FliteTest Scratch Builds. (whose building them)? - Page 132 - RC Groups
May 16, 2018, 05:58 PM
Scratch Builder
TrooperCooper's Avatar
OK so I went out to fly my baron today, but it seemed a bit sluggish power-wise. The battery was not fully charged, at 12.0 Volts, and it's 88 degrees. I am thinking that I am just used to flying in 30-60 degree weather. It seemed a bit sluggish on level flight, as well as not having the vertical performance that it used to. Is this just the temp, or electronics wearing out? Keep in mind, I am referencing this to my old bloody baron, which was not coated in wrapping paper and packaging tape, but had all internal paper still attached. Anyone wanna give their .02?
May 16, 2018, 06:15 PM
60 years of RC flying
Daedalus66's Avatar
LiPo batteries perform better in warmer weather, so thatís not it. Starting at 12.0 instead off 12.6v is going to take off a bit of the initial boost, but we usually spend most of the flight between about 12.2 and 11.7, so the performance should just feel normal.
The electronics donít wear out (they just fail!) but the motor bearings certainly decline with age.
The biggest factor in diminished performance is usually a weak motor combined with a gain in weight. What does the new one weigh compared to the old one?
Looks very nice. I must try one.
May 16, 2018, 06:24 PM
what motor are you running and with what prop. I've had this happen to motors that were overproped. you get a runaway condition that eventually let's the smokey out. the temp goes up , this effects the magnetic strength which in turn effects the Kv which goes up which then causes more current to be drawn which causes more heat etc.
If the magnets get too hot they get permantly damage, which can result in lost of performance.
Seen that happen with my pixxa box flier and an emax motor I had, changed to a larger prop, performance was great for a while then it wasn't so great, I swapped motors but it was too late, the windings already showed signs of overheating, it shorted out when I tried to use it on a smaller foamie.
May 16, 2018, 06:26 PM
weight gain is defiantly going to effect perforamnce. it's surprising how little weight can make a big difference. I built an Ft mustang and used masking tape instead of packing tape (I use hk foam for building instead of foamboard) it flew but seemed to lack performance. I removed as much of the tape as I could. it left the airframe weak but it flew much better.
May 16, 2018, 07:54 PM
Scratch Builder
Yeah, I didnít figure it was the lipo. I figure it is the warm weather, making lift harder to make. Unfortunately, My scaleís battery went dead, so I have no way of knowing the weight, but I can compare that to the one on the Build website. Thanks.
I am running the stock Power pack C from FT. Emax BLheli 30A ESC, Emax GT2215-09 1180kv, with a 9*4.5E APC prop. Defenitely not overpropped, if anything underproped. The motor was not even warm after 30+ seconds of full throttle, so I think that rules out motor problems.
Come to think of it, I did have some issues with the esc after i tried the prop brake, which i guess overheated it and caused power loss to the motor. Could be the esc. Got an extra, will try that.
This here is my WORST fear. I removed the paper from the fuselage intirior and the fuse doubler, lightening it a little, i hope it made up for the wrapping paper (very light and thin) printed iron cross graphics (printer paper, trimmed to graphics, also very light), and packaging tape (not reenforced, pretty flimsey by itself. I will test the AUW and compare to the FT article. Thanks
Thanks guys!!
May 16, 2018, 08:00 PM
Scratch Builder
Yes, everyone needs one! At least build one of Sponzís Baby Baron. 60% the size, same characteristics, even a bit faster.
May 18, 2018, 05:41 PM
Scratch Builder
Ok, so I just finished decaling up my baby baron, using the same gift wrap paper as my bloody baron, just without the layer of packing tape, here are some pics, both included for reference.
Prayers to those in Texas and Hawaii today.
May 19, 2018, 01:20 AM
very nice
May 19, 2018, 09:33 AM
Scratch Builder
Originally Posted by 33joe
very nice
Thanks. Just waiting on some electronics. Anyone think that a 9g servo will work? It calls for 5g, and 9 may be a bit overkill, but i worry about the weight, and dont wanna order 5g servos.
Also, my full sized Baron weighs in at a whopping 15.3 oz. The reccommended weight from FT was 10.7. I still dont think this should be much of a problem. Might go to Hobbytown tomorrow, and might pick up a few props to test out on it. Maybe 9*6 or 10*5. Maybe even a speed prop.
May 20, 2018, 01:16 PM
Scratch Builder
Did some modifications to the power pod, added a lighter X6R reciever, with outer shell removed, as opposed to the overkill X8R. Saved me about 3 oz of weight.
