Dream-Flight Libelle DLG - Page 131 - RC Groups
Feb 11, 2018, 08:18 PM
PGR
PGR
Low AltiDude
PGR's Avatar
Originally Posted by tupeloflyer
Update on dream flight battery pack, I might have made a mistake and started using it straight out of the box without charging first? Now that Iíve charged it and used it, and charged it again the problem seems to have gone away..... I think it just needed cycling a couple of times?
The Dream Flight NiMH battery packs are not made with Low Self Discharge cells, so I can pretty much guarantee you that the pack was nearly dead when you started using it.
Pete
Feb 12, 2018, 05:49 AM
Cloudrider
DF’s stock battery for the Libelle, what kind of flight times are y’all getting? I’ve had mine on the bench testing mixes and setups till my rx started to brownout? Doesn’t seem to take very long, kinda concerned about a maiden at this point? Any ideas?
Tupel you need to properly cycle the new battery, the capacity does then come up to specs. But you should do this carefully, at minimal current for best results. 50mA or less where possible. I've found the same issue on a number of the packs when I build them for people.
Cheers Paul. UK
Feb 14, 2018, 05:21 PM
Dixie Sky Devils
tupeloflyer's Avatar
Anyone with any launch mode mixes and or any other mixes that work well for you with the Libelle, Iím all ears, or eyes rather...
Feb 14, 2018, 05:24 PM
fly2bob's Avatar
If you have a 3 position sw, utilize it.
Middle is neutral, up is 1/16" reflex, down is 1/'8" camber.
Launch in reflex, push over at the top and take it out.
When you find lift, use camber.
Feb 16, 2018, 03:36 PM
-=BS=-
BlazingStar's Avatar
My Libelle went together very easily.
The hardest part was sticking on the wing reinforcement tape - even with the wet float technique.
Using the standard flight pack I was encouraged to see a weight of 279g...
Then I tried to balance it! It took 29g if lead in the nose! So now it’s a porky 308g
Oh well...
Feb 16, 2018, 03:59 PM
fly2bob's Avatar
You might be able to take some of that out, especially if you can move it any forward, as you trim flight it.
Yesterday, 03:40 PM
Dixie Sky Devils
Flew my Libelle for the first time today. I was quite surprised at the altitudes I got with some very light throws! Had to remove one 1/4 oz weight after I thought the cg was dead on, and the glue joint on the vertical fin to boom broke loose on a accidental asphalt landing, but other than that I liked it for my first attempt at dlg. I added a small square of fiberglass around the boom to the vertical fin, I would highly recommend that if you donít plan to catch it every time. You donít need any up elevator dialed in for launch, it goís up just fine without it, a small amount of reflex is ok, and Iím a lefty and I found just a little left rudder on launch helped straighten it out. I can see it would be easy to get hooked on this! Probably will see a better dlg in my future
Yesterday, 06:36 PM
-=BS=-
Did a few test glides today on a breezy afternoon and experienced DLGers recommended I leave the CG alone for now.
Seems balanced and the trim is good.
Now on to learning how to throw and catch properly.
Unfortunately all that nose weight will have to stay.
Yesterday, 07:17 PM
-=BS=-
Flight profiles on DX9
How do I get the DX9 programmed for flaps?
Iím in the right menu, but must be missing something because itís not working
Mixing menu
AIL>FLP
Switch set to throttle stick
Position 0 (throttle all the way down) and dial in the %
But I donít see the ailerons responding
Thansk
Sold Dream-Flight Libelle DLG BNF seng30904 Aircraft - Sailplanes (FS/W) 2 Feb 27, 2017 09:25 PM
Sold Dream Flight Libelle DLG Hitec Servos (Flight Pack) ShoGinn Aircraft - Sailplanes (FS/W) 2 Feb 05, 2017 09:33 PM
Sold Dream Flight Libelle DLG - Local Pickup only kwoknet Aircraft - Sailplanes (FS/W) 0 Jan 04, 2017 08:43 PM
Sold Dream-Flight Libelle DLG // Battery, Spektrum RX, Hitec HS-35HD servos moteasa Aircraft - Sailplanes (FS/W) 4 Aug 04, 2016 09:28 PM
