This thread is privately moderated by blade strike, who may elect to delete unwanted replies.
Mar 11, 2014, 01:42 AM
Where is the power for the mini iosd and FPV comming from?
Mar 11, 2014, 09:09 PM
blade strike's Avatar
Ribbon cable no extra power is required
Mar 20, 2014, 07:55 PM
Thanks for the information and pictures, but I'm confused about one thing. You said remove the Power and Video cable. Do they really need to be removed? Does the 4 wire color cable get removed also?
Mar 22, 2014, 01:01 PM
The 4 wire color cable is what I was talking about.. That is power and video.
No this cable does not need to be removed but it would be wise to do so.
Mar 23, 2014, 08:00 PM
Does this procedure apply to Phantom V1.1.1 with upgrade kit and H32D installed?
I am looking to install the AVL58 and iOSD mini.
Mmmm...P2 has a can bus socket in the compass P1 hasn't.
Mar 23, 2014, 08:55 PM
I don't think so. P2 board has a bit more logic.
Mar 25, 2014, 09:51 AM
Here's a tutorial to manually add a CAN bus port to V1 phantom:
http://www.sarawuth.com/2014/01/dji-...-can-bus-port/
It would be interesting to confirm FPV hub can or cannot be used with V1+Upgrade Kit+H32D Gimbal because of the logic.
Mar 29, 2014, 12:06 PM
Blade I have the immersion 5.8ghz Tx. Is it possible to do this install internally so the hub and iOSD are hidden?
Mar 31, 2014, 08:27 AM
The only concern I would be worried about is the cable length from the h3-2d to the hub. The included wire is pretty short. You will just have to try it and let us know :-)
Mar 31, 2014, 12:25 PM
I ordered the FPV hub and an additional set of wiring for the Phantom 2 from All e RC.
I have a couple ideas in mind and will share photos as soon as the new toys arrive
Mar 31, 2014, 12:32 PM
Please keep us updated.. it definitely will make for a clean install.
Mar 31, 2014, 04:01 PM
The second set of cables I ordered include a 180mm Zenmuse cable - if its long enough to get everything inside, then I should be fine hiding everything inside...
Question - should I mount the Immersion Tx to the right side of the battery (if you're looking right at the battery in the Phantom? I've heard a few people mention that the left side of the battery tray may affect the vTx because of possible heat dispersement from the battery connection?
Mar 31, 2014, 05:44 PM
That I don't know.. I wouldn't think there would be heat from the battery connection though
Apr 10, 2014, 01:41 PM
Blade strike-Great write up and tutorial--helped me a bunch! While I am anxiously awaiting for my H3-3D gimbal from my dealer to arrive (who knows when they will ship) , I have the identical setup as you posted with the AVL58 TX and the FPVhub/mini iOsd. Is it possible for me to tap the black and yellow cable coming from my GoPro3+ to somewhere in this setup so that I can experience FPV today? Would splicing those wires into the VTX work?
Apr 21, 2014, 01:45 PM
Did you use velcro to attach the hub, mini iosd, avl5.8 to the p2?
Sold DJI AVL58 FPV For Phantom and DJI Hub NEW fltekdiver FPV Equipment (FS/W) 1 Oct 27, 2014 11:21 AM
