This thread is privately moderated by Nitro_Nancy, who may elect to delete unwanted replies.
Feb 14, 2014, 01:46 PM
Video
Unboxing Nitroplanes Pitts 12 VIDEO!
Unboxing: Pitts 12 (12 min 16 sec)
If you are a bi-plane fan you will know the Pitts arguably one of the best. The Pitts 12 is unbeatable in stability and precision flight characteristics and is certain to please all pilots from beginners to seasoned competitors. Designed to perform its best in precision and 3D style flight, it is definitely a top competitor compared to other planes in this class. The plane was blueprinted from the ground up to be a top performing aircraft. Constructed of balsa wood and fiberglass the plane is light and nimble with generous control surfaces permitting effortless maneuvers. This plane has a wing span of 1462mm which is just a tad less than 58inches. If built with the recommended power setup, the plane yields an awesome power to weight ratio that will give you the confidence in those hair raising maneuvers.
Features:
Completely covered, hinged, ready for final assembly semi-scale airframe
Pre assembled and temperature treated canopy
Big round pre-painted and trimmed matching fiberglass cowl
Covering scheme matching wheel pants
Light, durable and strong landing gear
Thoughtfully complete hardware package
Specifications:
Fuselage length: 1413mm
Wing Span: 1462mm
Wing Area: 43.2dm2
ARF Weight: 1550grams
