Thread Tools |
This thread is privately moderated by blade strike, who may elect to delete unwanted replies. |
Mini-HowTo
Dji fpv hub
I received my DJI FPV HUB last week so I thought I would show how to install it. The FPV HUB allows you to connect a Mini iOSD or MarkII , h3-2d and AVL58 w/o the need of soldering. The hub is super small and lightweight, I saved 5 grams by installing it. My old wire harness was 10g vs 5g of the fpv hub and ribbon cables.
Before The Install: ![]() After Install ![]() The FPV HUB is very small ![]() ![]() First thing I did was open up the P2 so I could remove the Power and Video cable. Please remove the four screws per arm. This step is not required but in my opinion you should remove the wire harness. ![]() Once all 16 screws are removed, remove the top cover and unplug the GPS. Now we need to unplug the cable shown below. ![]() Once the cable is removed, go ahead and plug the GPS back in and reinstall the top cover. I installed the FPV HUB on top of the Mini iOSD. ![]() Now just plug in the AVL, Gimbal and iOSD. Make sure you select either Video or OSD with the micro switch. When not using an OSD leave this switch in the video position. ![]() ![]() DJI does include a cable for the Mark II and a power / video out cable incase you use another brand of vTX. If you have any question or need help just post or send a PM ![]() |
Exactly what I was looking for, thanks for posting this!
No problem
You inspired me to convert my P2 over to the fpv hub.
https://www.rcgroups.com/forums/show...8#post27571275 |
Awesome Chris
![]() Makes for such a clean install imho ![]() |
A quick question as I am new to my P2 and I just bought the kit...
By removing the cable inside of the P2 In your pictures what is the cable coming out of the P2 that is connecting to the hub. Is this a new cable?? I think I am asking... where is the power coming from to power the hub and then other devices. (gimbal, iOSDmini & AVL58 I am not clear if need to plug in new cable or use an existing cable from the P2. Thanks for the help !!!! |
The only cable you need that comes from the Phantom is the gray one that connects to the zenmuse. With the hub it connects to the hub instead of the zenmuse. The a supplied cable goes from the hub to the zenmuse. Another supplied cable goes from the hub to the avl58 and another to the iOSD mini. The red, yellow, brown cable that comes out of the Phantom can be removed. I hope that makes sense :-)
on off subject... with DJI Zenmuse H3-2D Gimbal is it an issue doing compass calibration and the gimbal on... will this hurt the gimbal motors when one turns the P2 on the side and rotates for the calibration procedure??
I tend to do a calibration before each flight due to new locations. |
Thanks for posting this tutorial blog entry!
One small improvement would be to edit your text regarding the ribbon cable removal to make clear that it is the 4-wire multi-color cable that is to be removed. The circle in the picture could be mis-interpreted to include both ribbon cables. Steve |
Thread Tools | |
Similar Threads | |||||
Sold | DJI AVL58 FPV For Phantom and DJI Hub NEW | fltekdiver | FPV Equipment (FS/W) | 1 | Oct 27, 2014 11:21 AM |
