Apr 27, 2016, 04:24 PM
Originally Posted by jan brilman
Hey, glad I found this thread.
Plm. 15 years (?) ago I started with one of the Palmer designs, but that didn't work out . . .
This one really looks great (two feet of wingspan more would have made me order one immediately!)
This is my favorite color scheme:
http://www.washington.edu/news/2013/...-mercury-smog/
(Why doesn't the picture appear???)
jan.
(Netherlands)
Jan,
I pulled the image into a page by itself, not the pop-up window...
Then I was able to obtain the link to the scheme. It is found here...
http://www.washington.edu/news/files...NCAR_plane.jpg
To have it open you need to link it as an image and I don't think they allow html IMG linking on RCG...
You have to upload the image to the site to get it to display.
This prevents virus propagation I think...
Here is the image, I have attached it to the posting using the Advanced tool with the attached files box, located below the text field in that advanced tool window...
David
Apr 28, 2016, 06:45 PM
killickb
killickb's Avatar
That is a nice version -- never found that one when I was looking at color schemes. If/when mine needs a recover just might do this one.
campbelltf, if you mean flap deflection I have three position -- Up/ 10 degree/25 degree. Maybe I should have more to provide more drag and less lift and so that I can land in a flatter attitude? I cannot get more than 40 with my set up and as I almost looped when I did have 40, have never gone back to that and played around.
I suspect better piloting would also reduce the scrapping! We do have grass as well as tarmac and it does fine on the grass strip. By the way still have not tried out my 4 blade props.
Nov 26, 2016, 09:17 AM
Veni Vidi Volavi
Brian Allen's Avatar
Greetings All
Well I have pretty much so decided to get started on the C-130 as soon as I finish up a few details on the J-3 Kitten build I am working on right now. have reviewed the thread and pulled the kit out of the kit stash pile. Have also ordered some motors from Heads Up RC and have 4 Castle Talon 15 ESC's handy. So it looks like I will have all the needed goodies on hand shortly.
Will start a build thread as soon as I get started. Need to figure out a scheme, hopefully something a bit different or offbeat.
Brian
Veni Vidi Volavi
I came I saw I flew
Nov 27, 2016, 10:47 AM
Prowler901's Avatar
I can't seem to find this kit anywhere. Is it still available?
Nov 27, 2016, 10:57 AM
Veni Vidi Volavi
It is available from Brodak.
Go here for details:
http://brodak.com/electric-kits/dare...ed-martin.html
Hope this helps.
Brian
Veni Vidi Volavi
I came I saw I flew
Nov 27, 2016, 11:00 AM
Prowler901's Avatar
Ah super! I guess I was looking in the wrong place on his website.
Thanks, Brian!
Nov 28, 2016, 02:12 PM
Veni Vidi Volavi
Received my package from Heads Up RC today containing the four motors and props. Another item down!!!
Brian
Jan 04, 2017, 08:46 AM
My C-130 was completed.
I introduce some image producing.
1. The main wing and the tail assembly
2. Body part
3. used the spare parts of FREEWING F/A18 NOSE GEAR.
4. Motor, 20A ESC, 5A SBEC
5. The body did plank by 1mm balsa.
6. Only the upper part of the main wing did plank by 1mm balsa.
7. Nose part
8. USED GRAY ORALIGHT FILM
9. The painting of ABS parts
10. Assembling of the main wing
11. Linkage of FLAP
12. I made battery tray back and front for CG adjustment.
13. Here is front tray. I used 2 3S-1300mAh BATT.
14.
Completion image
The weight became 1,530 g.(Plan was 1332g)
Jan 04, 2017, 09:16 AM
Neophyte hacker
portablevcb's Avatar
That looks beautiful!
charlie
Jan 05, 2017, 04:23 AM
Very nice and fast build!
David
Jan 07, 2017, 06:46 AM
I succeeded in maiden flight.
Today,I succeeded in maiden flight.
2017 01 07 C 130 (3 min 25 sec)
Jan 07, 2017, 01:04 PM
Prowler901's Avatar
Congrats! Sure looks beautiful in the air.
Jan 07, 2017, 01:20 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
Very nice!! And a very smooth landing!!
SteveT.
Latest blog entry: My shop....
Jan 07, 2017, 02:36 PM
Wow, Congratulations!
Looked like a JATO assist takeoff. You have some powerful motors on her. More than enough for getting her out of most any issue if you need to power up and go around. Very fast flier, not really scale like but still a pretty bird in the air.
David
Apr 24, 2019, 01:49 PM
jmxp69's Avatar
2. Body part
7. Nose part
11. Linkage of FLAP
14.
Completion image
Very nice work. Thanks for sharing. I'm curious about your process on the canopy windows. It looks like you painted the entire canopy, then cut the windows out and attached a plastic sheet on the inside. Is that correct?
I realize this is a dated thread so I'm hoping someone will answer. I'm interested in this plane.
Again, very nice work.
