Help!
Dragon Link Problem (bought from RCgroups)
Hey all,
I just purchased a used combo that included a JR 9503, Dragonlink V1 TX, and 2 V1 Red 12Ch RXs all said to be upgraded to V2. I was using a friend's actual V2 setup with a futaba and everything worked great with good flight results. First off, I have verified that the tx is connected correctly via DL website and the problem is the same on both Rxs as well as an original V2 Rx. NOW FOR THE PROBLEM: I bind the new to me Rxs just fine with the new to me Tx. But channels are mixed up (ie the aileron stick moves the elevator, the throttle stick does nothing as far as I can see). JR is on PPM and ACRO default mode. Has anyone seen this issue?? Do you think think the Tx as V1 firmware on it?? Please Help! Thanks Everyone! K9 |
There were some Rx's that had the wrong channels printed on the board. Can you switch the outputs (plug the flight controls into the channel that works them) to get it to work?
Thank you for your responses!
I think I can get it to work by plugging in to the channels that do what i need. I just want to make sure there is not an underlying problem. I tried it on a V2 Rx that i know is printed correctly and they are still mixed. Thanks again guys K9 |
Wish i could delete this thread out of pure embarrassment... as a Futaba guy I had no idea JR outputs different channel assignments. See below, you live you learn!
JR 1- Thro 2- Ail 3- Elev 4- Rudd 5- gear 6- aux1 (flap) 7- aux2 (spol) 8- Aux3 9- Aux 4 10-aux 5 11-aux 6 12-aux 7 Futaba 1 - R Aileron 2 - R Ele (V-tail) 3 - Throttle 4 - L Ele (V-tail or rud) 5 - R Flp 6 - L Flp 7 - L Aileron K9 |
