Feb 08, 2014, 12:36 AM
L16-R 50mm linear servos are in!
We have just received our first small shipment of L16-Rs!
L16-50-35-6-R - 50mm 35:1 gearing
L16-50-63-6-R - 50mm 63:1 gearing
L16-50-150-6-R - 50mm 150:1 gearing
Available online now!
store.firgelli.com
The L16-R will also come in 100mm and 140mm stroke lengths. We should have the first 100mm units out next week.
Latest blog entry: New Branding
Mar 06, 2014, 07:24 AM
MaHö's Avatar
Hello,
do you guys think its possible to change the CARF Mig 29 gear to your electric actuators?!
Here are some pic.
http://www.rcuniverse.com/forum/atta...7&d=1375362682
http://www.carf-models.com/public_ca...structions.pdf
Main and front gear lock only with the cylinder pressure.
Does the actuator accept landing shocks with the plastic parts?!
To have high forces you have to take the 1:150 version, but that is really slow.
I´ve found a german dealer for your actuators.
Thanks for infos,
regards Martin
Mar 06, 2014, 01:16 PM
Hi,
While I think it would be possible to use our actuators instead of pneumatic or hydraulic cylinders for such applications, I do worry about the weight and shock they would have to bear on landing breaking the drive nut, which would cause the actuator to collapse.
[email protected]
