Feb 12, 2014, 04:48 PM
RFC Cadet
Guy Fawcett's Avatar
Build Log
Fokker V 23 in 1/6 Scale
Just wanted to start a thread about my latest project a my own design for a Fokker V 23 in 1/6 Scale.
Motor: AXI AC2826/12
Battery: A123 LIFE 2300mAh; 3 series x 2 parallel cells
Speed Control: Castle Creations Thunderbird 36
Drive System: APC 13 x 10 electric
Wig Area: 479sq.in;
Projected Weight: 76.8oz RTF;
Wing Loading: 23.1oz/sq.ft
Feb 12, 2014, 04:51 PM
I never saw one of these, ought to be fun!
Feb 12, 2014, 05:32 PM
RFC Cadet
Major components assembled. Landing gear next
Feb 12, 2014, 05:40 PM
RFC Cadet
Start of the landing gear and sub wing. Sub wing is built with the same technique as the main wing.
Feb 12, 2014, 09:17 PM
vonJaerschky's Avatar
Nice, Guy. Certainly something different! A good sized model, too.
Feb 12, 2014, 11:25 PM
Martin Irvine's Avatar
Nice to see you back building, Guy. But why such an ugly plane? And only one wing?
Martin
Feb 12, 2014, 11:58 PM
RFC Cadet
Hi Martin
Because I wanted to use foam core and be scale.
It's not nice to be mean to other peoples airplanes
At least it is WWI my other stalled project is a Yak 9D
My son Alex wanted a demonstration of the building technique to be used on a 1/6 Scale Ki-61 Hein.
Guy
Feb 13, 2014, 08:13 AM
Guy,
Where did you find the plans, or did you derive them from scanning parts of the 1/48 plastic kit?
Jim R.
Feb 13, 2014, 11:02 AM
RFC Cadet
I found the instructions for the Omega Models Resin kit online which has three views of the real plane included. These drawings were traced in TurboCad and corrected so that all views matched each other. Then using my knowledge of Fokker construction and bits of Fokker D VII three views I filled in the the missing information. After the the three view was corrected I designed the model.
Feb 13, 2014, 06:44 PM
Captain Dunsel's Avatar
Very nice, Guy, and very creative!
CD
Feb 16, 2014, 05:36 PM
cbalgra's Avatar
Guy,
Great choice of aircraft. I love obscure airplanes myself and am always looking for unusual subjects. I was looking for something simple to build with equipment I had on hand, and just recently narrowed it down to the V-23 also.
The hardest part was finding specs on the V-23. The Omega Models resin kit was my launching point for starting on a 1/7 scale V-23. I plan on using 3mm and 6mm Depron, with a bit of balsa and ply. 50" wingspan, 43 1/2" length. Emax CF2822 motor, 9x4.3 sf prop, 3S-2000mah lipo.
A question that I had from looking at your photos is, did you scratch build the wheels or did you purchase them? They look lightweight compared to a Williams Bros. type WW I wheel. If scratch built, could you please describe how they were constructed?
Thank, Brad
Feb 17, 2014, 01:19 AM
RFC Cadet
The wheels are scratch built and I will try to put together a little how to shortly.
