Mar 18, 2020, 09:56 PM
Too old to rock-n-roll...
TooJung2Die's Avatar
The Simple Scout is a blast. I've built several FT airplanes over the years and the Scout may become my favorite. I made a few changes, mostly cosmetic. I eliminated the bat-wing trailing edges and rounded the rudder. I extended the turtle deck to the tail and lengthened the cockpit section. Then I closed off the nose. The landing gear is a soldered wire frame with soda can wheels. It balances perfectly with a 1500 mAh 3S battery. Motivation comes from a 2212-2200KV motor and 8x4 prop.
Description: Name: cropIMG_1876.jpg
Description:
Simple Scout (1 min 37 sec)
Jon
May 23, 2020, 12:58 AM
crash expert
Made these 2 with my son.
They are good fun to make
Jun 16, 2020, 09:50 PM
Aura 5 AFS stabilizer
Attachment 13289523 Attachment 13289525
https://www.youtube.com/watch?v=Tyr3ZL2q3V8
Jon
Nice plane ! Iím just in the process of building mine but Iím looking for somewhere convenient to mount the FT Aura 5 stabilizer/ receiver .........any ideas? Out side the fuse ( a bit ugly ) is easy or is there somewhere accessible in the fuse?
Has anyone put an Aura 5 in the Simple Scout ?
Jun 16, 2020, 10:07 PM
The Simple Scout has a big fuselage. There's plenty of room for the Aura, no problem. Don't use the power pod, it takes up too much room. I glue in the firewall and add a shelf to Velcro the battery to.
Jun 17, 2020, 05:43 PM
Aura5
Ok sounds like an idea, thanks.
Jun 18, 2020, 04:23 PM
Retired USAF
Cobra1365's Avatar
Originally Posted by jhsa
I have been also searching and found the Emax 2215 /09 or the 2215/12. They seem quite powerful for their size, and also cost nearly half of the price of the ones Graupner sells :O
Brushless can rotate on either direction as far as I know, so no need for CW or CCW motors, if that exists in brushless motors.
If you havenít found them yet, try AMain Hobbies. I picked a couple up for my 337 build.
