-Go Home-Landing)
Low Votage Vibration Alert (Phone Terminal)
Intelligent Motor Arm/Disarm
Supporting Common receiver and PPM
Multirotor 6 Types Supported
Built-in Gimbal Stabilization Function
Remote Gain Adjustment
TECH Specification:
Supported Multi-rotor
Quad-rotor I4, X4 / Hex-rotor I6, X6, IY6, Y6
Supported ESC output
400Hz refresh frequency
Power Consumption
MAX1. 5W ([email protected])
Normal:0.6W ([email protected])
Operating Temperature
-10°C ~ 50°C
Ground Control Station Requirement
Android/Windows XP sp3 / Windows 7 / Windows 8
Hovering Accuracy(GPS Mode)
Vertical:±0.8m
Horizontal:±2.5
Max Yaw Angular Velocity
200°/s
Max Tilt Angle
45°
Ascent / Descent
±6m/s
Built-In Functions
Multiple Modes Autopilot
Enhanced Fail-safe
Low Voltage Protection
S-Bus Receiver Support
Mar 05, 2014, 07:25 PM
Sounds Good i will get One to Test it
Du you have dealers in Spain?
And is there a reason why the product is not on your webside?
Mar 06, 2014, 07:18 AM
Yes, may I have your email address which can be forwarded to the local dealer?
Because YS-S4 is not officilly release yet....but it will be coming soon!
Kind Regards
Vivien
Mar 06, 2014, 09:58 AM
i just ordered it here... http://rc-innovations.es/Multicopter...1a/Zero-UAV-S4
i hope its the real deal.. is it working with the WIFI modul?
and where can i find the manual...
Mar 06, 2014, 10:28 AM
In Germany the new YS-S4 is allready available in multicopter-shop.de.
I got one and I'm crazy about it. Very stable out of the box. No Problems to install I needed only the firmware upgrade to fix the problem with TX calibration.
The start procedure is much more better than other products. Very fast GPS-fix and the best position hold I ever had. I made a short video in youtube.
Zero UAV YS S4 V2 Testvideo 01 (5 min 10 sec)
Amazing performance. Currently I`m waiting for the manual
Best whishes to Vivien Y
Mar 06, 2014, 10:58 AM
this looks to good to be true:-D
das sieht viel zu gut aus als das es war sein könnte :-D
aufgrund dieses videos hab ich den gekauft konnte aber in dem anderen forum nicht ersehen das multicopter shop.de den auch hat... tssss
Mar 06, 2014, 11:04 AM
Glaub mir, das Teil fliegt wirklich so gut, das wird der Hammer. Du kannst die Diskussion auch im rc-forum weiterverfolgen.
You can trust me, the performance is really fantastic. No reason for me to buy any longer NASA.
Mar 07, 2014, 07:45 AM
Hmm a sponsor starts a thread and then no response... do we get a manual any time soon???
Mar 07, 2014, 09:39 AM
I got the info that it should happen this weekend. I'll wait and see. May be we should send Vivien an email or PN.
Mar 07, 2014, 11:17 AM
o just got the parcel without a manual, what is forbidden in Europe
Mar 07, 2014, 11:26 AM
This is the reason why multicopter-shop.de dont delivers for normal customer yet. I got the flight control for testing purposes and i promissed not to make trouble because of missing manual.
Mar 07, 2014, 02:33 PM
James not bond
jy0933's Avatar
any chance to upgrade for us s4v1 people?
also. mind talk about the essential difference between v1 and v2?
and I have heard that s4(v1/v2) will have a 300m radius/100m height ceiling?
Mar 07, 2014, 03:54 PM
i will also not make trouble :-D but the ver 1 manual is there what shows the important things i guess
Mar 07, 2014, 03:56 PM
limits
thats what they say, if u exceed this limits the copter will go automaticly back in this virtual cube and u regain the control, so i guess it is not to brake range records :-D
Mar 08, 2014, 06:30 AM
I am a little bit puzzled. The LED in Vivians picture has a black cover, my LED has no cover only the pure Aluminium star cooler.
