DJI Lightbridge any info?
Not sure if anyone has posted about DJI Lightbridge. Is this a real product?
1920*1080 video on 2.4 Ghz 1.7km range. Find more "info" (translation required) http://bbs.5imx.com/BBS/forum.php?mo...extra=page%3D1 |
The video in that link looks very official.
I don't see why anyone would fake it, there are other Full HD wireless transmitters available. The chinese is quoting 8W consumption for the aerial end, which is pretty beefy for a 2.4GHz system. Will be very interesting to see the cost for this. I would expect in the order of $1-2k at least. |
From the diagram, it looks like a combo control/video transmitter/receiver that completely replaces the antenna in your transmitter? On-board module sends telemetry back to the ground station, and the ground station has multiple video out, as well as two hard connections for an rcTX and a gimbalTX? And because the video/tx signal is combined in a single digital stream, there's no clumsy frequency separation like the Phantom, everything is an integrated 2.4ghz?
I gotta say it's pretty damned exciting. DJI living up to the "innovation" in its name? |
it's indeed a killer setup , an every aerial photog wish for
There is an app
https://play.google.com/store/apps/d...=com.dji.video |
I wonder what a unit transmitting 100mW needs 8W coming in and a fan for. It probably has an "FCC mode" for ISM compliance, but under normal use it's full blast, 1W transmission or more.
Is there documentation on the tx? My guess on an ideal setup would be that you can use ANY gimbaled analog controller, 2.4ghz or otherwise, as long as it has the appropriate output, and the light bridge will take the signals from the pots and encode a digital tx signal to include with the video control signal. Combining everything into a single 2.4ghz transmission would be the best way to integrate all of these separate signals. |
It would be great if it works with the H3-2D though, not sure whether the video output via the rear auxiliary port of the Gopro is in HD though.
From the video, it does look like it was connecting to the Canon 5D via HDMI cable. If it does, I can see this being used in a normal video production for normal cameras if there is a need for wireless monitoring. Kinda like what Teradek is offering, but cheaper..hopefully. |
To be honest most of people are flying within 100 meters, and for this, 200mW in 2.4GHz is more than enough.
It's not made to fly far obviously, curious to see what this "HD1080" looks like at 1700 meters, I bet for a very heavy compression and very little FPS. If the system is smart it will probably adjust on the fly with whatever bandwidth is available. |
