Dec 29, 2014, 10:09 AM
Originally Posted by AndreiD
hello all
i just received a sj4000 without SJ logo on it
it seems to be oem version
in menu/version is 20141122V02 SJCAM-SJ4000
the problem is that the image quality is very bad
day light image and video are over exposed and even if is it set on 1080 FHD the resolution look lower than this and also the image is not sharp
in low light all the image and videos have a yellow hue
any ideas please ?
i downloaded some firmware versions but didn't try them yet
thank you
i tried several firmware versions but they don't work
no i can not start the camera
please help
thank you
Dec 29, 2014, 02:04 PM
Another great day with SJ4000.
I had it installed on H3-3D gimbal and after coming back home I discovered that accidentally I pressed zoom option (or rather tight -gopro3 designed- gimbal pressed that).
So my whole video looks like someone just digitally zoom it 4x.
I hate moments like this one.
Any one here had similar issue?
Is there any hope to fix this video? (probably not )
Dec 29, 2014, 05:51 PM
Few issues I would love to get help with
Hey all ,
Just read about 100 pages of this thread and finally gave up and decided to ask.
So , I've bought my SJ4000 in ebay here : http://www.ebay.com/itm/261673962247...%3AMEBIDX%3AIT
it looks legit based on the tutorial I've found like the one in the actual sale.
The camera came with : N20140902v01 and (apparently) old UI (photo attached).
so :
1) I've tried to update to 20140929 Firmware , liked the UI but unfortunately my OK button stopped working (like few of the members here had) - What's the best and newest FW for those type of camera with bad wiring?
2) My battery case is virtually impossible to open , I have to use 2 plastic tools in order to open it which is ridiculous , If I can barley do it at home on my table in my comfort zone , how would I be able to do it when out in the field? (known issue?)
3) when I shake the camera there's a noise like something is loose inside the camera (known issue?)
so? is it fake? is it genuine but low quality? should I return it?
I would very much appreciate any help with my issues.
Thanks guys.
Dec 29, 2014, 05:59 PM
The screen doesn't look anything like the 4 SJCAM 4000 wifi I have seen.
Dec 29, 2014, 06:01 PM
But maybe older versions looked like that.
Dec 30, 2014, 01:51 AM
Hey all ,
S
Thanks guys.
1 Best to use firmware version that came with camera.
2 When you put battery in case leave tape on battery outside battery door. Not very elegant but it works. Otherwise put a loop of cotton around door before shutting door then you can pull this when opening.
3 Mine has a tiny rattle too
Dec 30, 2014, 03:27 AM
please help
thank you
nobody experienced same problem ?
the firmware that was on the camera was very new 20141122V02 (strange)
i can't find it nowhere to restore it
Dec 30, 2014, 04:30 AM
ukbren's Avatar
I have this philosophy when it comes to these things: if it ain't broke, don't fix it. the f/w on mine is from September and it'll stay that way even though there is a newer one available. even sjcam's firmware pages don't give any detail on what the firmware updates contain and why you should or shouldn't upgrade to them. unless you're trying to solve a "problem" then there's no reason to take the risk.
fwiw I would hazard that those having trouble with firmware updates are doing so because they have an inferior copy and not a genuine sjcam sj4000.
Dec 30, 2014, 04:54 AM
http://der-frickler.net
(Jo)Hannes's Avatar
Short Question:
Is it still that way that the TV-Out has to be enabled on every Camera Power-On or is there a new Firmware that fixes this issue?
Johannes
Dec 30, 2014, 05:50 AM
Wicked, tricksy, false!
mikefromgermany's Avatar
Yup.
No.
Dec 30, 2014, 06:08 AM
hey ,
check if this video helps you (in case you have the fake SJ4000 or as it called SD28)
Fake SJ4000 from DealExtreme SD28 & How to recover it (13 min 6 sec)
toward the end he talks about how to to recover the FW .
Dec 30, 2014, 08:13 AM
thank you for your answers
i tried the firmware from video and camera starts and works but the lcd on back doesn't light up so the problem is partial solved
also i don't have the fake case so i don't know if the camera is fake
Dec 30, 2014, 08:38 AM
and with this version SJ4000_FW(Version N20140809V01) the camera starts the lcd lights up and the image is moving but after 1 2 seconds the camera shuts off
so the camera can be recovered but only with correct firmware
i requested the firmware from the seller on aliexpress but no luck
Dec 30, 2014, 05:47 PM
I just recently got a SJ4000 WiFi for Xmas. The camera seemed to work okay, but I figured I would upgrade the firmware. Ever since I tried the new firmware off SJCAM's site I have not been able to get the unit to power back on.
The stock Firmware I believe was marked 12-04-2014 I think.
Is there anyway to restore the camera to factory defaults?
Dec 30, 2014, 06:53 PM
Originally Posted by JNJO
I would pay serious money to see that crash....
Glad you found the problem though.
Happy holiday flying.
Lol, I did pay good money to see that crash!! Even though I managed to borrow a screen from a really helpful guy here (thank you Saariq) it seems to have put an end to my ap holiday. Never mind I'll have another play tomorrow and if I can't get it to work I still have an epic new years Eve party to make me feel better!!
