Blohm & Voss Ha 139 - RC Groups
Feb 17, 2014, 01:27 PM
Blohm & Voss Ha 139
from wikipedia
The Blohm & Voss Ha 139 was a German all-metal inverted gull wing floatplane. With its four engines it was at the time one of the largest float-equipped seaplanes that had been built. The inboard engines were mounted at the joint between the inboard anhedral and outboard dihedral wing sections, above the pylon-mounted floats.
Further development of the Ha 139 led to the land based version Blohm & Voss BV 142 which had its first flight in October 1938.
General characteristics
Crew: 4-5
Length: 20.07 m (65 ft 10 in)
Wingspan: 29.5 m (96 ft 9 in)
Height: 4.8 m (15 ft 9 in)
Wing area: 130 m2 (1,400 sq ft)
Empty weight: 10,340 kg (22,796 lb)
Gross weight: 19,000 kg (41,888 lb)
Powerplant: 4 Junkers Jumo 205C 6-cyl. opposed piston diesel engines, 447 kW (599 hp) each for take-off
Propellers: 3-bladed variable-pitch metal propellers
Performance
Maximum speed: 288 km/h (179 mph; 156 kn) at 3,000 m (9,843 ft)
Cruising speed: 238 km/h (148 mph; 129 kn) (maximum) at 2,000 m (6,562 ft)
Economical cruise speed: 200 km/h (124 mph)
Ferry range: 4,600 km (2,858 mi; 2,484 nmi) at 238 km/h (148 mph)
4,950 km (3,076 mi) at 200 km/h (124 mph)
Rate of climb: 2.833 m/s (557.7 ft/min)
Armament
Guns: 4 x 7.92 mm (0.312 in) MG 15 machine guns in nose, flight deck roof hatch, and staggered fuselage lateral mountings
