Feb 10, 2014, 05:25 AM
DJI Lightbridge - 2.4G Full HD Digital Video Downlink
DJI Lightbridge will start shipping during February 2014. We will only have 500 units available this month so get your pre-orders in as soon as possible.
DJI Lightbridge is an all new revolutionary 2.4G Full HD digital video downlink. DJI Lightbridge offers extremely powerful equipment packed into a small and light-weight form factor. By offering 1920 x [email protected] video data transmission from up to 1.7km (1.05miles) away, it's the ideal solution for the professional aerial photographer and FPV users. Set yourself free and remove the limits from low definition analog video transmitters.
Please click and watch the Introduction Video:
http://www.youtube.com/watch?v=1ZN1_zq_S2k
Features:
[email protected] input and [email protected] output
Extreme Long Distance Transmission
-Less than 100mW ground unit transmission in full compliance with CE and FCC certification
-5dBi omni-directional antenna offers an enormous distance of up to 1.7 km (1.05 miles)
-Optional 14dBi patch antenna boosts transmission distance tremendously to 5km (3.1 miles)
Multiple Input And Output Connections
-AV input
-HDMI input
-DJI Zenmuse gimbal input (Digital Video/Power Supply/OSD Data)
-HDMI HD image output
-USB 2.0 image data output for iOS and Android phones and tablet synchronization
Built-in Remote Control Link
-Uplink remote control transmission and downlink video work simultaneously on 2.4GHz.
-Remote control data travels to the uplink via the TX-Thru Port at the same time that video is streamed back down all without interference.
-Support for two remote controls: one for flight control (10 Channels) and the other for gimbal control (6 Channels). Control signals are received in the air and then transmitted to the flight controller through D-BUS.
-When used with a non-2.4G radio transmitter, video only transmission operation is supported. The DJI 5.8G radio transmitter is recommended.
Strong Anti-Jamming Technology
-Frequency Hopping Spread Spectrum(FHSS) + Direct Sequence Spread System(DSSS) technology is used for uplink transmission to enhance stability and offer anti-jamming capability.
-MIMO multi-antenna technology and OFDM modulation methods along with advanced algorithms are utilized for downlink transmission to enhance data bandwidth, improving dynamic performance and increasing stability even in harsh environments.
-Channel interference is constantly monitored during downlink transmission with automatic switching between 8 channels for the best possible signal.
-Up to 8 downlinks can be connected for parallel streaming and work independently without interference.
Low Latency Transmission
Maximum latency of up to 80ms
Built-in OSD (On-Screen Display) Function
-No additional equipment required for OSD functions when used with A2/WooKong-M/Naza-M V2 flight controllers. Flight parameters will be displayed onscreen.
-OSD functionality can be turned off via mobile software for HDMI and iOS/Android Output.
Must Work With DJI Multi-Rotor Flight Controllers
-DJI A2, WooKong-M and Naza-M V2 flight controllers
-Phantom 2, with DJI 5.8G radio transmitter.
Multi-device Operation Mode, Stable and Reliable
-A single air unit can transmit to multiple ground units sending video to multiple screens. (Only one of the ground units can send a control signal while additional ground units will only be able to receive a video signal)
-Encryption ensures only authorized devices can receive data which can be programmed via mobile device software.
Built-in High Capacity Battery
-Ground unit has a built in high capacity 4000mA battery offering up to 4.5hours of use per charge.
-Rechargeable through the supplied charger or via a 3S~6S Li-Po power battery.A full charge takes approximately 1.5 hours.
-LED battery level indicator
-Also functions as a USB charger for mobile devices prolonging the life of peripheral equipment.
Electromagnetic Interference Shielded Structural Design
-Aluminum alloy casing
-Extreme internal and external shielding for interference protection.
Feb 10, 2014, 05:28 AM
Price?
Feb 10, 2014, 05:45 AM
How do you get HD out of the Zenmuse?
Feb 10, 2014, 06:07 AM
boustany's Avatar
It says DVSB for DJI Gimbals under Video Input but I'm not sure what that is and couldn't find much info about it online.
Any idea what that might be? HD bus from the Zen I hope
Feb 10, 2014, 06:13 AM
gardenroute's Avatar
Why is advertising on this device in the thread for Phantom 2?
It is possible "DJI Lightbridge" to operate with P2 and its seeds Tx? And how please?
How do I get HD out the gimbal Zenmuse H3-2D?
Why is not the product anywhere on the web DJI.COM? Or are different "DJI" now ?
Feb 10, 2014, 06:50 AM
I guess DJI has absobutely figured it out, otherwise they won't release the function.
Feb 10, 2014, 06:52 AM
Maybe you're right, Boustany!
Feb 10, 2014, 06:53 AM
zzr
zzr
DEAF-POWER
zzr's Avatar
Where is TX unit installation? i.LINK or video input from Zen GCU or iosd?
Description:
Feb 10, 2014, 06:54 AM
Originally Posted by GhostMaster
Price?
I translated the texts from Chinese forum, the price will be released very soon as DJI promised! Let's be patient! Hope the price is rather reasonable.
Feb 10, 2014, 06:57 AM
From the feature list above, it tells it can work with Phantom 2 and Naza-M V2.
I think the HD output should come from the camera directly. If you use 5.8G video downlink, you also use the video output from the camera directly, right?
Feb 10, 2014, 07:03 AM
The video comes out from the camera directly, the cable is very soft, and it won't affect gimbal function.
The website is still under maintanance, will release it when it's ready. Thanks!
Feb 10, 2014, 07:04 AM
Price?
We will release the price very soon, and it will be very reasonable.
Feb 10, 2014, 07:35 AM
When will the manual be available?
capman231
Feb 10, 2014, 08:12 AM
Thanks.
Feb 10, 2014, 09:01 AM
Launch the drones ...
Is that dual diversity in the ground system?
Could it be improved by adding CP antenna? Or is adding the patch the only improvement possible?
