Cheerson CX-20 CX20 Auto-Pathfinder FPV RC Quadcopter With GPS RTF - RC Groups
Feb 12, 2014, 09:42 AM
TS Banggood RC's Avatar
New Product
I start this thread to introduce a new product to you guys:Cheerson CX-20 Auto-Pathfinder FPV RC Quadcopter With GPS
Only $254.99 at BG
Headless Mode:
Description:
Control distance: about 300m
Flying altitude: about 300m
Charge mode: Switching Power Supply
Charging time: about 2 hours
Flying time: about 15 minutes
Functions: GPS hold system, auto-return, up and down, forward and backward, side-flying, left and right turning, hover.
Features:
Attractive and highly integrated design
A compact and highly integrated design means that it is easier for you to pack it into your backpack. The streamlined design brilliantly reflects the aesthetics of its industrial design and the fantastic visual effects allows you to become the focus of the crowd. Moreover, you can mount a GoPro or other light and handy cameras on your Auto-Pathfinderto shoot some footage from the air which will bring you a brand new travel experience.
Read to fly design
The hardware mounting and software tuning are all done prior to delivery. The Auto-Pathfinderis ready to fly the moment you unpack it, you just need to attach propellors, charge the LiPo and install the transmitter batteries before use.
Contains remote control unit.(Just add 4 x AA batteries)
Auto-Pathfindercontains a remote controller and receiver, which help the user to completely avoid the inconvenience of purchasing such things. The only thing you need to do is to add TX batteries (4x AA dry cell). The 2.4 G ISM frequency makes the effective control distance up to 300 meters (can be impacted by the specific flight environment). The frequency hopping anti-interference design allows multiple remote controllers to work at the same time, and provides a reliable remote communications link.
Stable,yet agile performance,easy to fly
Auto-Pathfinderhas an integrated flight dynamics system, the MX + GPS multi-rotor autopilot system, as well as the dedicated remote controller and receiver. Flight parameters and functions have been setup before delivery, so you can fly your Auto-Pathfinder the moment you receive it. The proven stability of the MX autopilot system allows you to easily achieve great flight performance.
Two flight control modes,including position hold
With the built-in MX autopilot system plus a GPS module, the Auto-Pathfinder has GPS Attitude and Attitude Control Mode. Pilots can switch between the two modes to achieve a particular flight experience.
Intelligent orientation control(IOC)
Auto-Pathfinderalso has the Intelligent Orientation Control (IOC) function of the MX autopilot system. Usually, the forward direction of a flying multi-rotor is the same as the nose direction. By using Intelligent Orientation Control (IOC), wherever the nose points, the forward direction has nothing to do with nose direction: In course lock flying, the forward direction is the same as a recorded nose direction. In home lock flying, the forward direction is the same as the direction from home point to the multi-rotor.
Failsafe & auto go home/landing
Auto-Pathfinderalso has the failsafe function of the MX autopilot system. This means when the communication between the Mx Controller and the transmitter is disconnected, the outputs of all command sticks from controller will go to the center position. If the GPS signal is good enough, the system will automatically trigger Return To Home and will land safely.
Low voltage protection
Auto-Pathfinderalso has two levels of low voltage protection, a function of the MX autopilot system. It prevents your multi-rotor from crashing or other harmful consequences caused by low battery voltage. In the first level of protection, the LED indicator blinks and makes a sound of “Bi-Bi-Bi” to warn you. In the second level protection the system will trigger the Auto-Pathfinder to land automatically.
Maximum flight speed 10m/s
The maximum horizontal flight speed of the Auto-Pathfindercan reach 10m/s and the maximum vertical speed is 6 m/s. The perfect combination of speed and stability allows you to experience the glamour of Auto-Pathfinder.
High intensity led lights,to aid orientation during flight
Under each arm of the Auto-Pathfinderthere are some high intensity LED indicators which are used to help you to see the orientation during flight.
Gopro camera mount(camera not included)
Auto-Pathfinderhas an external removable camera mount for you to mount light and handy cameras (GoPro for example) or other video shooting electronic equipment. It is very convenient for you to record your flight.
10 to 15 minutes of flight time
Auto-Pathfinderincludes a 3S LiPo battery (with the capacity of 2700mAh, weight only 180g) and a balance charger. With the all-in-one design and light airframe, the flying time could last 10 to 15 minutes which will give you a more extensive flight experience.
Package Included:
1 x CX-20 Auto-Pathfinder RC Quadcopter
1 x Transmitter
1 x Battery
Feb 12, 2014, 10:13 AM
Thanks Aaron,
The new walkera ilook camera with built-in 5.8Ghz Tx seems interesting as well....
http://www.banggood.com/Walkera-FPV-...-p-916734.html
Feb 12, 2014, 05:43 PM
Quad Erat Demonstrandum
scousethief's Avatar
Does look interesting, Phantom clone i take it ? ill wait for a few reviews first
Feb 12, 2014, 09:37 PM
Originally Posted by bonzer2u
Thanks Aaron,
Yes,It is more cheaper than Gopro.I am looking forward to it
Feb 13, 2014, 07:16 AM
Hi
It seems to be interesting
But who is Cheerson ? I don't find any website or other info about them
When should it be available ?
Feb 15, 2014, 05:16 AM
Originally Posted by CyberFox
Hi
Cheerson is a factory of RC.
I don't know the direct date when it will be in stock ,But we will be the first.
Package including:
Description:
Feb 15, 2014, 07:48 AM
Took the plunge and made a pre-order.
Feb 18, 2014, 07:36 PM
Shawn Dean's Avatar
CX-20 Auto Pathfinder Quad copter
Don't think so, Banggood your not the first , we had them, we lead, others follow , as in UK already for a few weeks
Feb 19, 2014, 09:34 AM
So I have ordered one of these - not a pre order (im the sold 1 guy) and will post as much info about it when it arrives as possible. Im not paying an extra Ģ100 just to have a UK dealer sell it to me. Price Ģ299.99 from a quick web search or 209 from Bangood at the time of of purchase.
In Stock Date : Pre Order for Dispatch 6th March 2014
Shawn if your the first where are all your reviews, web links, details ect to help the community? Also where in the UK are they up for grabs?
Feb 19, 2014, 10:03 AM
I spent a couple hours trying to find the elusive UK dealer that was delivering vaporware. No luck. I got the same news as far as release date from every source I found; including those who pre-ordered house branded units. There is an EBay vendor also selling from an empty shelf for $419USD.
Feb 23, 2014, 06:28 AM
Always Excel >>>
BenHayat's Avatar
Package including:
A few questions:
1) Can you add Accessories/parts to your webpage? Like Props, Props guard, and ect.
2) Is it possible to use a bigger battery than 2700?
3) When is it shipping?
4) What the ESC and Motor power?
Feb 23, 2014, 01:20 PM
Feb 24, 2014, 05:11 AM
baxter's Avatar
I canīt read battery miliamps, do you know the size of the battery?
Feb 24, 2014, 05:18 AM
From the info above:
Auto-Pathfinder includes a 3S LiPo battery (with the capacity of 2700mAh, weight only 180g) and a balance charger. With the all-in-one design and light airframe, the flying time could last 10 to 15 minutes which will give you a more extensive flight experience..
